Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Wed Aug 09, 2006 8:33 pm Post subject: Skins |
I’m getting ready to attach the front fuselage skins and was wondering if I should use Proseal at the firewall like I did on the bottom skin.
Sean Blair
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
Tim(at)MyRV10.com Guest
Posted: Wed Aug 09, 2006 8:55 pm Post subject: Skins |
Absolutely. Keep that CO out of the cabin.
Sean Blair wrote:
| Quote: | I’m getting ready to attach the front fuselage skins and was wondering
Sean Blair
#40225
Sean Blair
Posted: Wed Aug 09, 2006 9:02 pm Post subject: Skins |
Thanks Tim...good luck with that nosewheel.
Sean
#40225
#40225
N967SB (reserved) |
jhasbrouck(at)woh.rr.com Guest
Posted: Thu Aug 10, 2006 9:34 am Post subject: Skins |
Sean,
Better check the0 plans!!!! The cowl attach hinges go in that rivet line I think. You0 can pro-seal when you place the hinges but you better wait till0 then. Look at the rivet call-outs on page 28-19, there are none called for0 on the firewall/skin yet..
John Hasbrouck
#40264
Sean Blair
Posted: Thu Aug 10, 2006 10:46 am Post subject: Skins |
Understood, John, but shouldn't I use Proseal at the access point between the firewall and the skins? I don't plan to rivet until the hinges are installed and don't see how I would get Proseal between the skins later.
Sean B.
#40225
---- John Hasbrouck <jhasbrouck(at)woh.rr.com> wrote:
| Quote: | Sean,
Better check the plans!!!! The cowl attach hinges go in that rivet line I think. You can pro-seal when you place the hinges but you better wait till then. Look at the rivet call-outs on page 28-19, there are none called for on the firewall/skin yet..
John Hasbrouck
#40264
#40225
N967SB (reserved) |
Posted: Thu Aug 10, 2006 11:16 am Post subject: Skins |
I had a QB fuse, and had a similar dilema. I used proseal in the
notches around the forward side of the firewall, and then put a
fillet inside too. It would be nice to get some between the
skins, but to serve the purpose of sealing CO, that should do
fine. If you got it between the skins...just a super thin
layer, it would possibly keep moisture out better. You could
probably put just the tiniest bit in and cleco it and still
rivet it at a later date.
seanblair(at)adelphia.net wrote:
Sean B.
#40225
Posted: Thu Aug 10, 2006 1:33 pm Post subject: Skins |
Tim is right. My point about the pro-seal was to be aware where the hinges
go so as not to creat a big mess that will need clean-up later. I think a
nice bead of the stuff in the joint between the inside of the skin and the
firewall would do nicely to seal. Should have been more specific but was
heading back to the office when I read the first post.....john
