Erich_Weaver(at)URSCorp.c Guest
Posted: Thu Aug 31, 2006 12:18 am Post subject: in-rush limiters |
I am considering installing in-rush limiters for my landing lights. Can
in-rush limiters be used effectively in conjunction with a wig-wag flasher?
My understanding is that the in-rush limiters do their job through their
odd property of providing decreasing resistance with increasing heat. That
would imply that they would need time to cool down before being able to do
their job the next time the power is turned on. With the flasher however,
the power is being turned on and off very quickly. On the other hand, the
bulb filament is probably not cooling off a lot either between flashes, so
maybe the in-rush limiters do not need to be effective when the wig-wag is
wigging and wagging.
Did I just answer my own question? If so, can someone recommend an
appropriate in-rush limiter for my 12V, 75W halogen lights
thanks
Erich Weaver
nuckollsr(at)cox.net Guest
Posted: Thu Aug 31, 2006 3:06 am Post subject: in-rush limiters |
At 05:06 PM 8/30/2006 -0700, you wrote:
The inrush limiters are, as you've already guessed,
slow to respond. They have to cool down for perhaps a minute
or more to be an effective inrush limiter for the next
turn-on event.
At the same time, filaments in lamps . . . especially the
halogens have a cooling time constant so long as to eliminate
the need for current limiting between flashes of a wig-wag system
I did some measurements on the bench a few years ago to
flash an automotive halogen headlamp bulb. The first turn-on
transient was what you would have expected . . . light up
transient from cold start was about a 10x running current.
However, sufficient heat was retained between flashes that
subsequent turn-on events were perhaps 1.2x running current.
Before halogens, the notion of installing inrush limiters
or adding some kind of keepwarm circuit had some appeal. With
the proliferation of the much more rugged halogens, the
old life-enhancing techniques are less useful. The next revision
of the 'Connection's lighting chapter will only mention these
techniques as ideas with historical significance but not
recommended for new design.
< with experiment. >
< --Lawrence M. Krauss >
FLYaDIVE(at)aol.com Guest
Posted: Thu Aug 31, 2006 4:03 am Post subject: in-rush limiters |
In a message dated 8/31/06 4:20:49 AM Eastern Daylight Time,
Erich_Weaver(at)URSCorp.com writes:
| Quote: | I am considering installing in-rush limiters for my landing lights. Can
thanks
Erich Weaver
Erich:
I am familiar with two types of inrush limiters. Neither of them work off of
heat (I would like to learn more about this heat type).
The simplest "limiter" you can build yourself. It is nothing more than a
coil. The coil can be made around either a dowel or a ferrite slug. The wire
size is chosen to handle the current of the load and the basic size is about
1/2" ID, 1" OD and 2" Long. The type of wire is SOLID single strand and is what
is known as Transformer Wire. After wrapping the wire coils TIGHT you can use
heat shrink tubing over them. If you want to get fancy and I would; before
you heat shrink tube them dip them in varnish. They should be located close to
the load device.
Oh! When choosing the wire size, do NOT go by the Mil-Spec wire size used in
wiring the plane. I would DOUBLE that wire size.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Thu Aug 31, 2006 4:50 am Post subject: in-rush limiters |
At 08:01 AM 8/31/2006 -0400, you wrote:
flasher?
heat. That
> thanks
> Erich Weaver
Erich:
See
http://www.gesensing.com/products/resources/datasheets/cl.pdf
| Quote: | The simplest "limiter" you can build yourself. It is nothing more than a
wire
is what
use
close to
the load device.
Adding inductance in series with a load does have an
effect of softening an inrush current event. However,
the time constant of an inductive circuit is (t=L/R)
and the inductance of a 1" x 2" wood core inductor
with 30T of wire on it is about 10 microhenries. Assuming
one finds a suitable hunk of ferrite and assuming also
a permeability of about 10, the inductance goes up to
about 100 microhenries. Cold closed loop resistance for
a 75 watt lamp circuit will be on the order of 0.3 ohms yielding
a max time constant on the order of .0001/0.3 or about 1/3
millisecond for a ferrite core device. A wood core device
yields about a 1/30 millisecond - rather short compared to the time
constant of a part like the KC003L NTC current limiter that
will be in the neighborhood of 10-100 milliseconds.
An inductive current limiter would be so fast compared to
the inrush time for a lamp filament as to offer little
assistance in mitigating the magnitude of inrush current.
| Quote: | Oh! When choosing the wire size, do NOT go by the Mil-Spec wire size used in
Don't understand why. The current ratings for choosing wire
size from charts like those found in AC43-13 or chapter
8 of the 'Connection are already de-rated for 10C temperature
rise. The 6A lamp cited in the original post would not
seriously warm an inductor wound with 22AWG (5A rated) wire.
Hopperdhh(at)aol.com Guest
Posted: Thu Aug 31, 2006 3:51 pm Post subject: in-rush limiters |
In a message dated 8/31/2006 8:53:53 A.M. Eastern Daylight Time, nuckollsr(at)cox.net writes:
| Quote: | Don't understand why. The current ratings for choosing wire
Bob,
When wire is wound in a transformer or choke, the density of the power loss is much greater than even in a bundle of wires. A typical design value is 500 to 1000 circular mils per amp. Solid number 22 wire is 25.3 mils in diameter and has about 643 circular mils. Therefore it is only rated for about 1 amp when wound in a multi layered coil. Operating a number 22 enamel wire at 5 amps continuously when it is tightly surrounded by more number 22 enamel wire also carrying 5 amps would cause it to overheat.
Dan Hopper
Retired electrical engineer and transformer nut.
Posted: Thu Aug 31, 2006 4:21 pm Post subject: in-rush limiters |
Bob,
Sorry, after rereading all the posts on this subject, I made a wrong assumption in writing the reply below. The reply still is correct, but probably not applicable.
Dan
In a message dated 8/31/2006 7:54:57 P.M. Eastern Daylight Time, Hopperdhh(at)aol.com writes:
| Quote: | In a message dated 8/31/2006 8:53:53 A.M. Eastern Daylight Time, nuckollsr(at)cox.net writes:
Bob,
Dan Hopper
.matronics.com/">http://forums.matronics.com
ronics.com/">http://wiki.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Fri Sep 01, 2006 3:58 am Post subject: in-rush limiters |
Hello Bob:
You have me smiling ...
Now how did I know you were going to question this part
Let me start off by asking a LOADED QUESTION:
What determines the current handling capabilities of a wire?
I should wait at this point for a responce, but concidering that the question
is also put the site's reading public ... I will guess at their answer and
maybe yours.
That being: The diameter, cross-sectional area of the wire.
Does that sound like the most given answer? And it is a logical answer. But
not the whole story. I did say it was a LOADED QUESTION.
So to unload the answer:
The Determining factor is the INSULATION, the thickness and type.
Here is why. You have to ask the questions: What fails? And How?
There are two failures. As the wire heats up, it heats up so much that it
MELTS the insulation. FAILURE ... This exposes the wire to do any combination
of events: Fire, short to ground - case - airframe or melt into and short to
another wire.
The other failure is crystalization of the wire from the heat. Usually
repeated heat and that leads to the wire failing in an OPEN. This is not the norm.
The norm is the insulation FAILING.
Now, most builders do use Mil-Spec wire and the Mil-Spec wire does have a
higher tempature rating and dialectric rating. So what determines the current
handling capabilities of a wire? INSULATION - Told ya it was Loaded!
Lets switch to the coil construction I mentioned. You said 30 Turns ... Only
30 Turns? Way Much More than 30 turns can fit on a form that has a 1/2" ID
and a 1" OD and 2" Long ... That gives you 1/4" of room to build up and about 1
1/4" length to fill. I haven't worked out the Henry's (inductance) of the
coil and quite honestly it does not matter. Too much engineering and not enough
practicality. I know the size will work. How do I know? A life of
experimentation! I have been getting my ass shocked since I was 11 years old
As the commercial says: Try it you'll like it. As we say here in NJ: Don't
worry about it!
O! For the size of the wire -- I would suggest 18 or 16 AWG enameled
(Transformer) wire. It should handle the current and both circuit heat and engine
heat. And even with this large size wire you should be able to get way more
than 30 turns.
Try it you'll like it. We are the EAA, Experiment!
Happy Toe Tingles.
Barry
"Chop'd Liver"
time."
Yamashiada
Posted: Fri Sep 01, 2006 4:06 am Post subject: in-rush limiters |
Bob,
Define "overheat". I'm aware of the transformer design
philosophies but were talking about a single layer solenoid
wound inductor. The amount of current a 22AWG wire can carry
without damaging its insulation is huge compared to the de-rating
we impose for bundling and/or voltage drops.
The 22AWG wire you see at:
http://www.aeroelectric.com/Pictures/Wire/20A_22AWG.jpg
had been carrying 20A for several minutes at the time this
picture was taken. The temperature as monitored by the
thermocouple in the photo was still well below operating
limits for the wire.
One of the most difficult concepts to illuminate with
respect to wires is that the recommended current RATINGS for
wires are chosen for a suite of inter-related effects not
the least of which is insulation type and ability of the
wire to reject heat - as installed. The values cited in the
wire bundle charts are not even close to being LIMITS beyond
which one may expect smoke, fire and otherwise unhappy times
in the cockpit.
For the case cited (single layer inductor) the charted
rating for 22AWG at 5A would be quite conservative even
for the 6+ amp landing light cited . . . assuming that
the inductive approach to inrush limiting was useful.
Posted: Fri Sep 01, 2006 7:31 am Post subject: in-rush limiters |
In a message dated 9/1/06 8:12:28 AM Eastern Daylight Time, nuckollsr(at)cox.net
writes:
| Quote: | Define "overheat". I'm aware of the transformer design
wound inductor.
Who said!
I said a form of 1/2" ID, 1" OD and 2" Long. That is no single layer ... Not
unless you are using 1/4" thick wire.
Barry
"Chop'd Liver"
time."
Yamashiada
Posted: Mon Sep 04, 2006 5:13 am Post subject: in-rush limiters |
At 07:56 AM 9/1/2006 -0400, you wrote:
used in
Hello Bob:
maybe yours.
| Quote: | That being: The diameter, cross-sectional area of the wire.
Sure. Cross section controls resistance, but says nothing
about ability to reject heat energy due to I(squared)R heating
combined heat transfer physics of the assembly.
| Quote: | Here is why. You have to ask the questions: What fails? And How?
combination
another wire.
Yup.
| Quote: | The other failure is crystalization of the wire from the heat. Usually
the norm.
Temperature rises that put COPPER at risk are so much
beyond temperatures that damage insulation that failure
of the conductor is exceedingly low on the list of concerns.
| Quote: | Now, most builders do use Mil-Spec wire and the Mil-Spec wire does have a
current
Yup, this is discussed in Chapter 8.
| Quote: | Lets switch to the coil construction I mentioned. You said 30 Turns ... Only
about 1
enough
Define "work". The goal is to add a SIGNIFICANT reduction in area under the
inrush current curve without degrading system performance. I guess I don't
know about "too much engineering" . . . it's been said that if the only tool
you have is a hammer, lots of things begin to look more and more like a
nail.
I'm an engineer and my first thoughts for working a problem DO focus on
the physics.
| Quote: | How do I know? A life of
old
worry about it!
Whether one chooses to worry or not to worry, the physics
doesn't change.
| Quote: | O! For the size of the wire -- I would suggest 18 or 16 AWG enameled
and engine
than 30 turns.
Inrush Limiting 101
Agreed. Taking your adjustments to my mis-perceptions of the
hypothesized single layer coil, let us assume as follows:
1/2" od core 2" long wound with 5 layers of #16AWG wire
(0.050" diameter) for a depth on the order of .25" for a total
diameter of 1". 050" wire will take 40T to cover 2" of
length for each layer so 5 layers is 200T total.
Goto:
http://www.captain.at/electronics/coils/
. . . and plug in 200T, 1" and .5" and 2" (be sure to select
units to "inches" and we get about 300 microhenries. Assuming a
ferrite core with permeability of 10, we might push this inductance up
to 3 millihenries.
Let us further consider 16AWG wire with a resistance of about 4 milliohms
per foot. The 200T will have an average circumference of .75 x 3.14 or
or 2.3 inches. 200T offers a total length of 460 inches or 38 feet
and a resistance of 150 milliohms.
| Quote: | Try it you'll like it. We are the EAA, Experiment!
Good idea. Went to the bench and measured the cold-resistance
of a 65W, halogen head lamp bulb and got 0.150 ohms. 12v applied
directly to the terminals of this lamp will produce an in-rush
current of 12.0 /0.15 = 80 Amps! Okay, lets wire it up with some
clip leads and a 12v battery and plot this puppy. Here we get
a curve like . . .
http://www.aeroelectric.com/Pictures/Curves/Exemplar_Incandescent_Lamp_Inrush.gif
Note that the peak inrush current was not 80 amps, but just
about 38 amps. Okay, this means that circuit cold-resistance
was 12/38 or 315 milliohms. Understandable. Wire used to hook
the system up combined with about 15 milliohms of battery
resistance produces a new, higher cold-resistance.
Adding your hypothesized inductor of 3 millihenries and
150 milliohms would raise the total circuit cold resistance to
315 + 150 = 460 milliohms. Adding the inductor would produce
a drop in in-rush current to about 26 amps if it exhibited
no inductive characteristics at all!
Going back to the curve we see that the time constant (measured
to 37% of the delta between peak (38A) and static (5A) or
(38-5)*.37 + 5 = 17A. The trace crosses 17A at about 15
milliseconds. At this same time, total loop resistance is on the
order of 600 milliohms without the hypothesized inductor.
I do not doubt that you observed reductions in in-rush
current as a byproduct of the actions you suggested.
It's easy to see here that adding the hypothesized inductor
will indeed cause a significant drop in the inrush current,
NOT because it's an inductor, but because it adds a
significant resistance to the circuit. The L/R time constant
for the added inductance is still much shorter than the
15 millisecond time constant demonstrated on the bench
so that the benefits of adding the inductance are small
at best.
Inrush Limiting 102
If inrush limiting is a really big thing for the designer,
there are thermal devices offered by a several manufacturers.
Here's one example:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/GE_Sensors/CL_limiters.pdf
In this case, we're adding to the cold-resistance of the
circuit by means of a style of thermistor . . . a temperature
sensitive resistor chosen for its NEGATIVE temperature
characteristics. The hotter it gets, the lower the resistance.
Take a look at p/n CL-30. It has a cold-resistance on the order
of 2.5 ohms. Adding this resistance in series with the
hypothetical .315 ohms cited above raises the cold-resistance
of the system to about 2.8 ohms. This will reduce the in-rush
current observed to 12 / 2.8 = 4.3 amps! Nice reduction indeed.
Now, as the thermistor is allowed to heat up, we see that
when loaded to 50% of rated load (It's a an 8A device and
our 55w lamp will load it to about 4A) its operating resistance
drops to about 140 milliohms. The power tossed off under
normal operating conditions is .14 x 4 = .56 volts x 4A =
2.25 Watts. This is about the same losses as for the
hypothesized inductor cited above but with a profound
effect on in-rush current.
Caveats: The CL-30 inrush limiter must be allowed to heat
up. One cannot clamp it down against a heat-sinking surface
for mechanical support lest you soak the heat energy out.
This can cause excessive dissipation internal to the device
and failure (been there, done that). On the other hand,
the critter is mounted on 18AWG solid copper leads and
not terribly resistant to breakage under vibration. On
the GP-180 program we wrapped the limiter in fiberglas
tubing before capturing it under an aluminum bracket.
In the final analysis, builder needs to decide what return
on investment is needed on an effort to mitigate in-rush.
The original goal was to increase lamp life. In the BH
era (before halogen) there was some benefit to lamp life
by considering some form of keep warm or inrush limiting.
Nowadays, I doubt that the return on investment is
positive. The bulbs are very long lived running "barefoot"
but they're still going to fail at some point in time -
in-rush limiting is not a reliability issue.
So unless your system is vulnerable to the effects of
a 40 amp, 20 millisecond transient (shame on you if it
is!), then there's no positive return on investment I
can perceived for adding special in-rush limiting
features to your landing light system.
