		John Brunke
				 Posted: Sat Sep 16, 2006 11:23 am    Post subject: IO-390 engine use |
				Dear listers,
  I am one of the many trying to figure out an engine  for my RV7.   I am interested in the IO-390 engine.   If you  have installed
  one of these on your airplane,  I would be  interested to hear if there are any installation problems compared to  the
  IO-360 series (spacing, cowling attachment, etc)  and also how your performance numbers look.
  Thanks in advance,
  John Brunke
  St. Charles, IL
  N767JB
  Tail almost completed.
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		sfarner(at)gmail.com Guest
				 Posted: Sat Sep 16, 2006 11:52 pm    Post subject: IO-390 engine use |
				John,
 I have an IO-390 in my -7A. I can't speak for performance numbers yet
 (although wait a week and I'll see), but my installation is pretty
 much done. I ran into three issues that were -390 specific.
 First was the alternator bracket. I have the 60amp internally regulted
 model from Van's and the supplied bracket didn't line up with the
 flywheel. It was a pretty easy fix, though. I just flipped it around
 and riveted on a new piece of angle for the alternator attach hole and
 sliced the othere one off. It looks like Van's is selling an
 alternator kit with a bracket that looks more like the one B&C sells
 now, so this might not be a problem anymore.
 The prop governor for the -390 is located up front, which is good and
 bad. Good in that apparently it is easier to run the control cable,
 but the bracket for holding it can be a bit of a challenge. Check out
 www.io-390.com. There are a couple of examples of how it can be done.
 The way I did it is on the contributions page.
 The biggest headache (relatively speaking) though was the baffling. It
 will take a little restructuring (at least it did for me) behind cyl
 #4 as the barrels are physically larger than on the -360. Also, with
 the prop gov up front, you'll have to do some chopping to get the
 baffles up there to fit.
 I didn't have any spacing or engine related cowling issues. I have
 plenty of clearance between the cowling and exhaust with the -360
 setup. All told, most of the issues were minor and should certainly be
 worth the extra 10-15hp IMHO. We'll see though.
 Scott
 www.scottfarner.com
 RV-7A - Prepping for inspection
 On 9/16/06, J. Brunke <jdoody727(at)comcast.net> wrote:
  Dear listers,
  Thanks in advance,
  John Brunke
  St. Charles, IL
  N767JB
  Tail almost
  completed.
