JRatcli256(at)aol.com Guest
Posted: Fri Aug 25, 2006 3:34 pm Post subject: Propellers - IVO or Warp |
Hi guys,
Getting on with my Mark 3 Xtra project with Flaps/Alirons and considering a Rotax 912 ULS 100 HP and Prop.
Would like to get your input on which Prop to use. Planning on a 70", three blade but need to make a decision on brand/model. Price for me is a serious consideration and it would be very nice to have ease of adjustment. Without your experience I'm sure there are many things I haven't considered.
Ivo has two suitable units. (1) Their Ultralite (Light) for up to 100HP (2) Their Ultralite (Medium) for 100HP and higher. They also have the Magnum for more powerful engines and higher speeds.
Warp of course has the Warp.
I understand the Warp is tougher and the Ivo much easier to adjust.
The Ivo light prop is less expensive and the Ivo Medium or Warp about the same price.
What about maintenance? Also is the 2.5" spacer sufficient or will I need the 4" spacer?
I live on Johns Island, SC just outside of Charleston. (lowcountry) about sea level.
Density Altitude around 1200' - 2000' during the summer months and am a fair weather flyer. Is there any other type in a light aircraft like ours?
Thanks -- John Ratcliffe
Richard Pike
Posted: Fri Aug 25, 2006 5:15 pm Post subject: Propellers - IVO or Warp |
I think you get better performance out of a two blade prop than with a
three blade.
Richard Pike
MKIII N420P (420ldPoops)
three blade
*<snip>
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Sat Aug 26, 2006 5:13 am Post subject: Propellers - IVO or Warp |
John,
Between the two, I would go with the Warp.
You might also consider the Powerfin, I have an F model 68" Powerfin on my Mk-3 and it is super easy to adjust and performs well. However I do not have the high hours on it that others have with the Warp Drive. The Warp is surely the most well proven prop for pushers.
Denny Rowe
HShack(at)aol.com Guest
Posted: Sat Aug 26, 2006 6:59 am Post subject: Propellers - IVO or Warp |
In a message dated 8/26/2006 9:14:16 AM Eastern Standard Time, rowedl(at)highstream.net writes:
My $.02............I like a Warp Drive prop because it's the toughest prop you can buy. It's also real heavy. So heavy that, in some configurations, it's out of spec. for your gearbox.
Check out the Kiev or Hot prop [same thing]. It's much lighter [you can use an extension no problem] , more efficient, smoother, quieter, prettier, & tough. We have one on a MkIII float plane with over 800 water landings & it almost looks like new. I also have one on my FSII.
Costs about the same as a Warp.
Howard Shackleford
FS II
SC
Richard Pike
Posted: Sat Aug 26, 2006 11:42 am Post subject: Propellers - IVO or Warp |
Just to muddy the waters a bit more -
Tried a three blade Kiev Hot Prop on the FSII with 582 and it did not
perform as well as an Ivo 68" two blade. And it was noisier.
Today I delivered my old J-6 Karatoo to the grass strip where the new
owner will be keeping it, I had always flown it with a 66" two blade
Warp Drive, but after it's "incident" a while back, it got a 68" two
blade Powerfin stuck on it instead. It is now about ten mph slower than
it was with the Warp Drive. Perhaps it would still be as fast if it was
a 66" prop instead? Don't know.
IMO, a Warp is extremely efficient, and almost indestructible. An Ivo is
equally efficient, fragile compared to the Warp, and (because of it's
flexibility) runs a lot smoother, much less vibration. Those would be my
first choices for a prop. And IMO, a two blade is more efficient than a
three blade.
Richard Pike
HShack(at)aol.com wrote:
Quote: | In a message dated 8/26/2006 9:14:16 AM Eastern Standard Time,
John,
Howard Shackleford
FS II
SC
Kingsport, TN 3TN0
Posted: Sat Aug 26, 2006 11:59 am Post subject: Propellers - IVO or Warp |
Ivo is
it's
be my
than a
| three blade.
| Richard Pike
Richard:
Was wondering how an IVO could "run a lot smoother, much less
vibration" than a Warp Drive??
After 2,400 hours flying in front of a Warp Drive Prop, I have yet to
find any one of the several I have owned to show any signs of
"vibration".
Quite possibly, the Warp you were flying had a problem or was not
adjusted in pitch, equal in all blades.
Or maybe it is a characteristic of a two blade Warp. I do not know.
Have never flown a two blade Warp on my airplane, or any other that I
can recollect at this time.
For the record, I have never had to balance a Warp since day one,
which was September 1993. My Warp Drive Props are not babied. They
get to experience flight in many different environments, many of them
quite harsh. I just took off my last Warp Drive 3 blade prop which
was installed in June 2004, just prior to my departure for Point
Barrow, Alaska. This prop came home with dings from rocks, sand, and
gravel, bathed in a lot of rain. My last flight with this prop and
the engine that pushed me to Point Barrow twice, was just as smooth as
it was when first installed.
In fact, I do not know of anyone who has ever had to balance a Warp
Drive, even after minor repair from stuff that falls off the airplane
or stuff that is thrown into the prop by the tires.
BTW: Warp Drive has a life time guarantee of satisfaction for their
product. If for any reason you want to send it back and get your
money, they are happy to oblige. Most folks don't want to give their
Warp Drive away. They are tough, efficient, and will get you there
and back home safely.
_________________ John Hauck
Titus, Alabama |
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Sat Aug 26, 2006 12:28 pm Post subject: Re: Propellers - IVO or Warp |
John, I just purchased an IVO 66" two blade prop for my Firestar. Are you saying that THere may be a need or a time when I would need to balance it? I thought because of the factory weigh-in and match as well as the torque arm warping of the blade what took place with one side took place with both sides.
Heroic Ohio 40 landing Ralph!
(A hero in my own mind).
Richard Pike
Posted: Sat Aug 26, 2006 1:31 pm Post subject: Propellers - IVO or Warp |
Not being an engineer, couldn't tell you why it is smoother. It is not
that the prop vibrates, or was imbalanced, or anything of that nature,
but having flown with both Ivo and Warp props, the engine/gearbox/prop
combination with an Ivo gives a distinct impression of being smoother. I
suspect the flexibility of the Ivo absorbs various harmonics,
engine/gearbox vibrations, etc., whereas the stiffness of the Warp does
not, but that is just a guess.
All of us on the list are aware you are a confirmed Warp advocate, and
you have good reason to be, but in my limited experience (having flown
only about 1,000 hours with only 4 Warp Drive props, three of them two
blades, and one of them a three blade - and having owned only 5 Ivo's,
two of them three blades and three of them two blades) an Ivo gives me a
distinct impression of providing a smoother flying experience.
Richard Pike
"vibration".
<snip>
Kingsport, TN 3TN0
Posted: Sat Aug 26, 2006 1:58 pm Post subject: Propellers - IVO or Warp |
balance it? | Heroic Ohio 40 landing Ralph!
Ralph:
No, Sir!
I said I never had to balance a Warp Drive Prop.
I have flown IVO Props quite a bit on Kolb Factory airplanes over the
years. When the silver tape was applied correctly, and it was a new
prop, was smooth as can be. However, when the silver tape would start
to release, just a little, that little prop would wear you out.
With the Warp Drive, I like the idea of setting the prop up, then
flying 400 or 500 or more hours without touching it. No need to.
Once it is adjusted to the airplane and the engine, there isn't
anything left to do. The Warp I pulled off my airplane is still
adjusted exactly like it was in June 2004, when I installed and
adjusted it.
Yes, I am a Warp Drive kinda guy. In addition, you might call me a
Kolb kinda guy, a Rotax 912ULS kinda guy, MATCO wheels and brakes
kinda guy, among a few other items of equipment I have used for a long
time with a great deal of success, e.g., reliability.
Take care,
Titus, Alabama |
Ralph Hoover
Posted: Sat Aug 26, 2006 2:28 pm Post subject: Re: Propellers - IVO or Warp |
And John, Brother Kolber,
I appreciate that you didn't take my question as an attack upon your person. I have always liked the careful way you word things, and have learned a bit of tact from that way. Both of us having Military backgrounds and "older" men, I would think myself as a low rank and you as an officer of merit would butt heads. Yet we don't. I am glad for that maturity in both of us. I rely heavily upon you're as well as others wisdom on this site. And guys, lets face it, We aren't playing with stuff that accepts a lot of "dumb" anywhere in it's make-up. Anytime we offer advise, it should be the best we can give because there as a great deal of “lurkers” out there that will literally go out “on your word” and do, because you said it worked!
I am always amazed the differing results each individual seems to attain from "much-like" planes, albeit the build aspect. There are "hammer" mechanics as well as detailers that are so meticulous that appearance is almost everything, not discounting anyone's applications. I tend to be more the kind of guy that if a pound of steel will do the job, lets make it out of two pounds and be better. I once baked Lasagna in the oven. The box said 350 degrees for forty five minutes. I did it at 700 degrees in 23 minuets. It wasn't there when I went to get it! I really enjoy this site for the tremendous detail everyone offers, as well as the “civility” of the writers.
I guess that when someone has applied the time tested ways to something, there is where one should look first for “ways”. The more I fly, the greater the appreciation grows in me for the value of the trials and tribulations of the many of you that do some serious , distance flying, while I hang so close to the nest.
Ohio Ralph
Mike Schnabel
Joined: 27 Jan 2006 Posts: 114 Location: Manchester, TN
Posted: Sun Aug 27, 2006 2:52 am Post subject: Propellers - IVO or Warp |
John / Gang,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Interesting comments about the IVO prop and leading edge tape. The IVO on my Firestar was a "factory installed option" so to speak. Meaning, it came with the engine/airplane when built by Bryan M (great job by the way, Bryan knows how to build a Kolb!). Anyway (my point) is to say that this plane with only about 6 hours of time on the engine, the leading edge tape is separating from the prop. Granted, this plane has set dormant for several years inside an enclosed trailer which may be the cause for this issue since it gets REALLY hot in there.
I have had several observers notice this, and sternly advise to replace the tape before taking her up (only test flown after build, I am still in training). For now, the few hours of taxi work I have done, I have left it as is. But will replace it before first flight. It might just be me, but I think I hear a noticeable change in sound when I run the engine right after pressing that tape down. But it always lifts back up after a while.
Strike one against this 2 blade IVO.
Another problem I have is that this 2-blade prop rubs against the aileron tubes when the plane is folded. Seems that the prop extension that is used, with the thrust angle, causes this. I asked a fellow flyer why the extension, and his thoughts were that to keep as much engine mass forward as possible, it was necessary for the extension to clear the back of the cage. He thought it was regular practice from Kolb (as they tend to be tail heavy?). Sounded reasonable to me, and I am happy to have it, except it is wearing out my aileron tubes! I have given serious thought to a 3-blade prop for that reason alone.
Strike 2 against this 2 blade IVO.
I dont know if I want to wait for strike 3, so I will just ask instead
What 3 blade adjustable prop is best on a Firestar 2, and which would you men suggest? I would expect differing opinions, and thats a good thing. This list is all about sharing of ideas, and were it not for that, all we would need would be a single heres how to do it manual. What makes an idea worthy is when you have some experience to justify the opinion.
There you have it, rant over. I hope you guys are all having a great weekend! I know I have, Saturday Steven Green flew in and allowed me my first few moments aloft in a Kolb (his Mk3) how sweet it is! Thanks Steven!
Mike S
Manchester TN
Firestar 2 503
John Hauck <jhauck(at)elmore.rr.com> wrote:
[quote]--> Kolb-List message posted by: "John Hauck"
Ralph:
No, Sir!
years. When the silver tape was applied correctly, and it was a new Get your email and more, right on the [url=http://us.rd.yahoo.com/evt=42973/*http://www.yahoo.com/preview] new Yahoo.com[/url] [quote][b]
Richard Pike
Posted: Sun Aug 27, 2006 3:38 am Post subject: Propellers - IVO or Warp |
Ivo used to use a really thick metal tape, but no more. The metal tape
that comes on them now is wimpy. Replace it with Powerfin tape, they use
a heavy thick vinyl, sticks great, price is right. Don't know how it
reacts to heat. Probably not too well. Their phone # is on their web page.
Concerning prop extensions, the air coming off the wing surfaces creates
a noise when it interfaces with the prop, and the further away from the
wing you can get the prop, the quieter it will be. If you have ever
listened to a Varieze when it flies over, they are a worst case example
of wing/prop interference noise. A two blade prop on a Kolb with a 2
stroke makes a lower-pitched growley sound, a three blade sounds like a
typical 2 stroke ultralight.
Richard Pike
<snip>
Quote: | I asked a fellow flyer why the extension, and his thoughts were that
<snip>
Quote: |
Mike S
Manchester TN
Firestar 2 503
Kingsport, TN 3TN0
Posted: Fri Sep 01, 2006 9:25 am Post subject: Propellers - Ivo or Warp |
Hi Guys,
First I would like to thank everyone for their input. Without everyone's help, I wonder if building would be as much fun, buying is much easier.
Conclusions reached so far:
1. Warp is tougher and easier to repair, but heavier.
A. Not being foam filled would make them tougher, easier to repair and heavier.
B. Is everyone using the nickel leading edge? This would impact all three advantages.
2. Ivo is considered by some to be smoother, unless the leading edge tape starts coming loose.
A. Without the nickel leading edge, Both brands would have leading edge tape.
B. With less then 100HP engine the light Ivo would be used, whereas with the 100HP engine a medium Ivo is recommended.
Would the added stiffness and additional weight of the medium make it less smooth?
C. Smoothness suggests less vibration, if ultralites can be considered quiet in any form, how would you quantify the difference?
(On a scale of 1-10) For smoothness? For Quietness?
3. An additional consideration in my case. With a 2 blade prop I can move the plane into my air conditioned garage without modification to the door.
A 2-blade prop is considered more efficient and less expensive ???
Would appreciate a comparison between a 2-blade Ivo and Warp for smoothness and quietness and between a 2-blade/3-blade prop, on a scale of 1-10.
4. Current prices:
Ivo 2 blade - $700
Ivo 3 blade - $890 (Medium)
Warp 2 blade - $495 (without nickel edge)
Warp 3 blade - $685 (without nickel edge)
Don't know what tapered tips cost. Didn't see any reference to tapered tips on there site.
So many questions. If money wasn't a consideration, why not just pick one and move on. Maybe an Ivo 3-blade. Can be converted to a 2-blade for a trial and if I like it, would have a spare blade. More expensive though.
Again thanks for the help. Looking forward to all replies.
John Ratcliffe
Ralph Hoover
Posted: Fri Sep 01, 2006 10:53 am Post subject: Re: Propellers - IVO or Warp |
John, Please put down the drup pipe! (Joke, just a joke. Actually put down the bottle of Jim Beam). The IVO Ultralight 2 blade prop is $ 400 not $ 700. Unless you are equiping your plane with a 100 H.P. or greater engine, the ultralight prop should suffice according to the IVO web site. I just purchased a IVO 66" two blade prop to replace my old wooden prop and was told at any time I could add a third (see single piece purchase) at any time. The weight and mfg date are on the hub end of the prop. They are a very consious bunch of people and the quality is as good as any.
Has anyone complained to IVO about the tape? They have a "tape replacement" video on their web site if it is a problem. Did they offer to relpace tape to anyone that had some of the tape come loose? If not, shame on them, the liabilities connected with that could come back and bite them. Plus, the PR would be very damaging to their growth and service value.
Ohio Ralph
APilot(at)webtv.net Guest
Posted: Fri Sep 01, 2006 2:45 pm Post subject: Propellers - IVO or Warp |
My Ivo prop is kind of old. I think I bought it in 1999, The leading
edge tape is holding up good on all three blades. Vic Gibson in
Sacramento
Mike Schnabel
Posted: Fri Sep 01, 2006 5:15 pm Post subject: Re: Propellers - IVO or Warp |
Gentlemen and ladies,
I am replying via the forum option, for some reason, I still get all the old email messages (my preference), but cannot respond to them! MATT D, What is up with that??
Anyways.....
I contacted IVO via email to tell them about the prop tape separation concern I was having. Since there is only 6 hours on the prop I thought they would be interested to know.
All I received back, was a message that I could buy new tape for 4 or 5 bucks plus shipping. Oh, and that they will accept a Credit Card with the 3 digit verification code on the back.
Well, I am glad they have a replacement tape, and it’s available for a good price. But as for customer service, as in asking me about my prop to see why the tape would fail after only 6 hours, they did not score so well.
I will try again to contact them to further explain my concern.
I have to say, their prop at the very low end of RPM (1700/1800) has a really hard "thwap thwap thwap" sound (reminds me of a great scene, the movie "Mystery Alaska", if you get the reference your grinning, if not, go rent the movie!)... but when it kicks over the 2k range, she humms like a humming bird that wants to sing... and at full throttle she roars like a lion and WANTS to be airborne NOW!!!
My point, I like the prop, and think it has great merit, but except for the tape separation thing, I would not complain.
Done whining... Except for the issue of not able to reply to the old email list!
Mike S
Manchester TN
Firestar 2 503
ElleryWeld(at)aol.com Guest
Posted: Sat Sep 02, 2006 3:54 am Post subject: Propellers - Ivo or Warp |
Last year I purchased a new IVO 3 blade it did have less vibration but it preforms much better as a 2 blade on a 447 Rotax anyway and I recently set up a warp and the IVO is much easier to adjuts but I think the warp would be much Stronger if you plan on running parts through it
My 2 censt worth if it means anything
Ellery in 447 powered Firestar
Thom Riddle
Posted: Sat Sep 02, 2006 4:31 am Post subject: Propellers - Ivo or Warp |
I'm curious as to why you seem to be restricting your prop search to
Warp and IVO. Maybe you've already narrowed down your search to these
two companies. If not, there are other very good props available
including PowerFin and GSC. Several Kolbers have had good experience
with the PowerFin and I had very good experience with a GSC on my
Titan. My GSC had Maple blades with an extremely hard leading edge
insert that never ever showed any nicks operating from all kinds of
nasty fields. I had a two-blade IVO on my early Firestar because that
is what it had on it when I bought the airplane. No complaints.
FWIW http://www.powerfin.com/
http://www.ultralightprops.com/products.htm
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Eugene Zimmerman
Posted: Sat Sep 02, 2006 5:57 am Post subject: Propellers - IVO or Warp |
I bought a new Ivo recently from CPS . The leading edge tape was very
unsatisfactory and I removed it after only a few hrs. I am running
it without any leading edge protection for the moment. I received
replacement edges with the prop but they are the same junk as what
was on originally. It would be a wast of time to install them.
I have had satisfactory experiences with Ivo props in the past but
with their current quality control I can no longer recommend them. I
recommend Powerfin for anything running a B box gear reduction.
On Sep 1, 2006, at 6:42 PM, APilot(at)webtv.net wrote:
leading
Sacramento
Steve Boetto
Posted: Sat Sep 02, 2006 8:32 am Post subject: Propellers - IVO or Warp |
In a message dated 9/2/2006 9:58:01 A.M. Eastern Standard Time, etzim62(at)earthlink.net writes:
Quote: | --> Kolb-List message posted by: Eugene Zimmerman <etzim62(at)earthlink.net>
Eugene,
The Firefly I bought from Duane came with a 2 blade IVO. The tape leading edge was holding up OK for the first few hours of Seaplane use. After I dinged it up with a loose bolt I called IVO for replacement tape. That was 2 years ago. The replacement tape was much thinner and failed in about 2 hours. I asked them why they went to a thinner tape and they said that the original vender no longer had the thicker tape. After a few hours on the Internet I found a tape supplier with a thicker tape. They sent me a sample roll. I also found that they had supplied tape to IVO but IVO no longer bought from them. I never tried the tape because shortly after that I received the Kiev prop. I suspect that they are still using the thin stuff. I don't know how either tape holds up with normal use, but with a lot of water exposure both fail quickly. If you want to try some of the sample roll, let me know.
I think IVO makes a good product, It just is not suitable for Seaplanes.
Steve
