				 Posted: Sat Aug 26, 2006 6:57 pm    Post subject: Rant, question, suggestion: errors in plans/drawings |
				Rant mode on; drinkers of the 'Van's can do no wrong' koolaid, please
 stop & delete now.
 Several weeks (months?) ago I built up all the fuselage bulkheads
 including the main spar carry-thru for my -7 kit. I carefully followed
 all the directions/drawing indications I could find, especially on the
 spar carrythru bulkhead. I noted & carefully followed the exploded views
 on dwg 11 (rev 10-16-00) & later, dwg 22 (rev 10-27-00) showing the
 bolts for the F633 L&R control brackets & all the F716 seat ribs with
 the heads to the rear, threads forward.
 I built up the tail cone. I completed the prep work for final assy of
 the midsection. I began the riveting of the midsection several days ago
 & today, neared completion of the riveting.
 While studying dwg 22 section views to determine the orientation of the
 bolts through the F715 seat ribs, I noticed that they show nuts on the
 rib flange of all the F716 seat ribs where they bolt to the F704 spar
 carry-thru. 'Curses; must have not been paying attention when I bolted
 this stuff together.' (Bad medium term memory of earlier careful study
 of plans.) Out came the wrenches, re-oriented all the F716 bolts,
 retorqued. Happened to glance at the exploded view on the same dwg. All
 rib bolts drawn with head on the rib flange. I checked dwg 11 exploded
 view for the F633 bolts; it's inconsistent with the section view on dwg
 22 also. Errors/inconsistencies #742 & 743 (guesstimate   ) noted in
 the plans and/or instructions. By the way, this same section in the
 instructions tells you to cleco in & drill the seat & baggage floors
 without telling you to install the baggage ribs at all & before they
 mention installing the F715 seat ribs, which must be curved by the
 builder, have centerlines drawn on their bottom flanges (not
 prepunched), & be match drilled to the belly skin. My revision of dwg
 shows the control stick walking beam assy to the spar with bolts
 oriented in a fashion that cannot be achieved under the current laws of
 physics. When I called about that, the tech guy had different
 orientation for some of the bolts, on his dwg with the same revision
 date. Excuse: 'Well, sometimes minor changes are made without changing
 the rev date/number.' His 1st suggested change also could not be
 achieved under the current laws of physics. The final result was
 basically, 'assemble it however you can to get it to work.'
 I've lost count of the number of times I've called the tech guys at
 Van's to politely question or point out this kind of stuff & asked
 repeatedly why they don't offer a section of the website with
 corrections & updates. They are usually courteous, but I invariably get
 various lame excuses like 'you should read ahead', you should know how
 it's done', 'well, when we built the prototype, we didn't have the
 instructions', etc etc etc. Sometimes they say they will bring up the
 issue 'at a staff meeting' but rarely if ever do they act like the
 issues are any big deal. Never is there any feedback or encouragement to
 continue reporting this stuff & with a single exception (defective AL
 bar stock) never an admission that others have had the same issue.
 Ok, rant mode off.
 Question: should I care which way the F716 bolts are oriented (currently
 head forward, nut/washer on rib) or the F633 bolts (currently head on
 F633)? The belly skin rivets under the F716 bolts will be less
 convenient to drive, but still 'doable'.
 Suggestion:
 We all take advantage of Matt's wiki to add a section for each model &
 sub sections for each assy or part that we have problems understanding
 or that are obvious errors/inconsistencies. The entries should document
 the plan revision date and/or the instruction revision date. This should
 help us all by consolidating records of problem areas, something Van's
 is obviously unwilling to do.
 Is this a worthwhile suggestion?
 (Again, koolaid drinkers please don't reply.)
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		Brian Gawronski
				 Posted: Sun Aug 27, 2006 7:32 am    Post subject: Re: Rant, question, suggestion: errors in plans/drawings |
				I feel your pain.  I’ve wasted countless hours attempting to decipher Van’s instructions.  I find them poorly organized, lacking necessary detail, and at times ambiguous.
 After designing a great airplane, the single best thing Van could do for his customers would be to document the assembly process from the perspective of a first-time builder.  Really build a kit, start to finish, exactly according to the instructions.  This would allow them to find and fix errors and omissions.  I believe Van’s thinks their plans are accurate and complete, but the authors perhaps know too much about the assembly to realize how much they take for granted.  However, not maintaining rigorous revision control is inexcusable, and indicates a lack of respect for their customers.
 I’d happily buy the documentation that would eliminate the hours spent staring at the plans instead of building, or worse, having to disassemble and rebuild, because I can’t read minds or see into the future.  Read ahead?  Okay, but let’s please be reasonable.
 This is supposed to be fun, right?
		Bob Collins
  Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
				 Posted: Sun Aug 27, 2006 8:39 am    Post subject: Rant, question, suggestion: errors in plans/drawings |
				 	  | Quote: | 	 		  I checked dwg 11
  exploded
  view on dwg
  noted in
 It's been awhile -- two years -- but I vaguely remember this part. However,
 I didn't bother too much with the plans because there was -- as I recall --
 another issue which solved the question for me -- access to the bolt head
 (or maybe it was a nut) in the future. Anyway, as I recall -- without the
 specifics -- there was no way for me to EASILY check on those nuts (to see
 if they were working loose except if I oriented them one way (I have
 removable floors). There have been certain phases of the build, I've
 noticed, where it's helpful for me to slow down a bit and say "OK, this
 might be the easiest way to BUILD it, but what's the easiest and best way to
 accommodate an inspection once I'm built. YMMV.
 I think the suggestion is a good one. I think the thread could prove helpful
 ONLY if we can separate the suggestion from characterizing other people one
 way or the other.
 I'm loathe to have another week of deleting messages that really have no
 value to the build process, especially when the essence of the thread is
 about building.
 Do not archive.
  _________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
