archermj(at)swbell.net Guest
Posted: Sun Sep 03, 2006 6:09 am Post subject: Kilovac EV200 |
Hello all.
I will be using Z-16 with my Jabiru installation. The Jab Permanat Magnet
only puts out 20 Amps and I was considering using the Kilovac EV200 since it
has a low current draw. I saw some traffic earlier that there was a noise
problem with the Kilovac. Has anyone used the EV200 sucessfully. Are there
any tricks or technequies for this uint.
Matt
www.zodiacxl.com
Posted: Sun Sep 03, 2006 8:48 am Post subject: Kilovac EV200 |
Matt and all,
Magnet only puts out 20 Amps and I was considering using the Kilovac
EV200 since it has a low current draw. I saw some traffic earlier
that there was a noise problem with the Kilovac. Has anyone used the
EV200 sucessfully. Are there any tricks or technequies for this uint.
As I may be the one who raised the EV200 noise issue, here are some info.
The circuit I designed is based on Z-16 with two batteries and two EV-200.
The he Low Voltage light failed to illuminate when the EV-200 was in
use. After much head scraching, I concluded that the Low Volage module
did not like what the EV-200 was throwing at the circuit.
After much head scratching (the Low Voltage module worked flawlessly
when the main EV-200 was open), I replaced it with a Perihelion model,
and everything has been working perfectly for nearly two years.
More on the LVW story at http://contrails.free.fr/elec_lvwm_en.php
By the way, the study conducted on the Rotax regulator, and the
suggestion from my electrician buddy on the sense (C) wire may have led
to the recent Z-16 update.
Gilles Thesee
Grenoble, France
nuckollsr(at)cox.net Guest
Posted: Sun Sep 03, 2006 1:38 pm Post subject: Kilovac EV200 |
At 09:07 AM 9/3/2006 -0500, you wrote:
Hello all.
it has a low current draw. I saw some traffic earlier that there was a
noise problem with the Kilovac. Has anyone used the EV200
I've heard of several cases where folks have experienced
system interference from the EV200's duty cycle limited
coil controller. But before you pop for the $high$ contactor
to save a 0.7 amps of hold current, what were you planning
to use that 0.7 amps for?
