l_klingmuller6(at)earthli Guest
Posted: Tue Sep 05, 2006 7:49 pm Post subject: Fuel flow pulsation dampener |
I have a J P fuel flow/fuel totalizer but are somewhat disappointed in the fuel flow readings. These fluctuate constantly within a +/- up to 1 gl/hr rate. Now my installation is not accordingly to the manufactures recommendation which calls for 6 inches of straight line on the inlet and outlet sides. I attached the sensor right to the gascolator out side since this seems to be a much sounder installation scheme.
Questions for those who have been there: Is it worthwhile (time, $) to install the Dralle dampener??
I do not recall seeing too many post on this subject on the list. Could not find anything in the achieves.
Lothar, 6A, 650 hrs
jeffpoint
Posted: Tue Sep 05, 2006 11:10 pm Post subject: Fuel flow pulsation dampener |
I had a similar, but not quite so high, oscilation on my flow readings.
I installed the dampener and it smoothed things out considerably. It's
not much $ or much work to install, and I recommend it.
Jeff Point
RV-6 flying
RV-8 preview plans
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
FLYaDIVE(at)aol.com Guest
Posted: Wed Sep 06, 2006 3:13 am Post subject: Fuel flow pulsation dampener |
In a message dated 9/6/06 2:44:29 AM Eastern Daylight Time,
l_klingmuller6(at)earthlink.net writes:
| Quote: | I have a J P fuel flow/fuel totalizer but are somewhat disappointed in the
not
| Quote: | find anything in the achieves.
Lothar, 6A, 650 hrs
Lothar:
I have installed 5 fuel flow totalizes, that extra length of straight run
depends on how you hooked up the fittings. Especially if you did a 90 Deg turn
in fuel flow before entering or leaving the transducer.
I have never used the Dralle Dampener, ONLY a smooth flow of fuel is
required. In one case where a 90 Deg turn was needed I had to fabricate a fitting
with oversized bores and a cut away internal turn. This either reduced or
eliminated internal restriction or caviation.
Questions:
The variance you are seeing, I guess you are seeing it during S&L flight?
How is the accuracy of the instrument on Gallons Remaining?
By playing with the 'k' factor you might take the gage from a borderline
reading into a more stabilized reading without affecting the Gallons Remaining
reading.
Barry
"Chop'd Liver"
