		pdwalter(at)bigpond.net.a Guest
				 Posted: Wed Jan 18, 2006 9:02 pm    Post subject: Trim Tab |
				Hi Guys,
  I was wondering when riveting trim hinge to trim  tab if all three items being the skin, hinges and trim tab spar are dimpled or  is hinge countersunk ?
  Thank you
  Paul Walter
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		dan(at)rvproject.com Guest
				 Posted: Wed Jan 18, 2006 9:49 pm    Post subject: Trim Tab |
				IIRC, dimple the skin, c-sink the spar, and don't  do diddly to the hinge.
  Same setup when you rivet the flap hinge to the  wing.  Wing skin is dimpled, brace is c-sunk, hinge is left  alone.
  )_( Dan
  RV-7 N714D
  http://www.rvproject.com
  [quote]   ---
		rv6capt(at)pacificcoast.n Guest
				Dimple skins countersink hinge.
 Norman
 Paul Walter wrote:
  	  | Quote: | 	 		   Hi Guys,
  countersunk ?
  Thank you
  Paul Walter
				 Posted: Wed Jan 18, 2006 10:29 pm    Post subject: Trim Tab |
				Thanks Dan,
  Also, with rod end bearing for attaching elevator  to HS. To get all perfectly in line did you just count the amount of rotations  on each as it threads into the plate nut ?.
  Regards  - Paul
  [quote]   ---
				 Posted: Wed Jan 18, 2006 11:01 pm    Post subject: Trim Tab |
				Sort of.  Van's plans call out suggested  dimensions for the rod end bearing, distance from the spar or something like  that.
  My 2 cents is -- don't sweat it until you're ready  to mount the rudder on the VS permanently.  Then you just make sure you  have (a) alignment of all the rod ends with the hinge brackets, (b) rod ends  adjusted to provide full range of rudder travel without any chafing or  interference, (c) counterweight arm is aligned with the top of the VS and  doesn't interfere.
  )_( Dan
  [quote]   ---
				 Posted: Thu Jan 19, 2006 12:11 am    Post subject: Trim Tab |
				Thank you Dan,
  That is how it will be done.
  Paul
  [quote]   ---
		fvalarm(at)rapidnet.net Guest
				 Posted: Thu Jan 19, 2006 1:56 pm    Post subject: Trim Tab |
				I'm just now working on mating the elevators to the  horizontal stab.  I have initially set the rod end bearings as  per the plans.  I'm getting ready to drill the elevator control horns but  they are not square to the main center bearing or to each other. I was just  about to email Vans (as the plans don't go into much detail here) when I saw  this thread.  Are the elevator rod end bearings supposed to be adjusted  until the horns are square?  This would mean each rod end bearing will be a  different measurement from the spar and the counter-balance arms will not be  exactly parallel to the horizontal stab as they are now.  What have others  done here?
  Bevan
  RV7A
    From: owner-rv7-list-server(at)matronics.com  [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Paul  Walter
 Sent: Thursday, January 19, 2006 12:10 AM
 To:  rv7-list(at)matronics.com
 Subject: Re: Trim  Tab
  Thank you Dan,
  Paul
  [quote]   ---
