pilotdna(at)HOTMAIL.COM Guest
Posted: Thu Aug 24, 2006 12:46 pm Post subject: Cheap 601XL flap actuator alternative |
For you scroungers and scrap builders, I came across a neat linear actuator
that is almost identical in size and function to the one Scott Laughlin is
using at www.surpluscenter.com . Although the force rating is overkill, it
has built in internal limit switches and a built in position potentiometer,
which can be wired up to a snazzy lighted three-position controller switch
that is also at the surplus center. Best of all, the actuator is only $72
brand new and the controller is $50. The 8 second full retraction time
sounds about right, and 4 pounds isn't unreasonable to me.
The controller is here:
http://www.surpluscenter.com/item.asp?UID 06082410322769&catname=electric&item=5-1577-C
The actuator is here:
http://www.surpluscenter.com/item.asp?UID 06082410322769&item=5-1577-4&catname=electric
I ordered one, and my plan is to set up the three controller buttons with an
up, approach, and down position (like a Bonanza uses). Seems better than
holding a toggle switch to extend them and guessing at the position or
watching a RAC indicator.
This is just my idea, nothing is installed or tested, but I though some
might find it interesting.
Doug Eatman
St. Augustine, FL
Flaps & Ailerons, 601XL
learn, build, fly, but do not archive
admin(at)arachnidrobotics Guest
Posted: Thu Aug 24, 2006 1:01 pm Post subject: Cheap 601XL flap actuator alternative |
I like it. : ) Thanks for the info.
Doug Eatman <pilotdna(at)HOTMAIL.COM> wrote:[quote] --> Zenith-List message posted by: "Doug Eatman"
The controller is [quote][b]
Posted: Thu Aug 24, 2006 6:16 pm Post subject: Cheap 601XL flap actuator alternative |
A very nice unit at a good price. One key difference between it and the
factory part is that the limit switches are non-adjustable and the travel 4
inches. If you weld up the flap actuator parts as per the Zenith plans a 4
inch travel is too much and will end up bending something. Yes the stops in
the controller are programmable but you had better not move too far while
setting them.
A scratch builder who is welding his own parts could just make the
attachment arm on the flap tube longer so that a 4 inch travel would be just
right. I suppose you could extend the arm on the Zenith part too.
-- Craig
Posted: Thu Aug 24, 2006 7:03 pm Post subject: Cheap 601XL flap actuator alternative |
Looks like they also have the part number LACT2P actuator which has a 2 inch
travel but not the LACT3P (3 inch travel). I believe 2 inches of travel is a
better match to the standard Zenith flap tube than 4 inches. The rough
settings shown for the micro switches show in 6-B-19 (dated 04/04) give
about 2 inches of travel (63mm - 12mm = 51 mm or about 2 inches) but this
adjustment is refined for 30 degree travel as specified on 6-S-3.
My wings are not hung so I can't say what my limit switches will be set to.
But 3 inches of travel will move the flap arm from where it hits 6B5-2 to
where a straight line from the actuator attachment points intersects 6B5-2.
-- Craig
nfivesl(at)yahoo.com Guest
Posted: Fri Aug 25, 2006 4:31 am Post subject: Cheap 601XL flap actuator alternative |
Great find Doug!
I noticed they offer a mounting bracket too. The
Built-in potentiometer and available controller makes
this a better actuator than what I used. I can't
complain since a friend gave me the one I'm using.
Thanks for the post and looking out for everyone.
This may be the way to go for XL plans-built flaps.
Take care,
Scott Laughlin
Working on carb air filter/heat muff, etc.
http://www.cooknwithgas.com/6_19_06_Cowl_Rside.JPG
--- Doug Eatman <pilotdna(at)HOTMAIL.COM> wrote:
Quote: |
<pilotdna(at)hotmail.com>
Posted: Fri Aug 25, 2006 9:52 am Post subject: Cheap 601XL flap actuator alternative |
Thanks for the input everyone.
Special thanks to Scott L. for your extensive detailing of your ideas on the
webpage. My flap arm might "coincidentally" look a bit like yours one
day...
As a side note, the '76 Grumman Tiger I rent uses a simple toggle switch for
flaps and it is still my favorite of any certified plane I've flown. If
anything about the controller leaves me with a question about reliability,
I'll just use a switch.
Doug Eatman
St. Augustine, FL
scrounge-build 601XL "The Batplane"
