nfivesl(at)yahoo.com Guest
Posted: Thu Sep 28, 2006 10:44 am Post subject: Running Engine - Wings Off (601XL) |
Hi guys:
I have a question for 601XL drivers. My engine is
ready for first fire and I'd like to start it in my
driveway before installing my wings.
Has anybody done this? Did it work out OK? I just
want to run my engine for about 20 minutes to break it
in before bringing it to the airport and installing
the wings.
No offense intended but please don't reply if you just
have an opinion. I've been inundated with opinions
from my local EAA buddies and I'm getting some pretty
mixed signals. I don't want to re-create that here on
the email list.
I'd like to hear from folks who have 601XL's and
running engines. Again, I don't want to start a
debate, just cold, hard facts from those who have been
there and done that (or chosen not to).
Thanks and keep up the great discussions,
Scott Laughlin
www.cooknwithgas.com
Inches from starting the engine for the first time.
601XL / Corvair
Posted: Thu Sep 28, 2006 11:13 am Post subject: Running Engine - Wings Off (601XL) |
As you probably know WW insists on a cooling duct for such a long ground
run. Or will you be using the nose bowl, shroud and baffling? And he really
really recommends the prelube with the dummy distributor and electric drill.
I would ensure my CHT, oil pressure and oil temp sensors and my EMS were
reading true before such a long run. Stick the oil temp sender in boiling
water, test the spark plug thermocouples with a source of heat in the
expected temperature range, etc.
Otherwise I don't see how what you are planning to do differs from running
your engine on a test stand (which many have done). What prop will you be
using?
-- Craig
daveaustin2(at)can.rogers Guest
Posted: Thu Sep 28, 2006 11:23 am Post subject: Running Engine - Wings Off (601XL) |
Scott,
I tied the tail of my 601 to a tree beside the driveway and ran it up
several times, with no wings on it. Far better to find any leaks, bugs,
overheating etc before it is away at the airport. Hope all goes well!
Dave Austin 601HDS - 912, Spitfire Mk VIII
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Thu Sep 28, 2006 1:17 pm Post subject: Running Engine - Wings Off (601XL) |
My engine is
Scott--
No opinion--just fact. I did my first runup on my 912 in my driveway.
No wings and no canopy. That last part was interesting. I tied the main
landing gear to a tree and choked all the wheels. My main interest was to
insure that I did not have any leaks with all the hoses used on the 912.
Make sure you have a couple of good fire extinguishes available--just in
case.
I used a 5 gallon plastic gas can with 3 gallons in it for my main fuel
source and insure that it was secured against being blown over.
Everythinng worked fine--no fire no leaks but it sure was windy without
the canopy. I've since repeated a similar runup but this time I tied the
plane to the trailer hitch on my truck. Worked fine.
George May
601XL 912s
The next generation of Search—say hello!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
rstone4(at)hot.rr.com Guest
Posted: Thu Sep 28, 2006 1:31 pm Post subject: Running Engine - Wings Off (601XL) |
Scott,
If you want to run your engine in your driveway, call the local police
and explain what you want to do and see if there is a city ordinance
prohibiting this. If not go ahead but be very careful especially when
neighborhood children are around. A spinning prop cannot be seen and all
neighbors are going to be interested in what you are doing.
Bob Stone, Harker Heights, Tx
ZodiacXL
dredmoody(at)cox.net Guest
Posted: Thu Sep 28, 2006 1:35 pm Post subject: Running Engine - Wings Off (601XL) |
Not exactly an apples and apples comparison but.....
When I broke in the Rotax 503 engine on my ultra-not-so-light, I tied it to the basketball goal post at the edge of my driveway. It had stood up to a direct hit from Hurricane Lili that shredded my shingles so I figured it was strong enough.
The break in was an hour long schedule of various rpm settings for specified lengths of time. There was a roofing crew working on the house across the street and when the hour was up and I shut it down, there was a collective "ThankGod!" from the roofers.
On the practical side, I had my wife reading out the rpm/time schedule via the intercom and a friend on guard duty watching to make sure no neighborhood kids got near the sawhorse and folding table barricades that we set up for a safety zone.
If you have enough security staff for safety and no local noise ordinances and the blessings of your neighbors, go for it. If any of those are missing, don't do it.
Ed Moody II
barcusc(at)comcast.net Guest
Posted: Thu Sep 28, 2006 2:36 pm Post subject: Running Engine - Wings Off (601XL) |
I plan on running in my engine in the very near future also, I have already
spoke to all of my neighbors about it. I assured them it would be in the
middle of the day and I would make sure I had plenty of help so their would
be no chance someone would get hurt. Several of them actually volunteered,
they have never seen an aircraft actually being built so they are very
interested. I do not plan on contacting the police because they are not
likely to show up without a complaint. I am waiting on a couple of parts
from William Wynne and a carburetor, then it will be time to turn the key on
my Corvair. I have had a lot of delays for various reasons but I am
beginning to see light at the end of the tunnel. Hopefully I will be flying
soon.
Clyde
601XL
Hendersonville, Tn
n801bh(at)netzero.com Guest
Posted: Thu Sep 28, 2006 2:41 pm Post subject: Running Engine - Wings Off (601XL) |
I ran my 801 for several hours on and off till I mounted the wings and transported it to the airport, All I did was to supply fuel to the lines at the wing root. I don't see a problem at all. In fact I am curious to the negative comments you have heard.
Ben Haas
N801BH
www.haaspowerair.com
-- N5SL <nfivesl(at)yahoo.com> wrote:
--> Zenith-List message posted by: N5SL <nfivesl(at)yahoo.com>
Hi guys:
the wings.
the email list.
Scott Laughlin
601XL / Corvair
____________================================================ Use the Matronics List Features Navigator;Archive Search & Download, 7-Day Browse,&n========================= - NEW MATRONICS WEB FORUMS -
================================================ - NEW MATRONICS LIST WIKI&nb========================= &nb Thank you for your generous supportbsp; -Matt Dralle, Li============================================ [quote][b]
Posted: Thu Sep 28, 2006 6:30 pm Post subject: Running Engine - Wings Off (601XL) |
Thanks for all the encouraging words and helpful
suggestions! All good advice and I plan to work hard
to make it happen in the next few days. I made a
scoop for catching air to cool the engine this
afternoon:
http://www.cooknwithgas.com/9_28_06_TempCowl2.JPG
I've got the 93 octane autofuel ready in a plastic gas
can and I need to temporarily rig up my fuel pump.
After that I need to connect a few wires and
everything will be ready.
Thanks again for the great advice from those that have
been there before me!
Scott Laughlin
Omaha, Nebraska
601XL/Corvair
Gig Giacona
Posted: Fri Sep 29, 2006 7:20 am Post subject: Re: Running Engine - Wings Off (601XL) |
One thing to add buddy, WE WANT VIDEO.
601XL Under Construction
Posted: Fri Sep 29, 2006 9:29 am Post subject: Running Engine - Wings Off (601XL) |
You got it Gig. "Video Camera" is one item on my punch list.
Scott Laughlin
