gz(at)comgz.com Guest
Posted: Thu Oct 12, 2006 12:51 am Post subject: Two shunts on one amperometer |
Hi all,
As I'm not decided where is the best place to connect the shunt of my
amperometer, I was considering to use two shunts: one on the
alternator output and the other checking all the electrical loads
(except starter).
The two shunts would go to the gauge through a a S700-2-3 ON-ON double pole
switch.
The advantage would be to be able to check alt output and, in case of alt
failure, check the battery depletion rate.
Any comment or criticism from the experts?
Gianni Zuliani
Tel/Fax +41 91 9710850
Mobile +41 79 3373439
Long-Ez >> Stag-Ez >> Stag-EzR
http://www.comgz.com/tristar.htm
nuckollsr(at)cox.net Guest
Posted: Thu Oct 12, 2006 3:29 am Post subject: Two shunts on one amperometer |
At 10:44 AM 10/12/2006 +0200, you wrote:
Hi all,
(except starter).
switch.
Measuring the battery depletion rate for alternator-out
operations by installing n ammeter suggests that you're
not planning to control battery life by a combination of
(1) choosing a battery capacity sufficient to operate
KNOWN loads for what ever duration you choose as part
of your design for alternator-out operations (Plan-B).
(2) maintaining the battery with either periodic
capacity tests or preventative maintenance by replacement
so that conditions under Plan-B are satisfied.
The point is that KNOWING battery loads "right now"
is useless if you don't know what the battery's capacity
is. Further, planning to do any kind of mathematical
gymnastics in flight so as to pick-and-choose from
electrical items you're not going to turn off is
poor design . . . it distracts from your duties
as pilot while you fuss with systems analysis
under duress while in flight.
The most useful instrument under battery-only
operations is the voltmeter, not the ammeter . . .
and then only to tell you whether your planning
and maintenance efforts have paid off. If the
battery drops below 11.0 volts sooner than you've
predicted, then you know you've blown the design
goal for achieving and maintaining a PREDICABLE
level of performance under battery-only operations.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
klehman(at)albedo.net Guest
Posted: Thu Oct 12, 2006 4:14 am Post subject: Two shunts on one amperometer |
Seems like extra work and expense for little gain Gianni.
With a shunt on the alternator you can quickly become familiar with the
current draw of various items. After an alternator failure it is very
unlikely that you can manage the current draw for any specific battery
life unless you have a brand new, tested, fully charged battery at room
temperature, and have a second pilot to fly the plane while you fiddle
with it. Just turn everything off that is not needed and revert to a
previous plan that probably entails use of an E-bus.
Ken L.
Gianni Zuliani wrote:
Hi all,
(except starter).
switch.
Gianni Zuliani
