paul.folbrecht(at)veribox Guest
Posted: Mon Oct 16, 2006 5:34 pm Post subject: Bushings vs. Conduit for wing wiring/QB wing stands |
I bought Van's conduit, but now I am rethinking this. Any real
reason to prefer the conduit to using bushings? The latter requires
only enlarging existing holes while the conduit requires new 3/4"
holes in each rib.
Then again, since I am doing navs/strobes and wingtip landing lights
(all Creative Air) as well as a NAV antenna in one tip and COM in the
other (that's COM2 with 1 under the belly), maybe I'll need BOTH.
That is, two runs. Will I?
About the wing stand that Van's has on the plans: certainly this is
not needed for QB wings. I am wondering what is the best way to work
on the wings in general: leave them in the cradle (the Checkoway
style cradle I built), table-top, sawhorses. I am out of town and
cannot look at the manual - have these thoughts going through my
head, as I'll be starting on the wings next week.
Paul
9A QB 1176
FLYaDIVE(at)aol.com Guest
Posted: Mon Oct 16, 2006 6:48 pm Post subject: Bushings vs. Conduit for wing wiring/QB wing stands |
In a message dated 10/16/06 9:36:18 PM Eastern Daylight Time,
paul.folbrecht(at)veribox.net writes:
| Quote: | I bought Van's conduit, but now I am rethinking this. Any real
holes in each rib.
Paul:
It is really a no-brainer ... Go with the CONDUIT.
How are you going to fish the wires through the bushings?
You must have very long,very skinny arms.
No problems with hanging wires.
No problems with chaffing.
No problems running a second or third pair of wires for wing-tip mounted
antenna or landing lights or Nav lights or Strobes.
OR DOING ANY TYPE OF ELECTRICAL REPAIR
CAN-DU-IT
Barry
"Chop'd Liver"
Albert Gardner
Posted: Mon Oct 16, 2006 9:55 pm Post subject: Bushings vs. Conduit for wing wiring/QB wing stands |
It's easier to pull wires as opposed to pushing them whether it's bushings
or conduit. Run a heavy string through whatever you use when you are
building. Later, use the same string to pull in wires when you need them.
(Pull in a new string also. You never know if a new wire will be needed.)
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Gary.A.Sobek
Posted: Tue Oct 17, 2006 12:26 am Post subject: Bushings vs. Conduit for wing wiring/QB wing stands |
About 15 years ago, I asked Van at the Merced fly-in the same question. Van
told me that the conduit was too heavy for him.
I have snap bushings in the ribs along the spar. I have the NAV antenna
coax in one set. (forget it if was the TOP or bottom of the wing.) The
other set of holes I ran the power wires for the landing lights, strobe
power supply (one in each wingtip) and nav lights.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,954 + Flying Hours So. CA, USA
----Original Message Follows----
From: Paul Folbrecht <paul.folbrecht(at)veribox.net>
Reply-To: rv-list(at)matronics.com
Subject: Bushings vs. Conduit for wing wiring/QB wing stands
Date: Mon, 16 Oct 2006 20:33:15 -0500
I bought Van's conduit, but now I am rethinking this. Any real reason to
prefer the conduit to using bushings? The latter requires only enlarging
existing holes while the conduit requires new 3/4" holes in each rib.
Then again, since I am doing navs/strobes and wingtip landing lights (all
Creative Air) as well as a NAV antenna in one tip and COM in the other
(that's COM2 with 1 under the belly), maybe I'll need BOTH. That is, two
runs. Will I?
About the wing stand that Van's has on the plans: certainly this is not
needed for QB wings. I am wondering what is the best way to work on the
wings in general: leave them in the cradle (the Checkoway style cradle I
built), table-top, sawhorses. I am out of town and cannot look at the
manual - have these thoughts going through my head, as I'll be starting on
Paul
9A QB 1176
Posted: Tue Oct 17, 2006 3:01 am Post subject: Bushings vs. Conduit for wing wiring/QB wing stands |
In a message dated 10/17/2006 4:28:08 AM Eastern Standard Time, rv6_flyer(at)hotmail.com writes:
| Quote: | About 15 years ago, I asked Van at the Merced fly-in the same question. Van
told me that the conduit was too heavy for him. |
Wow, I knew Van was weight conscious but how heavy is a piece of thin wall plastic tubing? The 3/4" is a bit large, all you need is 1/2" or what ever would fit into the existing holes and I would guess the weight for both wings would be just about 2 Lbs.
Then again, 15 years ago is a long time back. Back then Van was a purest and did not have the QB Kits.
Barry
"Chop'd Liver"
