Michel
Posted: Fri Oct 13, 2006 9:55 am Post subject: Ethanol and fiberglass tanks - once again |
Greetings, Kitfoxers,
We have been talking about the danger of ethanol in our fiberglass
tanks for a long time. I have already mentionned what I read on the
Jabiru Engine list but ... here it is again:
A gentleman called Bill Evans writes:
"The airlines, military and others use thiokol based rubber sealants to
seal their tanks. Brand names is PRC. You want PRC1422 A2. It's now
manufactured by ProSeal. Normally lasts for generations."
To what I reply, as previously said on this list: "Yes, but it can't be
sloshed in our existing tanks."
To what Bill answers:
"So the PRC is not thin but is pourable. The solvent is Methyl Ethyl
Ketone. (You can only do this outdoors and with the wind to your back.)
MEK is somewhat soluble in PRC. You use a paint mixer in an electric
drill, and thin the PRC with MEK until the sealant will flow
sufficiently to get 100% coverage. Slosh would be too optimistic. You
could also spray it in with a new garden sprayer, but that would also
"seal" the future of your garden sprayer. I have done this... Sprayed
PRC."
Guys, my brain is as empty as a barrel of beer after being raided by a
bunch of Norwegian soccer hooligans! Make up your mind on the above
information and let me know what the jury has decided. Can we do it?
Thanks in advance,
Michel
dosmythe(at)cox.net Guest
Posted: Fri Oct 13, 2006 11:01 am Post subject: Ethanol and fiberglass tanks - once again |
| Quote: | > To what I reply, as previously said on this list: "Yes, but it can't be
> sloshed in our existing tanks.">>
| Quote: | > sufficiently to get 100% coverage. Slosh would be too optimistic.
Michel,
In my opinion, no. This discussion on sloshing tanks has made a couple
turns over the years. One was sloshing to fill pin holes in tanks. The
other turn is now talking about sloshing to protect the fiberglass from
ethanol. To me, that is two entirely different situations.
Sloshing to fill pin holes in tanks is possible and has been done by
several with pretty good results. If the slosh happens to get into the pin
hole the leak is fixed.
Now, here is my opinion on sloshing to "protect" the basic fiberglass
material. If you slosh and just happen to miss a spot then the ethanol is
going to gain access to the fiberglass and all is lost (assuming ethanol
will eat the fiberglass) If down the road, the slosh develops a hairline
crack then the ethanol will wick into the fiberglass (all is lost again).
I used an "example" once about having tanks made from Styrofoam and
relying on a slosh to protect the base material from gasoline. Someone came
back and said, "Gasoline will eat Styrofoam". Well, I knew that and that
is why I used Styrofoam as an "EXAMPLE". In my opinion, you can no more
protect Styrofoam than you can fiberglass with a slosh material. The tanks
are just too big, too flat, too wide and too thin to cover all the
internals (plus, the baffles).
Sloshing to fill pinholes is possible but sloshing to protect the basic
fiberglass material is another question.
Lets assume (ANOTHER WAY OUT EXAMPLE) that ethanol was proved to eat
fiberglass tanks up is under 6 months. Who would trust their lives with a
slosh or thin coat of paint like material applied to the insides.
IMHO,
Don Smythe
Michel
Posted: Fri Oct 13, 2006 1:34 pm Post subject: Ethanol and fiberglass tanks - once again |
On Oct 13, 2006, at 9:00 PM, Don Smythe wrote:
| Quote: | In my opinion, no.
Thank you, Don. Your explanation makes perfect sense to me. I mentioned
once again PRC because Bill, on the Jabiru list, couldn't understand
what the problem was with ethanol. My initial posting there was to say,
in an answer to: is the Jabiru fuel pump and carby gaskets ethanol
resistant?;
- "I can always replace hoses and gaskets but what about fiberglass
tanks?"
Michel
torgemor(at)online.no Guest
Posted: Fri Oct 13, 2006 2:17 pm Post subject: Ethanol and fiberglass tanks - once again |
Hi Michel,
You're pointing to a very important problem -soon to come...
First, the PRC 1422(a..B) Pro-Seal, is a well known fuel sealing compound
much used for both jet fuel and 100LL. This compound is mostly used as a
sealer between joints in wet tanks, but also as a sealer for fasteners
etc. inside fuel tanks. The PRC 1422 "never" harden, but will keep it's
good elastomeric qualities for a very long time.. The problem is that
it's a stuff with "high" viscosity, I.E. cant be sprayed.
Here's a link to the "famous" site :
http://www.bergdahl.com/Aerocat.htm
Now to the problem, the ethanol fuel E85.
I do not think this kind of fuel can be used for "today’s" aviation.
Firstly, we'll need to find out more accurate information about various
Resins vs. Ethanol and "fiberglass degrade".
So, what kind of resin is used in YOUR Kitfox??? My Kitfox model II (93
mod) is made with West System Resin (the fuel tanks).
Well, here's a little info, copied from the "official" guide, issued by:
The U.S. Department of Energy
Some materials are known to
become degraded by contact with
fuel ethanol blends having high
alcohol concentrations. Zinc, brass,
lead, and aluminum are some of
these sensitive metals. Terne (leadtin-
alloy)-plated steel, which is commonly
used for gasoline fuel tanks,
and lead-based solder are also
incompatible with fuel ethanol.
Avoid using these metals because of
the possibility of vehicle failure or
fuel contamination. Unplated steel,
stainless steel, black iron, and bronze have shown acceptable
resistance to corrosion by ethanol.
Nonmetallic materials that degrade when in contact
with fuel ethanol include natural rubber, polyurethane,
cork gasket material, leather, polyester-bonded fiberglass
laminate, polyvinyl chloride (PVC), polyamides, and
methyl-methacrylate plastics. Nonmetallic materials
that have been successfully used with fuel ethanol
include Buna-N, Neoprene rubber, polyethylene, nylon,
polypropylene, nitrile, Viton, and Teflon.
You see, aluminum and brass (our carburetor), is among the material that
won't stand the Ethanol...
Ok., here's the link to the full document about Ethanol fuel (E85):
http://www.agriculture.state.ia.us/pdfs/ethguide.pdf
This is recommended reading for every one of us.
Torgeir.
A happy model II flier, with Avid wing , sure you too Michel...
On Fri, 13 Oct 2006 19:55:00 +0200, Michel Verheughe <michel(at)online.no>
wrote:
We have been talking about the danger of ethanol in our fiberglass tanks
for a long time. I have already mentionned what I read on the Jabiru
PRC."
Thanks in advance,
Michel
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
lcfitt(at)sbcglobal.net Guest
Posted: Fri Oct 13, 2006 4:46 pm Post subject: Ethanol and fiberglass tanks - once again |
I did a little research on the alcohol issue. The majority of the talk is in
the boating world where the fiberglass tanks have deteriated in some cases
and more seriously, in some cases residues, possibly from the affected tanks
have resulted in engine damage.
The good news seems to indicate that the affected fiberglass tanks were made
prior to the mid 1980s - at least for those that have models built after
that date.
For those interested do a Google search on Ethanol and Fiberglass fuel
tanks.
It is comforting that we Kitfox folks are not the only ones concerned about
this issue and there is info out there.
Lowell
Float Flyr
Posted: Fri Oct 13, 2006 5:19 pm Post subject: Ethanol and fiberglass tanks - once again |
The fun starts ... I think there are a few cars on the road today with
composite or plastic gas tanks. I wonder what will happen to them when they
have been exposed to EA85 for a year or so.
I still think ethanol is not the answer.... It is just a corrosive
diversion to get a few more votes.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sat Oct 14, 2006 3:07 am Post subject: Ethanol and fiberglass tanks - once again |
Lowell,
I did a lot of web searching and found the same stuff you're talking
about. I still have one little concern. Back when I was working in the
Submarine world, they had a program called "SUBSAFE". This program required
all critical parts in a Submarine to be certified with a long trail of
paperwork You could just about track back a piece of metal to the mine
where the ore came from. We discussed many times that the old Skystar had
used a couple different tank manufactures and I never did get a good warm
feeling as to exactly what materials were used and when. Bottom line, my
1995 tanks have no serial numbers or paperwork to tell me what they are made
of.. Who knows, they might be made of the pre 85 boat stuff.
Don Smythe
brodg(at)texas.net Guest
Posted: Sat Oct 14, 2006 4:33 am Post subject: Ethanol and fiberglass tanks - once again |
Noel, you might note that GM and Ford have intentionally designed some of
their vehicles to run on E85.
Don't know what their fuel tanks are made from, but I'd bet that the car
companies are WAY ahead of most aeroplane builders with regards to this
issue.
Brian
smokey_bear_40220(at)yaho Guest
Posted: Sat Oct 14, 2006 6:00 am Post subject: Ethanol and fiberglass tanks - once again |
Consumers' Reports ran a test on it and they don't
seem to back it either. Haven't finished reading it
yet, but they don't see a gain.
Some say it takes more energy to make than it puts
out.
But I would trade Gov subsidies there instead of
tobacco and maybe we don't need to pay farmers not to
work too? Even then, there isn't as much to meet the
demand for fuel as some think.
Brazil went to it big time, then backed off. Still
available everywhere though. I don't know what they
use for tanks and my Portuguese is too poor to ask.
I'll see if I can fine someone who speaks English
there and can find out tank materials.
Kurt S.
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | The fun starts ... I think there are a few cars on
the road today with
just a corrosive diversion to get a few more votes.
Noel
Posted: Sat Oct 14, 2006 6:02 am Post subject: Ethanol and fiberglass tanks - once again |
Don, I agree whole heartedly. My tanks are an interesting story. I took
delivery of the kit in March 1993. Of course the first things were the
fuselage controlls and fitting all the fuselate attachments: rudder,
horizontal stab and elevator. Then I got around to doing the wings, left
wing first. That was December 2003. The wing tank was a right wing tank
with a left wing tank top, in other words the washout twist was backward. I
sent the tank back for an exchange - so I now had wing tanks from two
production era's nine months apart.
It was the early tank that began leaking at 500 hours, in Idaho, after four
days soaking in AV Gas. There is definitely, in my mind, differences in
wing batches. Whether the difference has to do with materials or
workmanship, I have no idea.
I am running an experiment with vinyl ester resin and Kreem as a fuel
barrior. I tried to boost the alcohol content of the local fuel - 6% - as
we speak, but couldn't get the ethanol to mix, so I am using 100% ethanol in
one series and vinyl ester in the other. I have the samples under a bell
jar so I can simulate altitude changes that would cause a solid structure to
degass at lower air pressures - if there are pin holes in the tanks there is
air in them. The samples are held under the liquids in test tubes so I can
observe degassing bubbles if present. I take them up to a simulated 14,000
ft daily and observe for any degassing bubbles. So far nothing in any of
the samples, but they only have been submerged since Oct 1.
I will rerport to the list the first sign of failure.
Lowell
Float Flyr
Don:
As far as I've heard there is only one composite filler that is used on fuel
tanks. That is a Vinyl-ester filler. I've been told the vinyl is part
Epoxy and part Urethane. They say that's the filler that the new in ground
tanks at service stations is made of.
I still find it hard to believe that any organic compound will be impervious
to Ethanol. That stuff even feasts on Aluminium. Until these tanks have
been in the ground for a number of years filled with EA85 I will be leery of
it's use. It's not that I think the tanks will come apart in flight, just
that the goop from the fillers might gum up the works in my engine. Also
there is the issue of carburettor icing. I know some who say that use of
MOGAS doesn't increase the chance of icing. Unfortunately I've heard
different from high time commercial pilots. Ethanol won't help that
situation.
There is a fellow on the Avid list who has been flying an R582 for years
with the 10% fuel in California with no problems. He says he premixed all
his gas. That may be the answer to protecting the gas tanks. If the
ethanol has more affinity to oil in the fuel than it has to the organic
compounds in the fillers it may leave the fillers alone. The oil in that
case is acting like a sacrificial anode of a sort. That fellow has recently
installed a Jab ( wish I had one) but he is still adding a little top lube
to his gas. It seems to be working. Time will tell all.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Oct 14, 2006 6:43 am Post subject: Ethanol and fiberglass tanks - once again |
You must be kidding!
Car manufacturers ahead? Sure they're grounded!
If the tank on a Pontiac or a focus disintegrates or cracks in three years
you have the car pulled into the dealership where they will install a new
one. Very cheap because of the mass production and the "that will do"
engineering not to mention the ease of dropping an auto tank and shoving a
new one in. Think you can change out a wing tank in your fox in an hour??
You can't be doing that with planes. For one point your inspection schedule
should include inspecting the tank at regular intervals. Many planes have
that on the list of scheduled maintenance. That way the tank will have to
be changed out before any problems start. The other thing is cars are not
restricted to operation by weight. That is half the engineering that goes
into designing a plane. Can you imagine trying to get off the ground in
your 'Fox complete with air conditioning, power controls, electric seats,
warmers on everything you may have to touch, EGR pumps, and catalytic
converters and let's not forget the little light to tell you your gas cap
isn't tight.
I think it is more than possible to design a quickly changeable wing tank
for any small plane. When it is designed/built there is no doubt I'd
consider installing a couple.... Just in case they contaminate my present
alcohol free fuel supply.
The real answer in both the auto and aviation worlds is in the design of new
engines that don't burn gasoline. Imagine a hybrid aeroplane engine that
ran on coal oil and sunlight!
Car manufacturers are ahead of car manufacturers a few years ago. When I
was a kid an old clunker was maybe five years old. Now they are just
getting out of warranty. My '90 Miata looks as good as the day it came out
of the factory, back in 89, with the exception of a couple of paint chips.
Yes there have been advancements in the auto world. Multi port EFI on a
common high pressure rail is one. ABS is another but everyone in this part
of the world will have problems with their ABS sooner or later. We get so
much snow and there is so much salt put on out roads the poor ABS
connections really don't stand a chance of lasting too long. Hmmmmmmm ABS
on the kitfox????
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Oct 14, 2006 7:02 am Post subject: Ethanol and fiberglass tanks - once again |
Can you also introduce bending and flexing and vibration that you get in a
flying airplane into your experiment?
Noel
[quote] --
Kitfox III-A
Posted: Sat Oct 14, 2006 7:16 am Post subject: Ethanol and fiberglass tanks - once again |
Noel, you seem to be impervious to reason and common sense.
If car gas tanks were failing in use, I'd have a very hard time navigating
any roadway around here due to all the cars that stopped running.
Also, the car companies are not doing "that will do" engineering. Hello?
Have you noticed that the car warranty periods have been getting longer and
more inclusive than in decades past? Do you think that these companies
would be in business very long if they were changing out gas tanks, engines,
fuel lines, etc. on every car every couple of years?
Think man.
BTW, glass is an organic compound and you can find GALLONS of ethanol in
every liquor store around the world.
Brian
Posted: Sat Oct 14, 2006 7:28 am Post subject: Ethanol and fiberglass tanks - once again |
| Quote: | Don:
fuel
Yep, done read that a thousand times on the internet concerning gas station
fuel tanks but, back to my one concern, somebody prove to me that my tanks
are made of Vinyl-ester. No serial number, no traceable paperwork, nothing
from the factory, no quality assurance sign off, just rumors.
Don Smythe
Guy Buchanan
Posted: Sat Oct 14, 2006 8:32 am Post subject: Ethanol and fiberglass tanks - once again |
At 08:16 AM 10/14/2006, you wrote:
| Quote: | BTW, glass is an organic compound and you can find GALLONS of ethanol in
every liquor store around the world. |
Brian, it's not the glass, but the resin matrix that has a problem with solvents.
I found some definitive information in Professional Boatbuilder. There is a standard, UL1316, to which all underground fiberglass fuel storage tanks in the US are currently being built. (And apparently all underground fuel storage tanks in the US are currently being built of fiberglass.) If the resin you're using, (probably a vinyl-ester based product,) meets UL 1316 you can be reasonably sure it will work with all current auto fuels, and any future fuel anyone might stick in an existing underground storage tank. (Hear that John?) You may be able to use this to obtain a satisfactory interior coating. (I did a quick Google and found nothing.) Interplastic Corporation was mentioned as a possible source for resin. They may also be able to formulate an interior coating, though I'm sure it will be in bulk quantities.
Guy Buchanan
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
rjdaugh
Posted: Sat Oct 14, 2006 8:41 am Post subject: Ethanol and fiberglass tanks - once again |
By a chemist's definition, glass in inorganic.
But you can buy booze in plastic bottles, and it has ethanol in it.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Michel
Posted: Sat Oct 14, 2006 11:07 am Post subject: Ethanol and fiberglass tanks - once again |
Hei Torgeir,
On Oct 14, 2006, at 12:17 AM, Torgeir Mortensen wrote:
| Quote: | So, what kind of resin is used in YOUR Kitfox??? My Kitfox model II
(93 mod) is made with West System Resin (the fuel tanks).
Interesting. I wonder why they decided for that epoxy resin that was
developed mainly for the maritime industry and the "cold molding"
method of bounding thin wood ply with the resin.
Anyway, we have asked West System if their epoxy was ethanol resistant
and they answered "No, but we are working on it."
Michel
Posted: Sat Oct 14, 2006 2:54 pm Post subject: Ethanol and fiberglass tanks - once again |
Sorry, the proof reader is out of town.
I am using 100% ethanol in one series and vinyl ester in the other. Should
read 100% ethanol and 6% mogas in the other.
Lowell
Posted: Sat Oct 14, 2006 2:56 pm Post subject: Ethanol and fiberglass tanks - once again |
No Noel, that's where you come in.
Lowell
