ofd725(at)yahoo.com Guest
Posted: Fri Jan 20, 2006 2:33 pm Post subject: Paint |
I am starting to plan for the painting of my S7. I have read the Polyfiber manual completely and am wondering what kind of success everyone else has had using this method. What kind of process would you guys recomend to paint the aluminum and fiberglass? I am going to use a Polytone paint. How much is required to do the job?
Gary Olson
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
roncarolnikko(at)hotmail. Guest
Posted: Fri Jan 20, 2006 3:03 pm Post subject: Paint |
Gary I have just painted my fuselage with polytone white. Very easy to use
and white covers well. I don't think I'll make the tail group and wings on
this gallon, but expect two will be plenty. My lemon yellow graphics were
taped, sprayed, and unmasked in three hours easy. One quart will do graphics
on mine. Remember you can always spray more after a few minutes dry time,
but runs are a pain. I used Dupont Nasson automotive urethane for my cowl
and will use it on all metal. Ron NB Or
Quote: | From: Gary Olson <ofd725(at)yahoo.com>
To: Builder Hotline <kitfox-list(at)matronics.com>
Subject: Paint
Date: Fri, 20 Jan 2006 14:30:17 -0800 (PST)
Quote: |
Gary Olson
ASAP.
FLIER(at)sbcglobal.net Guest
Posted: Fri Jan 20, 2006 4:09 pm Post subject: Paint |
Ron,
You got two cross-coats with 1 gallon of Polytone??
Sounds to me like your coverage is a little thin.
Using HVLP, a top or bottom of one wing will use just
shy of a quart for 1 cross-coat and PolyFiber
recommends two cross-coats for typical coverage.
Which would be ~ two gallons just to do two wings.
Figure about 4 gallons or so of Polytone at least to
do a Kitfox.
Ted
--- Original Message ---
Subject: RE: Paint
Quote: |
<roncarolnikko(at)hotmail.com>
>Subject: Paint
> Thanks,
> Gary Olson
Quote: | >ASAP.
_-
browse
Subscriptions page,
FAQ,
List
Quote: | _-
Admin.
Brett Walmsley
Posted: Fri Jan 20, 2006 4:13 pm Post subject: Paint |
I am almost done.
Going to be pretty close to:
6 gal poly brush (1 brush 2 cross)
6 gal poly spray (3 cross)
6 gal ins. white poly tone (3 cross)
used 8500 reducer. HVLP gun.
very happy with results.
Easy.
Watch out for static electricity.
Smokey in Georgia
First time for me covering and painting.
_________________ Brett
Model IV 1200/912UL |
Posted: Fri Jan 20, 2006 4:27 pm Post subject: Paint |
Ouch! the wings are gonna hurt. Ron NB Or
To: <kitfox-list(at)matronics.com>, <kitfox-list(at)matronics.com>
Subject: RE: Paint
Date: Fri, 20 Jan 2006 19:09:01 -0500
Ron,
do a Kitfox.
Ted
Subject: RE: Paint
>do not archive
>>Subject: Paint
>> Thanks,
>> Gary Olson
>>ASAP.
>_-
browse
Subscriptions page,
FAQ,
List
>_-
Admin.
>_-
shericom(at)rogers.com Guest
Posted: Sat Jan 21, 2006 9:12 am Post subject: Paint |
Hi Smokey, I've just read your post and since I will
be ready to paint my M4 Speedster in the spring I have
a question or two for you. What model is your kit, and
what type of HLVP unit did you use, was it a complete
system or just a gun using a standard air compressor.
I have a large compressor and am not sure if I only
need to purchase a HVLP gun (if such a thing even
exists)
Any comments you may have would be a great help. Don
Stevenson, Caledon Ontario Canada.
I am almost done.
Easy.
Smokey in Georgia
Brett Walmsley
Posted: Sat Jan 21, 2006 9:37 am Post subject: Paint |
My kit is a M4 long wing with all the speedster mods.
The gun is a porter-cable PSH1 w/ standard nozzle (ebay $45) (I they are
over a hundred new)(many companies have similar models)
It is just a gun with the 20 oz. tank on top. Running a 22# +-.
Works real nice for me. I am NOT a painter.
One piece of advice I would give, would be to not over think the process.
It's just not that complicated.
The poly process is just like they say, "dead easy".
p.s. Watch out for static electricity
Regards, Brett (smokey or sparky, I've heard em all since I tried to burn my
airplane up)
bnn(at)nethere.com Guest
Posted: Sat Jan 21, 2006 12:49 pm Post subject: Paint |
At 09:11 AM 1/21/2006, you wrote:
exists)
I use the Husky HVLP gun and it seems to work well. However, if I had to do
it all over again I'd buy a more expensive professional gun. The Husky is a
pain to clean completely and I'm beginning to think cleaning it causes more
wear and tear than use. I recently had to rebuild the internals because
some had simply worn out from assembly/ disassembly. (In particular, the
air cap started leaking; a bad thing for an air gun.) I'd like to find a
gun that's made to be used and cleaned daily over a long period of time.
gun. I installed both a water separator and then a dryer in line. I've
never seen water in the separator so I think that was a waste of effort.
Here in San Diego the dryer works hard. I bought a really large one, (the
bowl is about 10" long and 4" diameter,) so I'd be able to do a lot of
paint without having to dry the agent.
2) is a pressure regulator at the gun. I run 90 psi to the gun and then
between 25 and 40 psi at the gun. I like this system a lot better than
using the compressor's regulator since there are no line losses.
Guy
eccles(at)Chartermi.net Guest
Posted: Sat Jan 21, 2006 1:27 pm Post subject: Paint |
Hey guys
jumping in with my two cents , what kind of paint are you spraying aerothane
or polytone for the final coats?
Posted: Sat Jan 21, 2006 1:51 pm Post subject: Paint |
Polytone when I get to that point, Don
--- eccles <eccles(at)Chartermi.net> wrote:
<eccles(at)chartermi.net>
Hey guys
aldaniels(at)fmtc.com Guest
Posted: Sat Jan 21, 2006 2:26 pm Post subject: Paint |
If you are getting water when you spray, even using a water separator
there is a trick. This usually happens when you spray a lot and the
compressor and the air gets hot. The water does not come out of the air
till it cools, like coming out of the gun. I got an extra hose and
coiled most of it in a bucket of ice water, then put my water trap after
that hose. This cools the air so the trap can take it out. I like the
Sharp gun. Remember that the size of the tip is critical, so match it to
what you are spraying. Any of the Poly stuff you can use a 1.5 or primer
type gun, but urethane requires a smaller tip.
>exists)
Guy
Lynn Matteson
Posted: Sat Jan 21, 2006 2:51 pm Post subject: Paint |
I used the Polyfiber products throughout, with their enamel for the
metal and f'glas parts. The enamel must be shot over their epoxy
primer. In the case of my flaperon horn brackets, I got this advice:
Shoot the brackets with epoxy primer, then while it is still wet, shoot
with polybrush. Shooting into the wet primer makes a transition from
the epoxy primer to the polybrush, and eventually the polyspray, and
finally the polytone. I chose to do this because I wanted to rivet the
brackets on before shooting anything on my wings, so that my brackets
would be a matching color, and the rivet heads would be painted. I've
seen too many that were riveted on after painting and they don't look
so good.
Lynn
Gary Olson
hands ASAP.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Jan 21, 2006 3:10 pm Post subject: Paint |
Don-
I bought an HVLP conversion gun through F&M Enterprises, who were the
Polyfiber people several years ago out in El Toro, CA. This gun uses a
regular air compressor but you regulate it down to 10 psi. It worked
beautifully for shooting my plane. It has a hopper/gravity feed and
holds about 20 oz. I bought it when I was living in California back in
about 2000. My gun is a model 38308 by Central Pneumatic, and was
distributed by Harbor Freight Tools. Cost was about $70. There are
probably others out there by now. The beauty of it is you use up every
drop of paint in the hopper, and if you run short pour in another ounce
and finish the job.
Lynn
On Saturday, January 21, 2006, at 12:11 PM, Donald STEVENSON wrote:
Quote: |
<shericom(at)rogers.com>
exists)
N369LM |
Brett Walmsley
Posted: Sat Jan 21, 2006 5:32 pm Post subject: Paint |
poly-tone
