kr2(at)earthlink.net Guest
Posted: Tue Sep 26, 2006 4:59 am Post subject: synthetic oils |
Thanks to you guys who asnwered my synthetic oil questions,I have found that using fully synthetic oil in my VW and using 100LL is not a good mix,my oil temp went from 180 to 250 and oil pressure went from 60 to 20, this is due to the lead in the fuel according to tech support so you guys were right on with your opinions,anyway back to using standard oil and all temps and pressures are back in the norm.
Note: an old A.P. likes using a qrt of marvel mystery oil at every oil change to acheive the same thing synthetics does,so I have tried this and flown off 2 more hrs and all is well....
Mark Thompson
kr2(at)earthlink.net (kr2(at)earthlink.net)
EarthLink Revolves Around You.
dave
Posted: Tue Sep 26, 2006 5:10 am Post subject: synthetic oils |
Mark ,
Do you know what Marvel Mystery oil really is ?
Seems to me i read somewhere it is Stoddard solvent and Lard.
Is that like varsol and animal fat ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Tue Sep 26, 2006 5:40 am Post subject: synthetic oils |
Absolutely!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
pwmac(at)sisna.com Guest
Posted: Tue Sep 26, 2006 5:48 am Post subject: synthetic oils |
Mark,
The "opinions" are not opinions, but the comments resulting from the
Rotax testing. Real world.
Paul
At 06:58 AM 9/26/2006, you wrote:
| Quote: | Thanks to you guys who asnwered my synthetic oil questions,I have
Mark Thompson
<mailto:kr2(at)earthlink.net>kr2(at)earthlink.net
<http://www.matronics.com/Navigator?Kitfox-List>http://www.matronics.com/Navigator?Kitfox-List
<http://www.matronics.com/contribution>http://www.matronics.com/contribution
roncarolnikko(at)hotmail. Guest
Posted: Tue Sep 26, 2006 6:37 am Post subject: synthetic oils |
Mark I am going to try switching to revmaster from redrive, since I have one
sitting in the garage. What size and pitch prop are you running? I'll
email off list Ron NB Ore
| Quote: | From: "Mark Thompson" <kr2(at)earthlink.net>
Subject: synthetic oils
Date: Tue, 26 Sep 2006 08:58:48 -0400
Mark Thompson
Search—Your way, your world, right now!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
spaghettiohead(at)hotmail Guest
Posted: Tue Sep 26, 2006 4:57 pm Post subject: synthetic oils |
Heya Mark - Just let me know before you changing oils and additives on me -
I'll let your buddy test-fly it first LoL
Andrew
Mark Thompson
Get today's hot entertainment gossip http://movies.msn.com/movies/hotgossip
Posted: Wed Sep 27, 2006 9:13 pm Post subject: synthetic oils |
Mark what size and pitch prop do you have? Ron NB Ore
Mark Thompson
Posted: Thu Sep 28, 2006 5:07 am Post subject: synthetic oils |
Hi Ron,I believe my prop is a 60x32 but I will double check this for you
today and reconfirm.I am using a Prince P Tip prop and have had good
performance however I would like to get my rpm up higher and therefore wish
I had of gone with a 30 pitch instead of 32.I am running direct drive off
the crank and have good climb and good cruise,.....climb:..100lb over gross
and getting 650 ft per min,cruise:..95-100 mph.I hope this helps,I will
email you back after I double check my prop size..
See ya Mark N61AC
| Quote: | [Original Message]
Date: 9/28/2006 1:17:45 AM
Subject: RE: synthetic oils
<roncarolnikko(at)hotmail.com>
20,
| Quote: | >this is due to the lead in the fuel according to tech support so you
guys
| Quote: | >were right on with your opinions,anyway back to using standard oil and
all
| Quote: | >temps and pressures are back in the norm.
and
| Quote: | >flown off 2 more hrs and all is well....
>Mark Thompson
