RG batteries with 35A generators
N6030X(at)DaveMorris.com
PostPosted: Sun Sep 03, 2006 10:58 am    Post subject: RG batteries with 35A generators Reply with quote
I have been doing a lot of reading lately, and somewhere I was
reading an article on RG batteries - now I cannot find it anywhere -
that said if your aircraft system is a generator instead of an
alternator, and if it is a 35A or less system, you should not use an
RG battery. I believe I remember the statement came from a Concorde
spokesperson.
Do you know anything about such a limitation?
Dave Morris
Mooney M20A
N6030X
nuckollsr(at)cox.net
PostPosted: Sun Sep 03, 2006 2:08 pm    Post subject: RG batteries with 35A generators Reply with quote
At 01:54 PM 9/3/2006 -0500, you wrote:
I have been doing a lot of reading lately, and somewhere I was reading an
article on RG batteries - now I cannot find it anywhere - that said if
your aircraft system is a generator instead of an alternator, and if it is
a 35A or less system, you should not use an RG battery. I believe I
remember the statement came from a Concorde spokesperson.
I cannot imagine why . . . I'll be talking with Skip
next week on other matters, I'll ask him if this is a
bit of wisdom from Concorde. But as far as I can deduce,
the technology of the engine driven power source is not
linked to the suitability of RG vs. any other battery.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
jm(at)10squaredcorp.com
PostPosted: Sun Sep 03, 2006 7:07 pm    Post subject: RG batteries with 35A generators Reply with quote
Data point - There is an SB for Stinsons that provides a list of
current batteries that should be used in the 108 series which have
generators. RG batteries are on the list, but not the extra capacity
versions with stated reason being the charging system cannot handle
the extra capacity.
On Sunday 03 September 2006 22:04, Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> <N6030X(at)DaveMorris.com>
>Bob,
> anywhere - that said if your aircraft system is a generator
> instead of an alternator, and if it is a 35A or less system, you
> should not use an RG battery. I believe I remember the statement
PostPosted: Tue Sep 05, 2006 3:54 am    Post subject: RG batteries with 35A generators Reply with quote
the extra capacity.
This is a WAG but I'd bet that the assertion developed from
a lack of understanding of a long standing "rule of thumb"
in battery/generator sizing.
While not explicit in the FARS, AC43-13 suggests that you
reserve 20% of generator/alternator capacity for the recharging
of a dead battery. Another notation in AC43-13 suggests that
a battery should be recharged in 60-90 minutes of flight. Both
of these numbers were pulled from where the sun don't shine.
Now, suppose you have a nice ol' C-140 with a 20A generator
and 24 AH battery. If you run that battery down, there's no
way that you can load the generator to 16A and recharge the
battery in 90 minutes with the 4A left over. Of course, that
airplane left the factory only with lights installed and
anyone who chose to launch with a dead battery could run
essentially 'dark' for an hour or so and get the battery back
up.
Suppose your airplane came from the factory with a 40A alternator
then according to one rule-of-thumb, we can fit the machine with
a 32A running load leaving 8A for charging. Hmmm . . . this means
we should only install a 12 a.h. battery so that 8A will get it
topped off in 90 minutes.
How about we upgrade to a 60A alternator. If the airplane left
the factory certified with 8A of headroom, logic suggests that
we could now carry a 52A running load and still meet the original
intent of recharging our 12 a.h. battery in 90 minutes. But no,
somebody will latch onto the 20% headroom statement and say
that you need to reserve 12A of headroom. Okay, now we can
recharge our tiny 12 a.h. battery in one hour. Good deal.
But suppose you want to upgrade to a 24 a.h. battery. Now
with 12A of headroom, we'll need 2 hours to recharge the 24 a.h.
battery. My bad.
Bottom line is that the best way to size an alternator/battery
combination is to know what your operating requirements are,
what the limitations are for getting the battery recharged under
the rare condition that you should decide to launch with a dead
battery. Then adjust operating conditions for the flight
meet the battery's needs in a whatever you decide is a reasonable
period of time while meeting minimum needs for operating equipment.
The prohibition for the higher capacity battery in the Stinson
is probably based on the 20% rule hat-dance and not upon any
understanding of performance by those who would prohibit or
individuals who can understand the new limitations for recharging
and adjust their operations accordingly.
It's the blind leading the deaf to follow rules by the ignorant
so that pilots are not required to understand. Grand recipe for
success, no? Sounds like groundwork for a juicy dark-n-stormy
night story.
RURUNY(at)aol.com
PostPosted: Tue Sep 05, 2006 8:44 pm    Post subject: RG batteries with 35A generators Reply with quote
The article is in the AOPA pilot magazine Aug or Sept issue, on aircraft batteries.
Bobs name is mentioned right in the introduction of the article and later near the end with a reference to the connection. I have a rotax 912 with a 20Amp generater, was setting up
for an RG battery from B&C, but took out the vented battery box I got with my kit and dusted it off wondering if this article is correct.
Brian
reading an article on RG batteries ....
Dave Morris
Mooney M20A
N6030X
PostPosted: Wed Sep 06, 2006 5:25 am    Post subject: RG batteries with 35A generators Reply with quote
Ah, yes, there it is in AOPA Pilot, September issue, page 136:
"The low internal resistance of RG batteries is the second reason
(more plate area is the first) they deliver more power and why they
accept a charge faster. Accepting more charge can cause small
generators to overheat. Skip Koss of Concorde Battery said any
airplane with a generator with an output of less than 50 amps should
use flooded-cell batteries for this reason."
Presumably that would apply only if the battery were needing a large
charge and Charge + Other Load was greater than the rating of the generator?
I have a 1960 Mooney M20A with a 35A generator, and I would think
that as long as I'm not taking off at night into the ice with a fully
discharged battery, needing my landing lights and pitot heat and a
heavy battery charge, this battery should be OK.
Dave Morris
N6030X
aircraft batteries.
Brian
Dave Morris
Mooney M20A
N6030X
PostPosted: Wed Sep 06, 2006 5:26 am    Post subject: RG batteries with 35A generators Reply with quote
batteries.
I don't subscribe to AOPA Pilot any more so I missed
the article. It would be interesting/useful to review
it. If someone could scan it and email it to me, I'd
appreciate it.
PostPosted: Wed Sep 06, 2006 6:39 am    Post subject: RG batteries with 35A generators Reply with quote
At 08:23 AM 9/6/2006 -0500, you wrote:
I'm mystified by this. Alternators are inherently current limited.
A 'cold' alternator will put out only a handful of amps over and above
the nameplate rating. Generators have no such inherent protection and
require current sensing and control feature as part of the regulator.
This is accomplished with the center of three relay-looking thingys
in . . .
http://www.aeroelectric.com/Pictures/Regulators/GenReg_2A.jpg
As a systems integrator looking over the specs of a generator/regulator
combination, I'd be disappointed if the data said something like, "Caution,
do not operate this system in the current limited mode for extended
periods of time." Obviously, current limiting is there to protect the
generator from it's willingness to self-destruct . . . but I'm mystified
as to why we should take special notice of current limited operations
to run systems aboard the airplane as opposed to charging a "too big"
battery.
If there are issues with respect to extended current limited operations
for generators, I'd expect these to be covered in the hot-day, max-load,
min-cooling tests customarily conducted at cert-time for the generator.
I've forwarded a copy of this note to Skip. I have no doubt that he
will come forward and enlighten us as to the underlying reasons for
Concorde's suggestion.
"The low internal resistance of RG batteries is the second reason (more
plate area is the first) they deliver more power and why they accept a
charge faster. Accepting more charge can cause small generators to
overheat. Skip Koss of Concorde Battery said any airplane with a
generator with an output of less than 50 amps should use flooded-cell
I have a 1960 Mooney M20A with a 35A generator, and I would think that as
long as I'm not taking off at night into the ice with a fully discharged
battery, needing my landing lights and pitot heat and a heavy battery
Dave Morris
N6030X
>batteries.
>Brian
chaztuna(at)adelphia.net
PostPosted: Wed Sep 06, 2006 8:06 am    Post subject: RG batteries with 35A generators Reply with quote
>batteries.
appreciate it.
Listers,
The relevent article is on page 133 of the September issue
Charlie Kuss
Kellym
PostPosted: Wed Sep 06, 2006 8:39 am    Post subject: RG batteries with 35A generators Reply with quote
Unfortunately, AOPA hasn't chosen to put that article on line, yet. It was
written by Steven Ells. It apparently gives www.aeroelectric.com and the
two battery companies web links. Title is "Charge It" under their Airframe
and Power Plant column.
> appreciate it.
> Bob . . .
Listers,
Charlie Kuss
Kelly McMullen
KCHD
brian-av(at)lloyd.com
PostPosted: Wed Sep 06, 2006 10:15 am    Post subject: RG batteries with 35A generators Reply with quote
in . . .
Well, here is some speculation, worth every penny you are paying for it.
The actual generating part of a generator is the armature, not the
stator. Less surface area from which to rid itself of heat. Also, the
generator has the commutator and its brushes. These are pretty lossy and
they don't have a good way to get rid of heat either, hence another
bottle neck. You are also likely to have less wire in the armature so
you don't have as much I*R loss to limit current.
I also suspect that even though alternators and generators have output
ratings, what they spec as "continuous duty" is probably not really
continuous duty. I suspect that the real, "you can run it this hard
until the cows come home," value is something smaller.
If you just knew the temperature rise of the various components you
could probably figure out what the real ratings are.
And his is an interesting but probably not-to-useful observation on
limits. The Chinese actually put multiple maximum limits on their
engines. It is like, "you can run it this hard for 5 minutes, this hard
for 10 minutes, this hard for 15 minutes, this hard for one hour, and
this hard for ever and ever." This makes a LOT of sense to me.
Brian Lloyd
PostPosted: Wed Sep 06, 2006 4:13 pm    Post subject: RG batteries with 35A generators Reply with quote
> in . . .
Understand . . . and agree
That's where I get crosswise in the road. In TC aviation, one
is generally expected to deliver to requirements and to fully
explain ratings and limits for products.
Yup, we do that too. Starter generators on some of our
products are qualified for continuous duty performance
(nameplate value) and then tested for short term overloads
under certain conditions . . . like a 30-minute requirement
for getting down from altitude with one generator dead and all
the de-ice equipment turned on.
I've been herding electrons in this venue for a long time
and Skip's assertions about battery sizing due to some failure
of the generator to meet nameplate performance continuously
is a first. Certification generally demands that you make
ALL limits known to both system integrators and ultimately
pilots . . . if the knowledge is necessary to prevent accidental
damage to hardware.
Now, it may well be that Skip reports some instances where
folks have put fat RG batteries into 1946 C-140's with
20A generators and the customer had "problems". I'm skeptical
that any detailed failure analysis was conducted and I'll
further confess to no knowledge of how generators were certified
in 1946. I do have a copy of CAR3 somewhere, I'll go dig that
out.
Not a really big deal for us alternator drivers but I would
like to understand more. Will let you know what I find out.
