matthew(at)n523rv.com Guest
Posted: Thu Oct 12, 2006 9:24 am Post subject: Closing gap in Flap Actuator to Fuselage interface |
Funny.. was just thinking about this very thing now that we are approaching winter and I'm attempting to draft proof the RV. (Wife complained last winter the heat doesn't work good enough.)
My thought was to take some baffle material as you suggested, cut out an appropriate sized hole with a slit somewhere to slip it over the flap tube and then just glue it or pop rivet it in place. Let me know if you come up with a better idea.
Matthew
N523RV :: RV-9A :: 129 hours
http://www.n523rv.com
Albert Gardner
Posted: Thu Oct 12, 2006 10:03 am Post subject: Closing gap in Flap Actuator to Fuselage interface |
Most RV’s don’t do anything. Several have made wing root fairings that extend over the flap and cover the hole from above-mainly for appearance. Fortunately, not much slush here in Yuma, even in the dead of winter. Haven’t had any sand get in though.
Albert Gardner
Yuma, AZ
RV-9A N872RV
_________________ RV-9A N872RV
RV-10 N991RV |
rv9jim(at)juno.com Guest
Posted: Thu Oct 12, 2006 10:41 am Post subject: Closing gap in Flap Actuator to Fuselage interface |
Matt,
I haven't gotten that far but a "bellows" arrangement would be
better in making up for vertical and horizontal motion of the flap
actuator rod as it goes thru the fuselage. Even if it was not a bellows
a long very thin rubber sleeve would work for air infiltration. I got
something like that from "Orvendorfer" (sp) for controlling air coming
into the fuselage below the floor and under your seat. A nylon fabric
that will not let air thru works. You get the idea.
Jim
RV9-A FWF
FLYaDIVE(at)aol.com Guest
Posted: Thu Oct 12, 2006 5:12 pm Post subject: Closing gap in Flap Actuator to Fuselage interface |
In a message dated 10/12/06 1:27:11 PM Eastern Daylight Time,
matthew(at)n523rv.com writes:
| Quote: | My thought was to take some baffle material as you suggested, cut out an
with a better idea.
Matthew
Matt:
After spending two years asking question, plugging holes and making diverters
in the hopes of curing the CO problem that many if not al lRV-6's have ... I
have finally come up with a solution. It works and it is cheep, yet I have
not solved the UGLY part of the problem.
The solution was two curved down exhaust pipes from a local auto shop. They
are held on with 'U' Clamps and a hunk of safety wire. The only good thing I
can say about this is there is ZERO CO in the cabin.
I have tried making bellow boots to cover the flap rod, adding a rear facing
scupper scoop back by the tail, all sorts of diverters in different positions
and sizes, extra cowl flaps, the hole punched exhaust tips, lowering and
raising the exhaust pipes. NOTHING worked. Except the two curved down exhaust
pipes. They give the sound of POWER and maybe even a bit of real useful power
also.
Barry
"Chop'd Liver"
RV-6
shempdowling(at)earthlink Guest
Posted: Thu Oct 19, 2006 6:50 am Post subject: Closing gap in Flap Actuator to Fuselage interface |
I remember seeing someone using one of those foam paint brushes to seal
that gap. Havent tried it yet though.
Shemp
FLYaDIVE(at)aol.com wrote:
> with a better idea.
> Matthew
Matt:
also.
Barry
"Chop'd Liver"
RV-6
