bearup(at)ida.net Guest
Posted: Wed Sep 27, 2006 7:45 am Post subject: Small Text Trick - List Messages |
For those who have trouble reading the fine text in some messages, here is a simple trick that works great....
Left click your mouse pointer somewhere in the text to "make it active", hold down the "control" key on your keyboard and scroll with the little wheel on top of your mouse if you have one. The text size "magically" changes size!
I hope this helps.
Stan Bearup
kerrjohna(at)comcast.net Guest
Posted: Wed Sep 27, 2006 8:18 am Post subject: Small Text Trick - List Messages |
Stan, was not successful as described on the recieved messge. The steps you suggested changed the wrap properties which will be helpful for some of the messages I recieve. Is there another set of commands that will alter the font size? An interesting thing though, your suggestion does function as you describe on the reply message.
John Kerr
I hope this helps.
Stan Bearup
john(at)leptron.com Guest
Posted: Wed Sep 27, 2006 8:42 am Post subject: Small Text Trick - List Messages |
That is so cool, and I thought I was a computer jock.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Stan Bearup
Sent: Wednesday, September 27, 2006 9:44 AM
Subject: Small Text Trick - List Messages
I hope this helps.
Stan Bearup
Posted: Wed Sep 27, 2006 9:38 am Post subject: Small Text Trick - List Messages |
John,
I am not sure why it is not working for you. I use Outlook Express for my e-mail, and perhaps you use other another? I am not sure how this works with other packages. Sorry, but I don't have an answer or suggestion for you. Perhaps someone else can clue us in.
Thanks.
Stan
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Wed Sep 27, 2006 10:21 am Post subject: Small Text Trick - List Messages |
I think the reason the mouse trick doesn't work for everyone is it may
be a function of the mouse software for your brand of mouse or version.
Look at your Menu bar for the "View" menu and and there's usually a
increase or decease text size choice. Try pressing and holding the
"Ctrl" key and tapping the "+" key to increase text. The same trick
works to decrease text if you use the "-" (minus) key. (Don't worry
about the fact that the "+" normally requires the "Shift" key, it
doesn't in this case.) These key commands should work in many other
programs. Note that this only works when reading a message, not when you
are composing or writing. That's when you would use Font tools.
Rex
Colorado
kerrjohna(at)comcast.net wrote:
[quote] Stan, was not successful as described on the recieved messge. The
John Kerr
I hope this helps.
Stan Bearup
_________________ Rex
N740GP - M2/582
Colorado |
Posted: Wed Sep 27, 2006 11:53 am Post subject: Small Text Trick - List Messages |
It does not seem to work with explorer....
John,
Thanks.
Stan
Posted: Wed Sep 27, 2006 12:10 pm Post subject: Small Text Trick - List Messages |
Rex, Thanks for your attempt to help, but with my equipment the trick works when creating a response but not when working with recieved mail. The control + sign doesn't work in any mode.
John
[quote] --> Kitfox-List message posted by: Rex
are comp osing or writing. That's when you would use Font tools.
Rex
Colorado
> John Kerr
> From: "Stan Bearup"
> active", hold down the "cont rol" k ey on your keyboard and scroll
> I hope this helps.
> Stan Bearup
shericom(at)rogers.com Guest
Hay guys, If this sounds too much, get an Apple-just hold down the apple key and hit the + key, each time you do the text gets larger, or smaller with the- key.
Don Stevenson
John Oakley <john(at)leptron.com> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]--> That is so cool, and I thought I was a computer jock.
John Oakley
I hope this helps.
Stan Bearup
dave
Posted: Wed Sep 27, 2006 12:27 pm Post subject: Small Text Trick - List Messages |
I use outlook express and it works here.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Wed Sep 27, 2006 3:32 pm Post subject: Small Text Trick - List Messages |
John, are you sure you've highlighted/selected the text in question before
trying trick with the Ctrl key?
_________________ Mark Scott
Winston-Salem, NC |
Fox5flyer Guest
Posted: Wed Sep 27, 2006 4:03 pm Post subject: Small Text Trick - List Messages |
If using Outlook Express there's no need to highlight anything. Place the
cursor anywhere in the main preview page (not on a message), hold down the
Cntrl key, then roll the scroll key in or out to get the font size you want.
I'm old so I have mine nice and big!
Deke
Fox5flyer Guest
Posted: Wed Sep 27, 2006 4:58 pm Post subject: Small Text Trick - List Messages |
oops. Below where I said "scroll key" I should have written "scroll wheel"
on the mouse.
Deke
