Static port question
rv10(at)sinkrate.com
PostPosted: Mon Sep 04, 2006 6:50 pm    Post subject: Static port question Reply with quote
Does anyone have any pictures of how they ran their static port tubing? Did you drill out holes for bushings in the ribs and what size did you use? I went with the Van’s pop-rivet kit because I never got around to researching anything else and the time has come to install.
Any pointers would be appreciated.
-Ben Westfall
#40579 Tailcone… still
billderou(at)yahoo.com
PostPosted: Tue Sep 05, 2006 11:12 am    Post subject: Static port question Reply with quote
Sorry no pictures - but -
I believe the only critical item is routing both ports up to the highest point on the nearest bulkhead and then tee off for a single run to the panel. This will drain the water back out the port and not into the instrumentation.
It would also be a good idea to perform a leak test and a flying test. Without a correct static port no instrumentation on your panel can be be accurate.
A simple flying test, derived from a very few observations, is to open your static line inside the cockpit during a flight. The altitude should increase 200 feet (or so). If it decreases then your static port is drawing a vacuum and your airspeeds will be incorrectly low and your altitudes high.
Bill DeRouchey
N939SB, Flying
billderou(at)yahoo.com (billderou(at)yahoo.com)
Ben Westfall <rv10(at)sinkrate.com> wrote:
[quote] Does anyone have any pictures of how they ran their static port tubing? Did you drill out holes for bushings in the ribs and what size did you use? I went with the Van’s pop-rivet kit because I never got around to researching anything else and the time has come to install. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
-Ben Westfall
jdalton77(at)comcast.net
PostPosted: Tue Sep 05, 2006 3:09 pm    Post subject: Static port question Reply with quote
Since we're on the static port question, and for those of you in the know, is there any significant reason, other than appearance, to go with the SafeAir vs. the Vans "pop rivet?" For those who have installed the Cleveland, how about that one. It sure looks nice and it's a lot cheaper than the SafeAir.
LarryRosen
PostPosted: Tue Sep 05, 2006 5:29 pm    Post subject: Static port question Reply with quote
*You can see how Deems the static tubing here
<http://www.deemsrv10.com/album/Sec%2035%20Access%20covers%20and%20Floor%20panels/index.html>
look at pictures DSC03048, 49 & 50.
Larry Rosen
#40356
N205EN (reserved)
<http>
Tim(at)MyRV10.com
PostPosted: Wed Sep 06, 2006 6:10 am    Post subject: Static port question Reply with quote
New news from me on Static ports.
Note: I know nothing about the SafeAir ones.
I have the original cleaveland ones. They are supposed to sit
out about .010" from the skin, and you're supposed to paint
them so they do stick out. (Just found that out yesterday).
I've been doing some test flights to check my airspeed accuracy,
and I found that I was about 6.5-7.5kts TAS low in cruise.
My static ports are absolutely flush, unpainted, and even with the
skin.
Last night, I did a test, I took some .050 material, and cut 2
small discs and drilled a small hole. I stuck those over the
static ports and taped them down with plain old scotch tape.
I test-flew it again and found that I am now only 4 kts off
in my TAS. So there is definitely some importance to the static
port design on an RV-10.
Yesterday I got on the way from Cleaveland a pair of their newer
static ports. I saw them on an RV-10 at Van's Homecoming. They
stick out a ways and are domed in shape. My guess is that these
will be much better than the original flat ones, based on the
quick and dirty test from last night.
My main point is, make sure you don't have flush static ports,
and that you have at least some part of them sticking out past
the skin. Again, I don't know what the SafeAir's are like,
and I've never really heard anyone provide any data on playing
around with their airspeed to see if it was accurate. If you have
the original flush ones or yours don't stick out, perhaps some
machining or filing of the backside of them where they hit the
skin would be in order. Just make sure they stick out a little.
Also, I encourage you builders to go out once you're flying
and actually gather and provide some data on your planes.
It's pretty rare that we see any true specs beyond the
minimum amount of info, but it's the only way to get good data.
In my case, I want the airspeed as accurate as possible. The
Chelton's calculate TAS, and from the heading offset from
ground track and TAS and Groundspeed, they calculate winds.
This can be pretty accurate, but imagine this:
Groundspeed is 160kts, TAS shows as 157kts, but the TAS is
reading 6kts low. So the system *thinks* you have a tail wind,
cruising over ground faster than through the air. In reality,
you have a light headwind. The lower the winds, and the
larger the error in airspeed, the more incorrect these
values can become. I'm going to keep playing and hopefully
get my error down to at most a couple KTS. I have 3 separate
instruments all reading the same airspeed, so it's not instrument
error.
jdalton77 wrote:
[quote] Since we're on the static port question, and for those of you in the
AV8ORJWC
PostPosted: Wed Sep 06, 2006 9:20 am    Post subject: Static port question Reply with quote
Here is a shot of the solution Dr. Carl Cadwell used on his Lancair IVP.
Sorry to the string and can folks. That was before he started such a
stir with his Epic LT which has led to the 51% Rule rewrite.
These static ports are critical in their exact location and design for
accurate pressure indication. Horseshoes and hand grenades are not
going to do it. You should see what is necessary for RSVM mapping.
John Cox
Do not Archive
 Filesize:  573.62 KB
 Viewed:  193 Time(s)
Tim(at)MyRV10.com
PostPosted: Wed Sep 06, 2006 10:17 am    Post subject: Static port question Reply with quote
Wow, that's the first time I've ever seen such a thing as that.
Very interesting. Maybe tonight or tomorrow I'll stick something
thick on the plane in front of the port like that just to see
what happens. I've never used a hand grenade, but M-80's and
firecrackers can be fun. Wink
Tim Olson - RV-10 N104CD - Flying 138 hrs
John Cox
Do not Archive
Rick S.
PostPosted: Wed Sep 06, 2006 11:44 am    Post subject: Static port question Reply with quote
That's not all that unusual, it seems a bit extreme but it does allow the air to breakup over the actual port. If I recall the oply problems folks have had with the Cleaveland ports (I'm using those) is making them flush with the skin. I think Mike piped in about the face of the port needs to be a thousandth or so above the actual aircraft skin otherwise the hole will act like a venturi and create a negative static pressure as the airflow passes over the static port.
Rick S.
40185
Rick S.
RV-10
40185
indigoonlatigo(at)msn.com
PostPosted: Wed Sep 06, 2006 12:42 pm    Post subject: Static port question Reply with quote
Not that I really know, but doesn't this venturi happen anyway and isn't
that why there is a port on both sides of the fuselage to cancel out the
negatives and positives of the other port?
My sailplane has a total of six in the tail boom located 120 degrees apart
and they are as flush as they can be.
John G.
Subject: RE: Static port question
Date: Wed, 6 Sep 2006 12:43:31 -0700 (GMT-07:00)
Rick S.
40185
Tdawson(at)avidyne.com
PostPosted: Wed Sep 06, 2006 1:03 pm    Post subject: Static port question Reply with quote
No kidding. I'm in Cali for a few days with the Air Force Reserve, and we had to plow out here at FL280 because, even though our RVSM modification has been done, the FAA is taking it's time with the paperwork! And plowing along at that altitude meant we had to make a fuel stop because we can't take off from our home base with a full load . . .
TDT
40025
From: owner-rv10-list-server(at)matronics.com on behalf of Tim Olson
Sent: Wed 9/6/2006 2:17 PM
Subject: Re: Static port question
John Cox
Do not Archive
Tim(at)MyRV10.com
PostPosted: Wed Sep 06, 2006 1:29 pm    Post subject: Static port question Reply with quote
I think it would depend on the plane and the location for how it
all works in the end. I'm not sure I agree with what Rick said
below though exactly the way he said it. It would seem to me
that if you had a venturi effect giving a little negative
pressure to the static system that you could end up with an
airspeed reading that would be HIGH, since the differential pressure
would be greater....not low. Mine is 6.5-7.5kts low with the
flush ports, and with them sticking out it's more like 4
so far. I'm hoping to figure out exactly what dynamics make it
perfect.
apart and they are as flush as they can be.
John G.
> From: Rick <ricksked(at)earthlink.net>
> Rick S.
> 40185
dlm46007(at)cox.net
PostPosted: Wed Sep 06, 2006 1:51 pm    Post subject: Static port question Reply with quote
I believe the static port each side plumbed together is intended to help
cancel out slips and skids which might cause higher or lower pressures than
normal. Now about the yaw damper.
dlm46007(at)cox.net
PostPosted: Wed Sep 06, 2006 1:54 pm    Post subject: Static port question Reply with quote
BTW the static ports on my certified Cardinal RG were each side of the
fuselage just forward of the doors and were a 40 hole in the skin.
completely flush.
dlm46007(at)cox.net
PostPosted: Wed Sep 06, 2006 2:00 pm    Post subject: Static port question Reply with quote
One other thought; My certified pitot tube on the Glastar has the static
ports in the pitot tube and flush to the side of the pitot tube . They are
four holes in a line on the bottom (parallel to the wing) and four holes on
a line on the top. probable reason to compensate for the angle of attack of
the wing at any given moment.
