jeff(at)westcottpress.com Guest
Posted: Mon Aug 14, 2006 5:04 pm Post subject: Fuel Sender and Pro Seal |
Is Pro Seal used between the tank sender gasket and outside flange of
the tank... or only on the inside side of the tank flange and sender
pass through?
Jeff Carpenter
40304
Finishing up the tanks and unpacking the fuse...
evmeg(at)snowcrest.net Guest
armywrights(at)adelphia.n Guest
Posted: Mon Aug 14, 2006 5:47 pm Post subject: Fuel Sender and Pro Seal |
I coated the mating surfaces of the gasket/aluminum. I saw that as where
gaps would happen. Don't tighten your screws too tight after you smear the
sealant and install it, you might snap a screw off in the nutplate....
Rob Wright
#392
Wings
ddddsp1(at)juno.com Guest
Posted: Mon Aug 14, 2006 6:39 pm Post subject: Fuel Sender and Pro Seal |
If you proseal the sender in ....HOW will you remove it to replace it or repair it someday? Might consider making a gasket out of cork material and put Fuel Lube on it. That would be a better fix.
IMHO
Dean 40449
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Visit http://www.juno.com/value to sign up today!
flysrv10(at)gmail.com Guest
Posted: Tue Aug 15, 2006 2:32 am Post subject: Fuel Sender and Pro Seal |
That's right! Throw the gasket in the garbage and just use the sealant. Use proseal everywhere! On the screw threads, over the screw heads and any other place you might suspect a leak. No kidding.
On Aug 14, 2006, at 9:42 PM, Evan and Megan Johnson wrote:
[quote]--> RV10-List message posted by: "Evan and Megan Johnson" <evmeg(at)snowcrest.net (evmeg(at)snowcrest.net)>
throw the gasket in the garbage and just use the sealant....I know this one
Evan Johnson
www.evansaviationproducts.com
(530)247-0375
(530)351-1776 cell
Posted: Tue Aug 15, 2006 6:18 am Post subject: Fuel Sender and Pro Seal |
The sender is easy to get loose...heavy material and not so much surface area for the sealant to hold onto. Do not however do the same to the cork gasket that goes between the inspection plate and the tank rib. That can be a bear to get loose when prosealed on.
Evan
Posted: Tue Aug 15, 2006 6:35 am Post subject: Fuel Sender and Pro Seal |
When I sent my recommendation I thought we all had the same gasket sent, apparently we didn’t. My gasket was a large rubber donut that I prosealed liberally against the tank side. I probably would have thrown a cork gasket away as well.
Rob Wright
#392
Wings
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Evan and Megan Johnson
Sent: Tuesday, August 15, 2006 9:20 AM
Subject: Re: Fuel Sender and Pro Seal
Evan
