ron.mcgann(at)baesystems. Guest
Posted: Sun Aug 13, 2006 9:01 pm Post subject: Clocking AN Blue Fittings |
G'day all
A number of sections require AN fluid fittings (eg elbows) to be installed (clocked) at a particular angle (eg the fuel line connections at the fuel valve). When the AN fitting is installed, it naturally 'bottoms out' into the part (eg fuel valve) and has a natural clocked position when it is tight.
To achieve a particular clocking, the fitting can't always be 'bottomed out' and hence tight. How do you achieve both correct clocking and a fit tight enough to prevent leaks? Does fuel lube etc provide a useful seal??
cheers,
Ron
#187 finishing
