		Tim(at)MyRV10.com Guest
				 Posted: Thu Jan 19, 2006 10:48 am    Post subject: Pitot Check |
				I just checked with my on-field FBO. They no longer do pitot
 static checks, and they always have rented scales for W&B but
 the guy they rented from no longer works at the other FBO so
 they don't know that they can rent them anymore.
 Is it true that a builder can do their on VFR pitot check, and
 then perhaps during/after the flyoff I could fly to a neighboring
 airport to get a full IFR pitot check?
 And scales....what are others planning to do about scales?
 Are these something you can usually find locally to rent?
 Tim Olson -- RV-10  #40170
 DO NOT ARCHIVE
		rvbuilder(at)sausen.net Guest
				 Posted: Thu Jan 19, 2006 11:46 am    Post subject: Pitot Check |
				 Have you checked  with your local EAA chapters?  They are usually your best source of information for this.  I believe my chapter has scales they loan out when my time comes.  Worth the yearly chapter fees alone!
  Michael Sausen
  -10 #352 Fuselage
		jjessen(at)rcn.com Guest
				 Posted: Thu Jan 19, 2006 11:56 am    Post subject: Pitot Check |
				Scales at your local EAA chapter?
		ddddsp1(at)juno.com Guest
				 Posted: Thu Jan 19, 2006 1:05 pm    Post subject: Pitot Check |
				Tim,
 If you have any friends that RACE stock cars or sprints they will have portable scales that will work to weigh your plane.
 DEAN
		lwalters2(at)cfl.rr.com Guest
				 Posted: Thu Jan 19, 2006 3:13 pm    Post subject: Pitot Check |
				Tim Olson wrote:
 I believe that is true, but you need to check a mor authoritative source!!!
 If you can't find suitable scales that go to 600 Lbs or so, you can take
 two standard bathroom scales and lay them side-by-side with appropriate
 material to bridge over the scales.  The wheel contact area needs to be
 in the center between the scales.
 If you cannot round up the number of scales, then you can use the
 'fulcrum' method.  Picture a 2X4 exactly horizontal, with one end on the
 scale and the other on the floor.  Position the wheel so that the
 distance from the wheel to the scale point is multiples of the wheel to
 the floor point.  Do the math.
 Linn
 No virus found in this outgoing message.
 Checked by AVG Free Edition.
 Version: 7.1.375 / Virus Database: 267.14.21/235 - Release Date: 1/19/06
		coop85(at)bellsouth.net Guest
				 Posted: Thu Jan 19, 2006 3:58 pm    Post subject: Pitot Check |
				Tim,
    The only pitot/static check that is required is for the transponder
 altitude reporting.  Therefore, if you don't have a mode C requirement where
 you are going to do your testing then there is no test required.  The Mode C
 XPDR requirement is for VFR or IFR.
 Marcus
 40286
		bhughes(at)qnsi.net Guest
				 Posted: Thu Jan 19, 2006 6:58 pm    Post subject: Pitot Check |
				At our local EAA meeting mid last year a DAR gave a talk on new rules.
 One was if the plane had a transponder it had to be tested with
 documents before phase 1 started.
 Bobby
 40116
		armywrights(at)adelphia.n Guest
				 Posted: Fri Jan 20, 2006 8:05 pm    Post subject: Pitot Check |
				Have you checked your local EAA chapter (you ARE a member, right???)?  A
 member in mine is an IA, teaches at a local Comm College, and can get some
 whenever he needs to.  Local chapter (if you have one) is definitely a good
 thing.
 Rob
				 Posted: Fri Jan 20, 2006 8:49 pm    Post subject: Pitot Check |
				Oh yeah, I'm a member fer sure.  Our chapter is a smaller chapter
 though, that isn't quite as active as many, and we don't currently
 own scales.  But, after contacting them, we're going to see
 if we can renew the old push to get some.  I have no idea what
 they cost for good ones, but I'd be willing to pitch in to the
 chapter to get some.
 Thanks everyone for suggesting the chapter.  I almost forgot to
 check them initially.
 DO NOT ARCHIVE
  thing.
  Rob
