jchang10
Posted: Wed Oct 04, 2006 8:55 am Post subject: Al fuel vent line cutting |
Another quickie question, is it kosher to use a home depot plumbing pipe cutter,
for cutting the Al tubes for the fuel vent lines for instance?
I guess I still need to buy something like the Parker Flaring Tool to flare the
ends?
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID 12FB&ReturnPage=/shop/
flyer.aspx?PageNo=1
Thanks again,
Jae
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Rick S.
Posted: Wed Oct 04, 2006 9:17 am Post subject: Al fuel vent line cutting |
Jae,
A good tubing cutter is worth the extra dollars spent. The small Rigid cutter has good bearing rollers and fine threads for better cutter feed. The cheaper models will not make as clean of a cut and tend to bevel the edge a bit too much. I picked mine up at Homedepot for about $25. I also have a Parker Rotoflare, hard to swallow price but works perfect. Be advised that if you lend it out you will need it the next day...Speaking of which Mr. Kaufmann...I need my Rotoflare back.
Make sure your using the 37 degree flaring tool for AN fittings.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Wed Oct 04, 2006 9:21 am Post subject: Re: Al fuel vent line cutting |
Any good quality tubing cutter will work. I suggest 2, a standard for using in the open and a close quarters cutter. Both availble at Home Depot and Lowes Aviation supply.
The parker tool is required for the flare, do noty use a auto parts flaring tool, as the flare angle is wrong.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Tim(at)MyRV10.com Guest
Posted: Wed Oct 04, 2006 10:45 am Post subject: Al fuel vent line cutting |
As for the cutting, I personally don't use any special
cutter...just a nice one from the hardware store.
But, I do run the tube end over the scotchbrite wheel
and then deburr the inside and outside slightly before
I use the rolo-flare tool. You really need to watch
for defects on that edge to prevent cracks when
flaring.
Funny you said that about loaning the RoloFlare tool.
I loaned mine out after I was flying, but sure as shinola
I soon found out I needed it and had to wait until I
could finally (a week or more later) get it back from
the guy. Now you know what I just buy tools instead of
borrow.
Rick wrote:
Jae,
Rotoflare back.
Rick S. 40185
jhstarn(at)verizon.net Guest
Posted: Wed Oct 04, 2006 12:12 pm Post subject: Al fuel vent line cutting |
Being an "old" plumber, A/C contractor I of course use ONLY Ridged cutters.
Three points: #1 make sure the rollers turn freely, #2: Cut slowly, by that
I mean go around more times with smaller additions to the tightening wheel.
#3: Make sure you have the correct cutting wheel. Yes, Virginia there are
different wheels for different materials. Examples: Copper, aluminum,
plastic (PVC, ABS etc), stainless steel. If you buy Harbor Freight you'll
get what they got, buy Ridged and you have a selection of cutter wheels to
choose from. GO SLOW...it will save you time in the long run. KABONG Do Not
Archive (GBA & GWB)
Posted: Wed Oct 04, 2006 12:31 pm Post subject: Al fuel vent line cutting |
I like to cut tubing with a fine toothed hack saw. The HD cutters (and
all the other 'wheel' cutters) will cold form the tubing, reducing the
inside diameter right at the cut. You have to clean that 'rim' out of
the tube before flaring. Lot more work than running a good file across
the saw-cut end.
Linn
Jae Chang wrote:
ends?
flyer.aspx?PageNo=1
Thanks again,
Jae
jchang10
Posted: Wed Oct 04, 2006 1:56 pm Post subject: Al fuel vent line cutting |
Thanks for the feedback. I am glad not to have to buy another tool!
jae
