ctnyfl(at)yahoo.com Guest
Posted: Sat Sep 23, 2006 2:10 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
I am trying to choose between these three aircraft. It
is my first time building, and am leaning towards the
fast build versions. In looking at the specifications
on the company websites it seems the
RV is considerably less expensive, yet they all have
similar cabin size, baggage capacity and airspeed. The
Legacy and Glassiar do have more range due to higher
fuel capacity, however I really wouldn't want to go
more than 4 hours without stopping anyway.
So my question basically is, why does anyone choose
the Lancair or Glassair? The Legacy's ROC and
TO/Landing numbers are far worse. The Glassair has
very nice performance, especially considering the
lower hosepower, but not for a 65% premium over the
RV.
Am I missing anything? Building time and complexity
is a factor also, but I haven't found any reliable
information about these.
Financial stability and customer service factors seem
to favor Vans, though , again, that is difficult to
assess.
Derek
(no flames intended)
| Quote: | From the company websites:
RV7a Legacy FG Glassair SII FT
Fast Build Cost
$25,705 $38,500 $42,544
(no slow build avail.)
V Cruise (at) 8000ft.
205mph 220mph 210mph
(200hp, cs prop) (210mph, cs prop) (180mph,?cs prop
Payload(full fuel)
448lb 360lb 596lb
Range (at) 8000ft.
755sm 1450sm 1009sm
Solo ROC
2450fpm 1700fpm 2700fpm
Solo TO/Landing Roll
250/350ft 1500/900ft not lsited
Baggage Capacity
100lb/12 cu. ft. 90lb/ ? cu. ft. 100lb./12 cu.ft.
Cabin Width"/ Height"
43/ 42 43/44.5 42/ ? height
khorton01(at)rogers.com Guest
Posted: Sat Sep 23, 2006 2:56 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
On 23 Sep 2006, at 18:09, Derek Bohn wrote:
RV.
assess.
1. Look into the implications of the building material for each of
the aircraft and think about what type of construction you want.
Composite construction implies many hundreds of hours sanding and
filling. Some people are prone to developing allergies to some resins.
2. Visit with some local builders to learn more about how each type
of aircraft is built. The more local builders you can find, the
better, as they will be a useful resource when you have questions, or
need some assistance.
3. Go for a flight in each of the candidate aircraft so you can
decide whether you like the performance and handling.
4. Don't be surprised if everyone on the RV-List tells you to build
an RV. We're not exactly unbiased.
Why do some people choose the Lancair or Glasair? Some people are
attracted to the more curvy designs that composite construction
allows. Some people put a higher importance on cruise speed than
they do on the total performance package (i.e. stall speed, take off
and landing distances, climb performance, cruise performance). Some
people want to fly something unique, and RVs are becoming the new
Cessna - i.e. every airport seems to have a bunch of them.
Ottawa, Canada
http://www.kilohotel.com/rv8
jhstarn(at)verizon.net Guest
Posted: Sat Sep 23, 2006 3:30 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
We have several metal, rag & tube, wood based & composite aircraft in our
Chapter (EAA #768) at APV. From what I have heard over the years there is
two questions you must answer:
Do you really, really LOVE sanding, sanding & sanding some more ? ?.
Does fiberglass of any type....insulation etc. make you itch ? ?
HRII N561FS & awaiting the RV-12 KABONG (GBA & GWB)
Fiberglass is for Corvettes (driving my 7th one) RV cowls & tips.
Bruce(at)glasair.org Guest
Posted: Sat Sep 23, 2006 4:19 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Hee...Hee. I can still blow your doors off, inverted.
Bruce
www.glasair.org
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sat Sep 23, 2006 5:20 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
HRII has no doors... must've already blown off!
Re Glasair build times, check the glasair website, the builders log
pages list build times. Might have to subscribe for $45 a year to read
them though.
Osh 2006 Glasair dinner cancelled due lack of interest.
How many RV builders have lost their money due kit non delivery? Ans:
Zero
The Glasair is a fantastic aeroplane, no question. Why is it not as
successful as it should be? Read the body language.
Doug Gray
Flameproof suit is on.
Bruce
www.glasair.org
Posted: Sat Sep 23, 2006 5:43 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
OK, we do take longer to build than those pop rivet kits, but the end result
is worth it. Can you do an outside loop in your RV? The dinner was cancelled
for other reasons.
Bruce
www.glasair.org
Posted: Sat Sep 23, 2006 6:40 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Derek Bohn wrote:
RV.
assess.
Derek
As others have pointed out, mission & building material choice should be
driving factors, with support & business reputation/history
overshadowing even those items.
One thing you didn't list in your comparison is stall speed. I looked at
all three when I was younger & uneducated. As I got a bit older & better
educated, I got a bit more focused on analyzing 'best worst case'
scenarios. Back when I got serious about making a selection, an
engine-out, off-airport landing in any of the Lancairs would have had
about the same result as an off-airport landing in a twin (death). The
Glasairs were highly variable, depending on model. Supposedly, the old
G-1's had a tolerable landing speed if built light; I can't remember
about the 2, & the 3 was as bad as, or worse than, the Lancairs.
Just one more thing to consider as you make your selection.
(hoping I never hear that Van is selling to an investment group)
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Sep 23, 2006 7:58 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
In a message dated 09/23/2006 8:45:08 PM Central Daylight Time, Bruce(at)glasair.org writes:
| Quote: | OK, we do take longer to build than those pop rivet kits, but the end result
is worth it. |
>>> (sound of gauntlet hitting floor...)
Pop rivets? We don't need no STEENKING pop rivets!!!
C'mon, folks- try one of each on for size and build whatever floats yer boat.
Mark do not archive
_________________ From The PossumWorks... |
jeffpoint
Posted: Sat Sep 23, 2006 8:05 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Bruce Gray wrote:
| Quote: | Hee...Hee. I can still blow your doors off, inverted.
Bruce
There are three Glasair builders in my EAA chapter. After hanging
around with them for years, I've learned something about Glasairs.
Namely, how does every challange from a Glasair guy begin?...
"Oh yeah? Oh yeah? Well, when I get MY Glasair done, we'll race,
and then ....."
Jeff Point
RV-6 flying
RV-8 preview plans
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
Posted: Sat Sep 23, 2006 11:58 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Why are ALL the "plastic" airplanes only painted white ? ?. Is it that their
owners have not color style.......OR is it that painted anything else and
the sun turns them into crispy critters. All cracks & wrinkles....and then
they have to be stripped, sanded & filled & sanded & sanded & then painted
white again.
Why Yes Gummibear, I did reply direct, off-list regarding the "doors".
The HRII only has one "door" & that's for checking the oil level.
KABONG 8*) Do Not Archive
Subject: RE: RV7a v. Legacy FG v. Glassair SII FT
Bruce
www.glasair.org
Posted: Sun Sep 24, 2006 12:35 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
"Pop Rivet" kits ? ?, I thought we were talking about Van's RV's & Harmon
Rocket airplanes.
The -12 is reported to be "pulled rivets" but it's not available yet.
ALL RV's & Rockets are flush driven rivets kits. We used "Pop Rivets" only
in blind areas such as control tube ends where it's not possible to fit a
bucking bar into an 1 1/2" round tube & the end bearing in the same place at
the same time.
Outside loop ? ?, Nope, never tried and I've have not done a
"lavencheck"(spelling ?) either but I did survive as a passenger when the
RV-6A I was in went upside down when hitting fence at the end of the runway.
In any of the "plastic" airplanes we would have hit going a lot faster
(higher stall & landing speed) and with less inverted protection.
KABONG Do Not Archive
result is worth it. Can you do an outside loop in your RV? The dinner was
cancelled for other reasons.
Bruce
DanFM01(at)butter.toast.n Guest
Posted: Sun Sep 24, 2006 7:53 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Before you make your final decision, be sure you get a chance to sit in the
cockpit of your intended! If your body deviates very far from the standard
FAA adult male, you may find that you're not happy in many of the homebuilts
available today. It sounds trivial but comfort is important. Even better
get a ride in one.
LessDragProd(at)aol.com Guest
Vanremog(at)aol.com Guest
Posted: Sun Sep 24, 2006 8:13 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
In a message dated 9/24/2006 8:55:27 A.M. Pacific Daylight Time, DanFM01(at)butter.toast.net writes:
| Quote: | Before you make your final decision, be sure you get a chance to sit in the
get a ride in one.
Look carefully at insurance price and availability at your current skill level and then research what additional costs would be required to get that insurance down to what us RV drivers pay. You could find that fast glass is quite costly in other ways.
Do not archive.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 808hrs, Silicon Valley, CA)
bo124rs(at)hotmail.com Guest
Posted: Sun Sep 24, 2006 10:25 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
OK, might as well throw my two cents in. My first airplane was the plastic
variety. My second airplane is obviously the metal variety. What I
immediately liked about the metal variety was when you put two pieces
together you actually had a part and not two pieces drying over a day or
two. Example: rivet part A to part B, now rivet part AB to C, now rivet
part ABC...............follow my drift:-) Seriously, when you build a
plastic airplane it seems like you have to have multiple operations going on
to be able to keep working. You spend a vast amount of, what could be
building time, watching things dry. You end up grabbing a beer, in the mean
time, then losing your motivation to build that day.
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
Search—Your way, your world, right now!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
B25Flyer
Posted: Sun Sep 24, 2006 5:08 pm Post subject: Re: RV7a v. Legacy FG v. Glassair SII FT |
One deciding factor is that I am a buyer, not a builder, and I would never buy a plastic airplane that was not built in a controlled environment, i.e. a factory. I love flying plastic airplanes, but there is too much risk associated with buying one.
The numbers flying pretty well answers your question, build the RV.
Tailwinds,
Doug Rozendaal
bought 2- RV-4s and a F-1 EVO
jjessen
Posted: Mon Sep 25, 2006 11:04 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Correct and good advice. I absolutely loved the flight I had in the Glasair
Super II, but hated the seating and cramped feeling. I could not talk
myself past that. Some feel the same way about the Legacy and the RV-7 and
RV-9. However, one ride in the RV-10 and I found my comfort zone. Also
found the same comfort in the Sportsman, but that plane's mission is not
quite what I want. Soon, but not just yet. Comfort, 4-seats, good speed,
handles most airports with ease, etc etc.
John Jessen
RV-10 tailcone
go_lancair
Posted: Fri Oct 13, 2006 9:56 am Post subject: Re: RV7a v. Legacy FG v. Glassair SII FT |
Ok, no one can resist this kind of question. Each person makes a good point, but most of you guys have not done enough research. In the same search I visited each facility, talked to the representatives and by the end of AirVenture 2006 had flown in each aircraft. To say the least Glasiar has lost interest in their FT's III's etc to go for the cash cow Sportsman. They sent me manuals for the FT which were completely out of date and poorly bound. I'd be surprised if they even sold one sport unit this year. The sales curve on that product is somewhere down there with the Cessna 150. Van's has a good product albiet I found their staff to be generally rude and little interested in me as a customer. I bought the empannage kit for the RV-8 (because it was cheap), built it and gave it to the recylcing center after flying the Lancair. Speaking of flying the RV(7) it flew just fine as an aircraft but noisy, not especially comfortable and somewhere the wind was whistling through with annoying prevalence. At take off time it rattled and shuttered as we approached Vr. The Lancair was incredibly smooth, fast climbing, and without a whisper of air in the cabin. Climb out was an easy 110 knots at 2000 ft p/min. I was sold in an instant. Did I mention Lanciar is the only build with solid controls? Yes, that makes me feel safer and it gives the plane a solid feeling. Did I mention Lancair is the only plane in the EAA museum and the NYC modern museum of art? The plane is totally responsive like I would expect from any good airplane. And no, you don't need to cross the numbers at 110. I found the staff especially professional and welcoming (will provide references). BTW I don't know about the Glasair dinner, but the ramp guy at Airventure was pissed as the demo did not leave the field all week. I guess that tells you something. So I will start my baby Lancair in March 07' and get the sniffles from fiberglass dust, life sucks. I have plenty of cuts from the RV empennage too. No one gets away clean. One thing Van's doesn't promote is the fact that yes they have over 5,000 kits flying, but have sold over 100,000 kits (or pieces) to people that have no intention of finishing them. Lancair is no where near those numbers, but as far as I can tell has a strong family of high flyers. In the end it's your ass in the plane, your 100+k and it should be finished exactly as you like it. Happy flying.
jmsears(at)adelphia.net Guest
Posted: Fri Oct 13, 2006 11:12 am Post subject: RV7a v. Legacy FG v. Glassair SII FT |
Hmmm. Seems this person is on the wrong list. I've found the RV to be
to my liking, what I can afford, and a kit I'm not afraid to buy because the
company should be around for a long time. I've found the staff to be
helpful and usually cheerful to talk with. I'm building a third RV and have
found improvements, at very little or no cost increases, with each new
project. Granted, the Lancair is a mighty fine airplane; but, it's one that
most of us can ill afford. One of my criteria was that the airplane had to
be metal because I can't afford a hangar. I'm afraid a glass airplane would
melt in the sun, over time. My RV has been outside for most of its flying
life and is still holding its shape.
Jim in KY
jsflyrv(at)verizon.net Guest
Posted: Fri Oct 13, 2006 12:02 pm Post subject: RV7a v. Legacy FG v. Glassair SII FT |
go_lancair wrote:
| Quote: | Did I mention Lanciar is the only build with solid
solid feeling.
What dose that mean? Solid controls? Seems to me like my RV-6 has sokid
controls. And guess what it does not even shake or rattle at takeoff.
| Quote: | Did I mention Lancair is the only plane in the EAA
Ii am supposed to be impressed becaue their airplane is in the NYC
museum? LOL They have piss and crap in there also.
| Quote: | The plane is totally
Most military pilots I know like the RV-** feel because it feel more
fighter like and does aerobatics much beter than a Lancair ever could.
| Quote: | And no, you
No you don't but you have to be really cose to it. BTW I do have time in
all three aircraft you mentioned.
| Quote: | I found the staff especially
Van's also will provide you with information and help you find builders
in your area.
| Quote: | BTW I don't
???????????????just what does that tell you? Maybe everyone got sick at
the dinner. LOL
| Quote: | So I will start my baby Lancair in March 07' and
cuts from the RV ! empennage too. No one gets away clean. One thing
Van's doesn't! promote is the fact that yes they have over 5,000 kits flying, but have sold
finishing them.
I really doubt that anyone buys a kit with the intention of not
finishing them.
| Quote: | Lancair is no where near those numbers, but as far as
Yes Lancairs are pretty airplanes, yes they go fast. No they are nearly
as much fun to fly as a RV. They are like owning a cessna etc. you get
in and go from point A to point B not much fun in between. Any old
airplane will do that.
Jerry
