debrun26(at)juno.com Guest
Posted: Wed Sep 27, 2006 10:21 pm Post subject: Kitfox5 needs cabin heat |
I just bought a KF-5 from Calif that has no cabin heat. The problem~~~ I'm in Alaska~~ Burr!!! Does anyone have plans to get cabin heat quick and cheep? The KF has an EA81 100hp subaru engine. Please help!!! Thanks, Layne
________________________________________________________________________
Visit http://www.juno.com/value to sign up today!
Fox5flyer Guest
Posted: Thu Sep 28, 2006 3:18 am Post subject: Kitfox5 needs cabin heat |
Layne, Earls Performance Parts sells a nice oil cooler with -8 AN male fittings that works nicely. Just add a couple fans to it. If you have the NSI engine then the radiator manifold has two (in/out) ports that are inside the cockpit down by the copilot rudder pedals. Just pull the plugs and add AN fittings, good quality hose, and warm up. I placed mine under the panel with separate fan switches so I could warm up either or both footwells.
Deke
shilocom(at)mcmsys.com Guest
Posted: Thu Sep 28, 2006 3:48 am Post subject: Kitfox5 needs cabin heat |
I think I still have a heater coil and fan combination that was removed off a 912. Bob U.
