		sfdarton(at)yahoo.com Guest
				 Posted: Wed Jan 25, 2006 9:37 am    Post subject: Sealant gun |
				Sean or any sealant gun users,
 Did you use a ribbon nozzle to apply Pro seal to
 mating parts (instead of spreading it on via a
 Popsicle stick). What were the tank parts that you
 applied Pro seal to with your sealant gun, when and
 how did you use it? Did you mix and then load an empty
 cartridge from a quart kit or use the "semkit" tubes
 or a combination of the above?
 Steve 40212
  <schmoboy(at)cox.net>
  +1 on having a Semco sealant gun.  I went to
  aircraft spruce and
  purchased tubes and nozzles.  That way I could buy
  the quart kit, mix it up myself and place in the
  Semco for easy application.  You can usually find a
  good used Semco on Ebay.
  -Sean #40303
  http://rv10.stephensville.com
  John W. Cox wrote:
  > --> <johnwcox(at)pacificnw.com>
  > The Semkits allow quick automated mixing without
  any mess but cost
  > more than purchasing product in two parts and
  mixing manually.
  > Nothing can make it quicker, better flow control
  and less messy than a
  > pneumatic sealant gun.  The 6 oz canister is the
  most popular size.
  > I will patiently wait for anyone with an argument
  to use a baggy.
  > John
		schmoboy(at)cox.net Guest
				 Posted: Wed Jan 25, 2006 10:10 am    Post subject: Sealant gun |
				Here's the parts from Aircraft Spruce for the cartridges...
 09-00758 PLUNGER FOR PRO SEAL CARTRIDGE $.67
 09-00759 PRO SEAL CARTRIDGE ONLY 2-1/2 $.66
 EA4180 NOZZLE FOR PRO-SEAL KITS $1.20
 I ordered the quart kit of sealant from Van's.  Mixed, then placed into
 the cartridges.  I used this for applying on all parts when doing final
 tank assembly.
 -Sean (#40303)
  Steve 40212
 > aircraft spruce and
 > -Sean #40303
 > any mess but cost
 > mixing manually.
 > most popular size.
 > to use a baggy.
 >> John
