Tim(at)MyRV10.com Guest
Posted: Tue Aug 08, 2006 12:31 pm Post subject: Fuel Pump Cooling Shroud |
I'm thinking that I may add a fuel pump cooling shroud
some time, just because it seems like a prudent thing to do
given the heat of the engine compartment.
I found one at:
http://showplanes.com/index_800.htm
Does anyone know of any alternate suppliers?
I just added about 4" extensions to my exhaust last night.
Haven't flown with them yet. As many of you found at OSH,
the older exhaust systems are shorter than the new. I figured
I'd see if it made any noise difference, or if I can notice
any heat difference. I don't have enough heat that
it will be easy to tell, but if suddenly things are cooler
then it'll be a plus. If it's quieter, that would be nice
too, although it isn't super loud. Just more little
things to tweak the bird closer to perfection.
rnewman(at)lutron.com Guest
Posted: Tue Aug 08, 2006 1:10 pm Post subject: Fuel Pump Cooling Shroud |
Tim,
On my engine (0-540-E4B5) which I harvested from a Cherokee 6-260
the fuel pump came with a simple cooling shroud fed by a 1" scat tube.
The shroud is super simple and may be easier to fabricate than source.
If I can remember, I'll send you a picture.
Bob
I found one at:
glastar(at)gmx.net Guest
Posted: Mon Aug 14, 2006 12:00 am Post subject: Fuel Pump Cooling Shroud |
Hi Tim,
NewGlasair offers one too:
<http://www.glasairaviation.com/options/glasairoptfire.html#fuelpump>
br Werner
Tim Olson wrote:
I found one at:
Posted: Mon Aug 14, 2006 3:25 am Post subject: Fuel Pump Cooling Shroud |
Perfect, just what I was looking for. Nicely anodized and
cheaper too. Thanks Werner!
Werner Schneider wrote:
Hi Tim,
br Werner
> I found one at:
