wcurtis(at)core.com Guest
Posted: Mon Oct 02, 2006 11:22 am Post subject: IO-540 Hose kit -possible group buy |
Gents, I’ve been out of commission for the last few weeks but I wanted to give you an update on the proposed group buy of the IO-540 hoses from aircrafthose.com. Basically the reply from aircrafthose.com was that because the 124J (Teflon hoses with integral fire) hoses were a specialty item, the price of $495 would be the best they could do even though I had 15 RV-10 builders ready to order. So to summarize $495 for the Teflon hoses with Integral Firesleeve and $432 Teflon with External Firesleeve. Ask for Ashley. Stratoflex Teflon with Integral Firesleeve Hoses for RV-10 ($495) 111-4 hose with a 300-4D fitting 21.50" Long (111001-4CR0214) (IO-540 Man Press.) 124-4J hose with a 524-4CR fitting 15.50" Long (124J001-4CR0154) (IO-540 Fuel Press.) 124-4J hose with a 524-4CR fitting 27.25" Long (124J001-4CR0272) (IO-540 Oil Press.) 124-6J hose with a 524-6CR fitting 14.00" Long (124J001-6CR0140) (IO-540 Fuel Supply) 124-6J hose with a 524-6CR fitting 25.50" Long (124J001-6CR0254) (IO-540 Fuel Line) 124-8J hose with a 524-8CR fitting 16.50" Long (124J001-8CR0164) (Oil cooler) 124-8J hose with a 524-8CR fitting 27.00" Long (124J001-8CR0270) (Oil cooler) Stratoflex Teflon with External Firesleeve Hoses for RV-10 ($432) 111-4 hose with a 300-4D fitting 21.50" Long (111001-4CR0214) (IO-540 Man Press.) 124-4 hose with a 524-4CR fitting 15.50" Long (124001-4CR0154) (IO-540 Fuel Press.) 124-4 hose with a 524-4CR fitting 27.25" Long (124001-4CR0272) (IO-540 Oil Press.) 124-6 hose with a 524-6CR fitting 14.00" Long (124001-6CR0140) (IO-540 Fuel Supply) 124-6 hose with a 524-6CR fitting 25.50" Long (124001-6CR0254) (IO-540 Fuel Line) 124-8 hose with a 524-8CR fitting 16.50" Long (124001-8CR0164) (Oil cooler) 124-8 hose with a 524-8CR fitting 27.00" Long (124001-8CR0270) (Oil cooler) William Curtis http://wcurtis.nerv10.com/ [quote][b]
apilot2(at)gmail.com Guest
Posted: Mon Oct 02, 2006 3:09 pm Post subject: IO-540 Hose kit -possible group buy |
That is a very good price. I paid around $615 for the same 7 hoses in
124J for my 200hp Mooney with IO360A1A in 2002.
On 10/2/06, W. Curtis <wcurtis(at)core.com> wrote:
| Quote: | Gents,
I've been out of commission for the last few weeks but I wanted to give you
Ashley.
Posted: Mon Oct 02, 2006 3:57 pm Post subject: IO-540 Hose kit -possible group buy |
Oh, if it wasn't clear in my message, for these prices it does not have to be a group buy. This is the price for an individual order when you order directly from them. > > > Gents, > > I’ve been out of commission for the last few weeks but I wanted to give you an update on the proposed group buy of the IO-540 hoses from aircrafthose.com. Basically the reply from aircrafthose.com was that because the 124J (Teflon hoses with integral fire) hoses were a specialty item, the price of $495 would be the best they could do even though I had 15 RV-10 builders ready to order. So to summarize $495 for the Teflon hoses with Integral Firesleeve and $432 Teflon with External Firesleeve. Ask for Ashley. > > Stratoflex Teflon with Integral Firesleeve Hoses for RV-10 ($495) > 111-4 hose with a 300-4D fitting 21.50" Long (111001-4CR0214) (IO-540 Man Press.) > 124-4J hose with a 524-4CR fitting 15.50" Long (124J001-4CR0154) (IO-540 Fuel Press.) > 124-4J hose with a 524-4CR fitting 27.25" Long (124J001-4CR0272) (IO-540 Oil Press.) > 124-6J hose with a 524-6CR fitting 14.00" Long (124J001-6CR0140) (IO-540 Fuel Supply) > 124-6J hose with a 524-6CR fitting 25.50" Long (124J001-6CR0254) (IO-540 Fuel Line) > 124-8J hose with a 524-8CR fitting 16.50" Long (124J001-8CR0164) (Oil cooler) > 124-8J hose with a 524-8CR fitting 27.00" Long (124J001-8CR0270) (Oil cooler) > > Stratoflex Teflon with External Firesleeve Hoses for RV-10 ($432) > 111-4 hose with a 300-4D fitting 21.50" Long (111001-4CR0214) (IO-540 Man Press.) > 124-4 hose with a 524-4CR fitting 15.50" Long (124001-4CR0154) (IO-540 Fuel Press.) > 124-4 hose with a 524-4CR fitting 27.25" Long (124001-4CR0272) (IO-540 Oil Press.) > 124-6 hose with a 524-6CR fitting 14.00" Long (124001-6CR0140) (IO-540 Fuel Supply) > 124-6 hose with a 524-6CR fitting 25.50" Long (124001-6CR0254) (IO-540 Fuel Line) > 124-8 hose with a 524-8CR fitting 16.50" Long (124001-8CR0164) (Oil cooler) > 124-8 hose with a 524-8CR fitting 27.00" Long (124001-8CR0270) (Oil cooler) > > William Curtis > http://wcurtis.nerv10.com/ William [quote][b]
cehoffman(at)bellsouth.ne Guest
Posted: Tue Oct 03, 2006 1:58 pm Post subject: IO-540 Hose kit -possible group buy |
Are the hoses the same for the O-540?
Cal
BPA(at)bpaengines.com Guest
Posted: Tue Oct 03, 2006 2:33 pm Post subject: IO-540 Hose kit -possible group buy |
Fuel line hoses MAY be a little different in length, but I think the rest of the hoses are the same. However, the hose from the servo to the flow divider won’t be used obviously on the O-540. I think that would be the 524-6CR
