Dave Pelletier
Joined: 10 Jan 2006 Posts: 100 Location: Prescott, Arizona
Posted: Mon Sep 25, 2006 10:01 am Post subject: Sport Pilot |
Guys,
Been flying a lot and I'm real close to taking the Sport Pilot practical test - hopefully in the first week of Oct. A couple of questions: What is the best glide speed for a Kolb MkIII? What is Vx and Vy? (I'm around 50 to 55 for both of them and can't see hardly any difference in climb rate.) Will take any acvice you can give.
AzDave
_________________ AzDave |
Russ Kinne
Posted: Mon Sep 25, 2006 2:20 pm Post subject: Sport Pilot |
Az DaveYou guys should all know the V-speeds; it's pretty basic info. Do yourself a favor and look them up; less than a dozen.
Won't your SP examiner ask these? He should.
Vx is best angle-of-climb speed, Vy is best rate-of-climb. Important to know which to use if you want to climb over a ridge or simply gain altitude quickly.
Best-glide speed should be implanted IN CAPS, in your brain before you ever fly anywhere, anytime. If the engine quits you don't want to waste any time trying to remember it.
On Sep 25, 2006, at 2:00 PM, Dave & Eve Pelletier wrote:
[quote] Guys,
AzDave
Dave Pelletier
Posted: Mon Sep 25, 2006 3:26 pm Post subject: Sport Pilot |
Russ,
I agree. But where do I look them up? That's my question. I'm about the fifth owner of this plane and no paperwork came with it. In testing, best glide seems to be at 50 mph. I know what Vx and Vy are defined as. I don't know if there are any "official" numbers for the Kolb MkIII. Vx and Vy seem to be 50 and 55 mph, but that's what I get when I test it. There seems to be no difference in climb from one of these speeds to the other. Depending on conditions, I'm climbing at 200 to 300 fpm at both of these speeds. If I go to higher or lower speeds, the climb rate drops. I forgot to mention, I'm flying a MKIII with a 582.
AzDave
jsflan(at)valornet.com Guest
Posted: Mon Sep 25, 2006 5:28 pm Post subject: Sport Pilot |
AZDave,
Doubt their is much difference in, or too much concern about Vx and Vy where 50 to 55 can be an inch of stick or a slight gust, and I firmly believe the one to be concerned about in any of these is VNE. Anybody know what it is on the Mark III?
When I can get the problems half straightened out with the Mark III and can fly, I am getting 500 fpm and sometimes 700 fpm on takeoff when density altitude drops below 6K here in southern NM. It's beginning to drop with change in weather. Now if I just ordered the right parts ...
jsf
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Mon Sep 25, 2006 5:53 pm Post subject: Sport Pilot |
According to the paperwork that came from Phoenixville the VNE of the Mark III is 100MPH.
Mike
Oak Grove Missouri
Mark III Classic (one of the last of Old Kolb) - 0hrs
Suzuki G13B 1.3L - 0hrs
Started with Big Lar still behind...
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of john s. flannery
Sent: Monday, September 25, 2006 8:27 PM
Subject: Re: Sport Pilot
AZDave,
jsf
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Posted: Mon Sep 25, 2006 8:10 pm Post subject: Sport Pilot |
Thanks, And, do you believe that, with a Kolb Mark III of unknown age, use, and provenance, covered with very thin but clean fabric you can't define? And no built-in umbrella or falschirm? But, it has held together at 70, maybe plus to date. Think my old-tried-it-still-here side says " I shan't seek 100 mph." Nor shall I creep much past 70 indicated. Verily and foresooth as the boys say.
And next, the flaps extension speed and how many threads should be concealed in the flap rod. An A&P messed up the flap levers rebuild and had to back out to get flaps balanced with underside of wings at 0-degrees or lose 5 mph.
jsf
Dave Pelletier
Posted: Mon Sep 25, 2006 8:11 pm Post subject: Sport Pilot |
Dennis.Kirby(at)kirtland. Guest
Posted: Tue Sep 26, 2006 8:00 am Post subject: Sport Pilot |
<< What is the best glide speed for a Kolb MkIII? What is Vx
difference in climb rate.) AzDave >>
Hey, Arizona Dave -
For my bone-stock Mark-III, I declared 55 for Vy (best rate = best
glide), and 50 for Vx (best angle), when the FAA asked me. (As you
know, we are required to determine these speeds for our homebuilt
airplanes during our Phase-I flight testing period, and document them in
our aircraft log as part of FAA certification.)
And like you, I'm seeing hardly any difference in climb rate between
these two speeds. Good luck in finishing up your certification!
Dennis Kirby
912ul, "Magic Bike"
Cedar Crest, NM
(Now, if I could just get this silly 'spider' to work right ...
jindoguy(at)gmail.com Guest
Posted: Tue Sep 26, 2006 10:21 am Post subject: Sport Pilot |
John, I fly a 582 powered Mk 3. Last time I went out at dawn to do timed climbs, I got a flat result from 50 to 65 mph of right at 500 fpm. It was 80 degrees at 6:30 a.m., ah summer in Kansas.
I use 60 as the top of the white arc (flap speeds) 90 as the top of the green arc 90 to 99 as the yellow arc (max smooth air cruise) and 100 even as red line (VNE).
After I put the aileron balances on I took it out to 120 to check for flutter. I usually cruise at 80 to 85 IAS if I want to get somewhere and 70 to 75 when I'm just out cruising. Your results may differ as I have the prop (Warp Drive 66" 3 blade with straight blades) set to get 6500 max RPM.
Rick
On 9/25/06, john s. flannery <jsflan(at)valornet.com (jsflan(at)valornet.com)> wrote:[quote] Thanks, And, do you believe that, with a Kolb Mark III of unknown age, use, and provenance, covered with very thin but clean fabric you can't define? And no built-in umbrella or falschirm? But, it has held together at 70, maybe plus to date. Think my old-tried-it-still-here side says " I shan't seek 100 mph." Nor shall I creep much past 70 indicated. Verily and foresooth as the boys say.
jsf
Dave Pelletier
Posted: Tue Sep 26, 2006 12:28 pm Post subject: Sport Pilot |
Michael Sharp
Posted: Tue Sep 26, 2006 2:35 pm Post subject: Sport Pilot |
I believe what the Designer of the aircraft states.
Few of us know the true details of the spam can we rent either.
Since exceeding Vne speed should never be done.. Hence the “ne” part… I wouldn’t seek 100 either…
Mike
Sent: Monday, September 25, 2006 11:07 PM
Thanks, And, do you believe [b]that[/b], with a Kolb Mark III of unknown age, use, and provenance, covered with very thin but clean fabric you can't define? And no built-in umbrella or [i]falschirm[/i]? But, it has held together at 70, maybe plus to date. Think my old-tried-it-still-here side says " I shan't seek 100 mph." Nor shall I creep much past 70 indicated. Verily and foresooth as the boys say.
jsf
Mark Twain,
Roughing it' 1886
Mike |
Posted: Tue Sep 26, 2006 4:39 pm Post subject: Sport Pilot |
Not sure I agree, Mike.
As I remember, all the "spam cans" I've rented and owned have had gauges color-marked indicating never exceed speed, caution range , maximum structural cruising speed, normal operation range, maximum speed flaps extended, flap operation range and that very important one touched on earlier, maneuvering speed. They didn't get through annual without those markings, I recall. And the ubiquitous operating manuals published by the manufacturers even listed the variations in those speeds for floatplanes, skiplanes and of course, landplanes.
jsf
Michael Sharp
Posted: Tue Sep 26, 2006 5:34 pm Post subject: Sport Pilot |
John
My statement about the spam cans referred to your comment:
Quote: | "Thanks, And, do you believe [b]that[/b], with a Kolb Mark III of unknown age, use, and provenance, covered with very thin but clean fabric you can't define? And no built-in umbrella or [i]falschirm[/i]?"
The Spam cans I've rented and owned are covered with a very thin usually NOT clean AL sheet and you have no idea how the last pilot treated the aircraft or what "squawk's" he didn't report. And they can pass years worth of annuals with the problems not being addressed... Therefore few of us know the true details of the spam can we rent
Your statement seemed to hi-lite the condition of the aircraft and not the original issue of Airspeed... Sorry if that wasn't clear.
Also, what does a "flip book" have to do with Aircraft?? i.e. "falschirm" Or is it a term for something else??
Mike
"john s. flannery" <jsflan(at)valornet.com> wrote:
[quote] v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Not sure I agree, Mike.
jsf
Mark Twain,
Roughing it' 1886
Mike |
e.bayliss(at)blueyonder.c Guest
Posted: Wed Sep 27, 2006 11:32 am Post subject: Sport Pilot |
I have just got the specs as issued by the uk importer when my aircraft was imported (build completed in 1995) these give the the following
max flap speed (vf) speed 55mph
never exceed (vne ) 95mph
best rate of climb speed 45mph
recommended climb speed 52 mph
recommended approach speed 52mph
I have seen on my trawling through the net that sometimes the published manufacturers figures do not match the figures we have to keep to ( courtesy of the CAA) but hope this is some use to you anyway
Eddie (uk)
Ed in JXN
Posted: Wed Sep 27, 2006 10:25 pm Post subject: Sport Pilot |
Hi John,
Va (maneuvering speed) is not specified on an ASI. One of those one needs to remember, like Vx and Vy.
Ed in JXN
MkII/503
Thom Riddle
Posted: Thu Sep 28, 2006 4:37 am Post subject: Sport Pilot |
Ed in JXN
Ed,
You are correct and am glad you made note of it here. The top of green
arc and bottom of yellow arc is supposed to be Vno, which is structural
cruising speed, sometimes referred to as Normal Operating speed, hence
the Vno. For what its worth, Va is a calculated value which is equal to
the square root of the positive limit load (3.8 G in normal category
aircraft) multiplied by the stall speed at current weight and flap
configuration. Therefore it moves all over the map depending upon
current stall speed which is dependent upon weight and flap extension.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Thu Sep 28, 2006 9:41 am Post subject: Sport Pilot |
Right, good point.
1956 Cessna 180 Operating manual:
"Maneuvering Speed* . . . . 122 mph
(The maximum speed at which you can use abrupt control travel without exceeding the design load factor.) "
And if you don't heed this, you immediately become a test pilot, usually with no Falschirm (Parachute).
jsf
Do Not Archive.
Russ Kinne
Posted: Thu Sep 28, 2006 1:46 pm Post subject: Sport Pilot |
FWIW on a 170 it's 124do not archive
On Sep 28, 2006, at 1:41 PM, john s. flannery wrote:
[quote]Right, good point.
jsf
Do Not Archive.
[quote]---
planecrazzzy Guest
Posted: Sun Oct 01, 2006 2:05 pm Post subject: Re: Sport Pilot |
Hi Dave,
The place to find out your "V" speeds , is your own plane...
The only V-speed that does your plane any good is the Vne
All the other speeds have to be found with your own plane , you can get a "Ballpark" idea from other peoples V-speeds , but your planes weight is different from theirs....
The "formula" for finding "all" of your " V-speeds " ( eccept Vne ) is found in the
Amateur-built aircraft and ultralight Flight testing handbook -
AC NO: 90-89A
If you look at Chapter 5 " Expanding The Envelope "
it explains how to find "YOUR" V-speeds....
Just like finding your STALL speed , you got a Ballpark idea from other planes , but you needed to find out where YOUR plane stalled....
Some of these other numbers work off of your stall speed....
( something like 1.3 times the stall speed to get Vx ??? )
Hope this helps...
Gotta Fly...
Mike & "Jaz" in MN
planecrazzzy Guest
Posted: Sun Oct 01, 2006 2:07 pm Post subject: Re: Sport Pilot |
Hi Dave,
AC NO: 90-89A
Hope this helps...
Gotta Fly...
Mike & "Jaz" in MN
