dashvii(at)hotmail.com Guest
				 Posted: Mon Aug 21, 2006 11:13 pm    Post subject: Lightning Pilot Report Repost |
				Ok, I'll bite.  I've got several hours in the Lightning now.  Hopefully this
 won't bore all of you and I'll try not to be too technical.  Let me start
 with a little history on the Lightning.  The Lightning was developed around
 the same idea as the Esqual, a light, fast, fun, and affordable sport plane.
   The Vol Medici company that marketed the Esqual sold off the company and
 (so far) stop producing the Esqual kits.  Jabiru USA was the US importer for
 Esqual.  This aircraft complemented the Jabiru line of aircraft as well as
 providing for a low wing alternative to the high wing Jabirus.
 The wing of the Lightning was designed much like the pressure recovery
 wheelpants.  The wheelpants are from the RV series of aircraft and modified
 to suit our own needs.  RV borrowed the design from Cessna.  The idea is
 that there was a better way to fair the landing gear that would result in
 less drag.  At the point where the airflow starts to detach from the surface
 of the gear, the shape would create a suction that would reattach the
 boundry layer.  The wing was designed as a kind of teardrop shape with
 concave trailing edge shape.  It is a high laminar flow wing.
 Now the wing that is on the Lightning is kind of a reverse engineered wing
 that was originally on the Esqual wing.  For various reasons that airfoil
 was traded for a different one and the molds were destroyed.  The new Esqual
 wing is more of a Clark Y "Hershey Bar" type.  That wing will allow for a
 shorter takeoff run, but at the same time will float forever if you come in
 hot and get in ground effect.  In Europe, operating out of grass strips the
 lower takeoff run and slower liftoff speeds were more desirable on a sport
 plane than all out speed.  The Lightning wing is whole different beast.  The
 speeds are higher on the plane for takeoff and landing.  The flaps work much
 better than the Esqual in that they provide the needed drag where the Esqual
 is mostly lift and a means of not accelerating when pointing the nose down,
 kind of more like a speed brake.  As with any glass plane it will accelerate
 rapidly when the nose is pointed down in a clean configuration.  On one
 particular flight test in an Esqual I tested for aileron flutter after
 finding and tightning a loose aileron.  With the power to idle in almost a
 vertical down line the Esqual will quit accelerating and hold about 185-195
 mph indicated.  The Lightning will eagerly pass through 200 and rapidly
 accelerate past Vne.
 There were two "hybrids" and one prototype aircraft.  The first hybrid,
 which we refer to as the "Frankensqual" is an Esqual fuselage with the
 prototype set of Lightning wings.  It has an old 80hp Jabiru 2200 engine and
 will do 160mph flat out!  The airplane is about twice as pitch sensitive as
 the Lightning with much lighter feeling on the controls.  It has a far aft
 CG because of the light weight of the engine and had each wing that was
 60lbs. heavier.  Very impressive performance and after about 15 minutes of
 flying it you get used to the sensitivity.  The next was Buzz's plane which
 tested the wheelpants, gear leg fairings, and the cowling for the lightning.
   Buzz built the fastest Esqual in the world, by about 40-50mph!  In fact,
 his plane is similar in performance to the Lightning.  In an all out speed
 comparison at 5,000 feet the prototype Lightning pulled away from Buzzes
 plane by about 1-2 knots.  The pitch of the prop wasn't set to the optimal
 level on the prototype at the time in its defense.  Some of the speed can
 certainly be attributed to Buzzes craftmanship and attention to detail.  For
 those of you who have seen it you know what I mean.  Getting everything
 faired over and making sure that you have a tight fit and smooth finish
 amounts to drag reduction, and superb looks.  Buzz also got custom leather
 interior and foam fitted seats put in.  I encourage any of you builders to
 do something similar.  The cloth seats are comfortable, but those
 leather/foam seats just really feel nice and make for a comfortable ride.
 The prototype, as did Greg Hobbs' plane had a thicker tail section which was
 the result of a miscommunication.  The fiberglass layups were extremely
 thick in the tail which resulted in a much heavier fuselage with an aft CG.
 While this is great for speed, it is horrible for loading arrangements and
 total useful load.  All of the newer planes have a lighter fuselage which
 should mean better takeoff performance and acceleration.  The prototype also
 had an early horizontal stabilizer that was (I think) 6lbs heavier per side.
   It has since been replaced with a production tail.  Nick is continually
 finding little ways to improve performance, looks, functionality, etc.  This
 is as much his baby as anybody's and he continually tweaks things.  The
 prototype eventually got to a little over 200mph TAS in level flight.  That
 was at greater than 3300 rpm though.
 Now on to the Pilot Report:
 First off, approaching the airplane you notice that it is a very nice
 looking plane.  The complex curves of the composite aircraft look very
 similar to that of a Lancair or Cirrus.  The plane is smaller than either
 and looks fast just sitting there.  A walk around is similar to any other
 light airplane with attention to the composites.  I like to get down to eye
 level with the surface and look for any chips or cracks that may indicate
 delamination.  So far I've never found any, which is the way it should be
 for a newly built plane, but it is a different type of a thing than you look
 for in a metal airplane.  I pay careful attention to the tail area and
 stabilizers.  The wings are extremely strong and both main wing spars cross
 through the fuselage, under the seat.  The rear of the wing attaches to the
 fuselage without a carry through structure.
 Getting in the airplane is accomplished by climbing up on the wing, being
 careful to avoid stepping on the flaps.  The sides of the plane are fairly
 low and you can easily throw a leg over into the cockpit.  At this point you
 want to step into the seat and then your other leg goes over and into the
 floorboard.  Once seated you find that there is adequate room for two adults
 to fit comfortably, even for long trips.  The center console does get in the
 way, keeping you from moving the stick to the stops because it hits your
 knees.  Future planes will have a console that terminates at the edge of the
 seat.  This should fix the problem.  Sitting in the plane the seats are
 reclined a bit.  I find that on a long trip this made me want to raise my
 head forward and that was uncomfortable after a while.  If the plane is
 going to be used for some long trips I would suggest fasioning some type of
 head rests.  This of course would limit the useful load some though.  The
 visibility is incredible with that bubble canopy.  The canopy itself is much
 clearer and free of distortion when compared to the Esqual.  Another thing
 is that the Lightning has a longer nose and gives a difference perspective
 than flying in an Esqual.
 With two on board and 10 degrees of flaps the plane will Flying Greg's
 airplane I found that the airplane was very responsive.  The airplane will
 rotate the nosewheel to a degree or so at about 50 mph and will hop into the
 air at a little less than 60mph.  Once airborne a speed of 80mph will give
 you greater than 1000 feet per mintue climb.  The airplane is nimble, about
 90 degrees of rolls per second.  It has a really nice feel to it.  The
 pushrods give a direct feedback from the plane and have a firm, but not
 heavy feel.  This gives the plane a sporty feel, but not a twitchy overly
 sensitive feel.  In a climb with high RPM and low speeds the plane requires
 some good rudder input.  Again the controls are firm, but not heavy.  Greg's
 airplane had a trim control issue at first which caused us to run out of
 trim and the nose would still fall at certain speeds.  The plane can be
 flown in all operating configurations without trim, but it is more
 comfortable and easy to fly with the use of trim.  The plane can be flown
 hands off when in unaccelerated steady-state flight in trimmed
 configuration.  Again, on a long trip a dual axis autopilot would be nice to
 have, especially when coupled with the Grand Rapids EFIS.  That would even
 do virtual approaches on autopilot.
 Landing speeds seemed to fall right in place if you can enter the pattern at
 no more than 110mph and slow to around 100 on downwind.  The plane flies a
 nice at the 65mph final approach speed.  The plane seems to have good rudder
 control and excellent aileron control authority in these lower speed ranges
 as well.  Landing is more challenging in some ways than the Esqual.  The
 Lightning doesn't really float.  It is similar to a high performance Mooney
 in that the laminar flow wing flies to a point and then it stops.  The trick
 is to round out the flare with a slight nose high attitude just as you reach
 the stall speed of between 45-55mph depending on configuration.  I liked
 using 20 degrees of flaps instead of 30 degrees.  For me it seemed to give a
 flatter and better feel on the approach.  30 degrees of flaps led to a good
 decent angle and although the plane will land just as smooth, I felt that
 this wing wanted to fly onto the runway.
 Flying Greg's plane out to the Tucson area we covered around 500 miles in a
 little over 2.7 hours.  We burned approximately 6.0 gph at 2950 RPM
 (slightly high side of cruise RPM)  Greg admitted that the jets weren't
 quiet tweaked as well as they could be and that a slightly lower fuel burn
 would be in the near future for his plane.  We also didn't have the plane
 all fastened up and as sleek as it could be.  The plane still had a slight
 right roll which resulted in about an inch of each aileron being deflected
 and causing undue drag.  Greg had planned on fairing over some small parts
 around the wheelpants and gear leg intersections.  We had hotter than normal
 CHT's due to an 'experiment' with adding a ramp to one side of the cylinder
 heads at the entrance.  This proved to actually make the majority of the air
 go over the cylinders at any angle of attack and out the outflow.  I
 understand that with the ramp removed the CHT's are more uniform now.  With
 these little improvements that Greg has done I imagine he'll pick up another
 10 knots or so at least.
 There had been the thought of testing some gap seals on the prototype to get
 some additional speed for free type of an improvement.  I had also suggested
 a winglet design for cruise performance, looks, and the added stability for
 long cruise flights.  If correctly designed they would slightly increase
 speed, increase range and climb rates, decrease takeoff roll, but I believe
 the looks are worth as much if not more than the performance gains.
 If any of you know Greg or if he is part of the list, tell him that I'd be
 happy to make the journey out west to fly any of the customer planes on some
 of the first flights.  They all are a little bit different and all have
 their own special needs as far as setting them up.  Once you get things
 right though you get a "Lightning" fast airplane that is comfortable and
 stable.  Hope you all enjoyed the read and any little improvements to the
 plane that you want to suggest I'll be sure to relay to Nick.
                                                           Brian Whittingham
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
