Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Sep 26, 2006 7:12 am Post subject: Rocker switches/Annunciator Lamps |
Howdy, Listers-
Can anyone recommend a source for the rectangular rocker switches I've seen on many aircraft (illuminated preferably with LEDs) with the legends engraved or printed on them? I'd also like to find some square lamps of similar appearance to use as annunciator lamps. What would be perfect would be lamps that are also illuminated pushbuttons (momentary) so they can be wired with a push-to-test feature.
No joy on usual suspects (ACS, Wicks, and WAY too much time googling, which is getting to be like "fishing for trout in a landfill"- even tried some street rod sites, etc.)
Mark Phillips do not archive
_________________ From The PossumWorks... |
Bruce(at)glasair.org Guest
wayne(at)engravers.net Guest
Posted: Tue Sep 26, 2006 8:16 am Post subject: Rocker switches/Annunciator Lamps |
Aircraft Engravers can engrave the rocker switch operators with what ever text you need. See http://engravers.net/aircraft/rocker_switches.htm
Wayne Cahoon
Aircraft Engravers
(860) 653-2780 ph
(860) 653-7324 fax
http://www.engravers.net/
J2j3h4(at)aol.com Guest
Posted: Tue Sep 26, 2006 12:13 pm Post subject: Rocker switches/Annunciator Lamps |
You may want to check out http://www.waytekwire.com/
They seem to make high quality automotive products. If you subscribe to their email, they will send you samples of neat stuff from time to time.
Jim Hasper
In a message dated 9/26/2006 10:15:25 A.M. Central Daylight Time, Fiveonepw(at)aol.com writes:
| Quote: | Howdy, Listers-
Dickk9(at)aol.com Guest
Posted: Tue Sep 26, 2006 12:32 pm Post subject: Rocker switches/Annunciator Lamps |
Jim try www.mouser.com
DOUGPFLYRV(at)aol.com Guest
Posted: Tue Sep 26, 2006 5:17 pm Post subject: Rocker switches/Annunciator Lamps |
Mark, this is where we bought our switches for the 7A & 10......very pleased.
Doug Preston
BHM
BAGSTERJR(at)msn.com Guest
Posted: Tue Sep 26, 2006 9:15 pm Post subject: Rocker switches/Annunciator Lamps |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Try the catalog at Pacific Coast Avionics. You can get them engraved with anything you want on them. I do think they are incandescent though, not LED
