sarg314(at)comcast.net Guest
Posted: Fri Oct 13, 2006 6:41 pm Post subject: catto 3-blade prop |
I just received a Catto 3 blade for my IO360. I just had to post a note
to say it is a beautiful piece of work. If it flies half as good as it
looks, I'll have a real hot rod on my hands. It will be a few months
before I can start testing, though. I'll be sure to post some results
when I have them.
Craig Catto has a big backlog right now, but he's a good guy to do
business with.
Tom sargent
RV-6A.
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Fri Oct 13, 2006 7:04 pm Post subject: catto 3-blade prop |
Just curious Tom.....How long did it take for you get your prop after you
ordered it??
And yes, it does fly as good as it looks. I have an O320 with a 3 blade
Catto. Just took some dual with a CFI that has RV time and he commented on
how smooth the engine runs.
You're gonna love that prop.
Jeff Orear
RV6A N782P
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
Posted: Fri Oct 13, 2006 7:30 pm Post subject: catto 3-blade prop |
Jeff:
I placed the order in mid March. He specified a June delivery,
which I did not believe at the time. I expected to get it in august or
september. I actually got it on Oct. 12. Craig knew that my project
wasn't stopped waiting for the prop. He gives priority to those who are
in more immediate need. I can't really argue with that. I got mine in
plenty of time. He seems to know his stuff and was always happy to talk
to me when I called up. I can't wait to see what this thing will really do.
Jeff Orear wrote:
[quote] Just curious Tom.....How long did it take for you get your prop after
you ordered it??
blade Catto. Just took some dual with a CFI that has RV time and he
commented on how smooth the engine runs.
Jeff Orear
rv6(at)cox.net Guest
Posted: Fri Oct 13, 2006 7:39 pm Post subject: catto 3-blade prop |
I have a 3-blade Catto on my 0-320(150hp) RV6. Lot smoother than the
Sensenich I did have on it and climbs much better, but the Sensenich is
about 10 mph faster. I can only turn the Catto a little over 2500 RPM in
level flight and 2475 RPM on the Sensenich.
| Quote: | From inside the cockpit, the Catto has a unique sound and is quieter.
I like the Catto though for a good all-around prop.
Jerry Calvert
Edmond Ok
RV6 296JC
jeffpoint
Posted: Fri Oct 13, 2006 10:42 pm Post subject: catto 3-blade prop |
Ditto on all the good things everyone else said about the Catto.
Jerry, if you only turn 2500 then your prop is grossly over pitched (or
your tach is off.)
Jeff Point
RV-6 flying
RV-8 tail kit ordered
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
davwol(at)svtv.com Guest
Posted: Sat Oct 14, 2006 4:46 am Post subject: catto 3-blade prop |
Ordered my Catto prop in Jan, said I did not need it till June. Craig is a
nice guy he said June would be fine. Still have not gotton it.
Dave Wolles
finishing 9A
paul.folbrecht(at)veribox Guest
Posted: Sat Oct 14, 2006 6:27 am Post subject: catto 3-blade prop |
I ordered mine well over a year ago ($700 deposit). Every couple
months I inquire about it, he asks "do you _need_ it now?", I reply,
honestly, "no", and am asked to wait a bit longer.
This has been Ok with me. I believe if I had an engine and did need
that prop, he'd get it to me.
Craig is a nice guy he said June would be fine. Still have not
gotton it.
Dave Wolles
finishing 9A
cgreimer(at)mts.net Guest
Posted: Sun Oct 15, 2006 7:57 am Post subject: catto 3-blade prop |
| Quote: | I just received a Catto 3 blade for my IO360. I just had to post a note
I admit the 3 blade looks very cool but I went with the Catto 2 blade for
(theoretically at least) slightly higher cruise efficiency. I have been
running the Catto on my O-320 powered RV-6 for about 12 hours now and I'm
very pleased with the performance. I asked for mine to be pitched for 2700
RPM at 8000', 75% power and it is bang-on. Solo climb is 1500+ fpm, which is
better than any of the Sensenich numbers I have seen.
It came painted to match my aircraft colours and looks superb.I have only
run it in the rain for a hour or so, but the finish shows zero signs of
wear.
It does seem to run slightly rougher than my old wood prop. I'll reserve
judgement until I have it dynamically balanced like the old one.
Delivery was promised to be 2 months; it actually took five. It was worth
the wait but I'm going to keep my old prop as a spare. If I ever ding this
Catto I have no intention of being grounded for 5 months!
Curt
RV-6 C-GACR
470 hours
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Oct 15, 2006 10:26 am Post subject: catto 3-blade prop |
In a message dated 10/13/2006 10:40:54 PM Central Daylight Time, rv6(at)cox.net writes:
| Quote: | | I have a 3-blade Catto on my 0-320(150hp) RV6. |
Howdy Jerry- what did he pitch your prop at? He labelled mine a 66x66 and it will turn 2850 down low (2500')- I usually see about 2200 static and on initial climb-out.
Mark E3D 150hp -6A, 360 hours
http://websites.expercraft.com/n51pw/
_________________ From The PossumWorks... |
Posted: Sun Oct 15, 2006 10:45 am Post subject: catto 3-blade prop |
I bought this Catto prop from another RV'er who had it on a 160hp 0-320 and it is pitched at 64x70.
Jerry
Posted: Sun Oct 15, 2006 12:12 pm Post subject: catto 3-blade prop |
Curt:
I think you have the right prop. Craig recommends the 3-blade for
the O-360 because it has better harmonics than the 2-blade - on the
O-360. On the O-320 the 2-blade's harmonics are just fine. If I had an
O-320, I'd have gotten the 2-blade also. (It's significantly cheaper!)
Curt Reimer wrote:
| Quote: | I admit the 3 blade looks very cool but I went with the Catto 2 blade
for (theoretically at least) slightly higher cruise efficiency. I have
been running the Catto on my O-320 powered RV-6 for about 12 hours now
and I'm very pleased with the performance. I asked for mine to be
pitched for 2700 RPM at 8000', 75% power and it is bang-on. Solo climb
is 1500+ fpm, which is better than any of the Sensenich numbers I have
seen.
matthew(at)n523rv.com Guest
Posted: Wed Oct 18, 2006 3:28 pm Post subject: catto 3-blade prop |
I too have a 3-blade Catto prop (66x72) on my O-320 RV-9A. It is a nice looking prop and very smooth. With 145 hours on it, I have a lot of nicks on the back side of the prop showing white through. I noticed on Mel Asberry's RV-6 with the Catto prop has no nicks at all and he flies off a gravel runway. I'm not sure if he has changed paints or just put it on too thin for my prop but I'll have to repaint the back side at some point.
As for delivery, this is where Craig really drops the ball. He is a helluva nice guy but has no sense at all about scheduling. I ordered on January 19, 20'05 and was told about 16 weeks. It was December 17th before the prop arrived and I had to bug the hell out of him to get it. I did give him a grace period in the summer since I knew he was busy.
I'd still recommend Craig's props but always tell people to order a year in advance!
Matthew
RV-9A :: N523RV
www.n523rv.com
