pacificpainting(at)comcas Guest
Posted: Tue Oct 17, 2006 3:36 pm Post subject: Inspection covers. |
Hello Fellow Listers,
Can anyone tell me why I would have to put doublers on for inspection plates. I have the plates and skins drilled. I don't see why I can't dimple and flush rivet nut plates to the skin. It's .025 and would hold a small flush rivet OK. If the plates were riveted direct to the skin, wouldn't it be about the same?
Dave in Salem
dredmoody(at)cox.net Guest
Posted: Tue Oct 17, 2006 4:14 pm Post subject: Inspection covers. |
The only reason that comes to mind for the doublers is to make the rim of the inspection hole more trauma resistant when the hatch cover is off. Once the cover is screwed into place, it essentially is a doubler for the inspection hole in the skin, isn't it?
Ed Moody II
Rayne, LA
601XL / Jabiru / fuselage
---- Dave Ruddiman <pacificpainting(at)comcast.net> wrote:
Dave in Salem
Posted: Tue Oct 17, 2006 4:46 pm Post subject: Inspection covers. |
Quote: |
One other reason for the doubler approach is it allows a flush
mounted inspection plate. This might be significant in a very fast
airplane - definitely not a good description of the CH801.
Paul
XL fuselage
Quote: | The only reason that comes to mind for the doublers is to make the
Ed Moody II
jhstarn(at)verizon.net Guest
Posted: Tue Oct 17, 2006 5:37 pm Post subject: Inspection covers. |
NO..... The doubler is to spread the "load" of flexing around the hole as a whole. Individual nutplates DO NOT spread the flex and can be the cause for cracks as they localize it. Besides if you use a doubler that leaves a 1/2" lip inside the hole & attach nut plates to the back of that flange the inspection cover will fit flush and add addition strength to the area. Flush rivet the doublers and make it part of the permanent structure. No square corners, radius them & those of the removable panel. I would also use .032 for the doubler and make it one piece. On the Rocket we used .040 on the .032 skins. KABONG Do Not Archive
Michael Valentine
Posted: Tue Oct 17, 2006 5:59 pm Post subject: Inspection covers. |
Perhaps I am just showing my ignorance here, but where does it call for doublers? I haven't seen that on the inspection holes on the tail or wings. Am I missing something or does this come later?
Michael
(in NH)
On 10/17/06, Dave Ruddiman <pacificpainting(at)comcast.net (pacificpainting(at)comcast.net)> wrote:[quote] Hello Fellow Listers,
Dave in Salem
Posted: Tue Oct 17, 2006 6:07 pm Post subject: Inspection covers. |
I'm not challenging any of the advice about the covers. I'm not concerned about drag. The 801 isn't exactly a low drag air frame. I also considered whether the plates would become part of the structure of the wing skin. The wing assembly manual says I can cut a 95mm access hole. Mine is 100mm. It also says to make a 135mm round cover and use 6 A4 rivets. My cover is 140mm and I have 8 holes which I have only pilot drilled. I was originally going to use doublers and nut plates, then decided to just rivet the plates to the skin. Now I have thought about using nut plates again. It seems like I am making a big issue out of something that should be simple. Or maybe not.
Dave in Salem
Posted: Tue Oct 17, 2006 6:13 pm Post subject: Inspection covers. |
Michael,
They don't call for doublers that I know of. I was just asking the question to see if they are necessary or not. ZAC says you don't need them. It does add a step or two to the procedure but.....?
gboothe(at)calply.com Guest
Posted: Tue Oct 17, 2006 6:43 pm Post subject: Inspection covers. |
Dave,
Your question is worthy. Unfortunately, there are many different answers depending on one’s preference. Whether .016 needs a doubler is probably more relevant than .025. You just have to make the decision yourself….caffeine / no caffeine, Mac / PC, tri-cycle / taildragger, green scotchbrite / purple scotchbrite, center yoke / dual sticks….so many decisions…..
Making a flush mount inspection plate is an easy task and looks real cool. Consider it. If you decide to make any kind of screw-on inspection cover, be sure to make the screw pattern an obvious indication of which direction the plate goes on. If you have multiple plates, mark them to show placement. Life will be better.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dave Ruddiman
Sent: Tuesday, October 17, 2006 7:07 PM
Subject: Re: Zenith-List: Inspection covers.
Dave in Salem
Posted: Tue Oct 17, 2006 7:04 pm Post subject: Inspection covers. |
Gary,
Caffeine, PC, tri-cycle, green scotchbrite, (apparently it is Un-American to use any othe color), center yoke. Flush plates look good, but I won't be able to see the top of the wing without a ladder. I did make a tiny little notch towards the leading edge of the plates. Another thing, hopefully these things never have to be taken off. I've got to quit making things so difficult. I feel so much better now that I've made all these decisions.
Dave
Posted: Tue Oct 17, 2006 7:14 pm Post subject: Inspection covers. |
Dave,
Now you’ve done it!! You just condemned yourself to multiple removals.
Gary – Do not archive
…..Another thing, hopefully these things never have to be taken off…..
Dave
Posted: Tue Oct 17, 2006 7:38 pm Post subject: Inspection covers. |
Gary,
You know, having my computer in the shop is almost as bad as leaving the door open at the airport when you are trying to get something done. I guess I don't have to stop and read the emails, but that part of the fun of the whole process. I wouldn't want to be left out.
Dave
I keep forgetting the DO NOT ARCHIVE part.
doug kandle
Posted: Tue Oct 17, 2006 8:35 pm Post subject: Re: Inspection covers. |
I believe that in a stressed skin design (like the 701 and 601) adding an inspection hole is the same as making a repair to the skin. AC 43.13-1B covers procedures for repairs of damaged skins. The repair that covers a 3" hole, using only material of the same thickness as the skin, requires two circles of rivets (24 rivets total). That is a lot more rivets (or screws) than you would put into an inspection cover. I don't know where the design data is for an inspection cover, but clearly it is not enough to repair a 3 or 4 inch hole with just 6 or 8 screws. (see AC43.13-1B section 4-58 ).
Remember that unlike a tube and fabric design, most of the strength of your aircraft is obtained from the skin. Unless you know the stresses that will be applied to each particular part of the skin, you should probably assume that it is critical to not weaken it wherever an inspection opening is added.
Ron Lendon
Posted: Tue Oct 17, 2006 9:37 pm Post subject: Inspection covers. |
Not to complicate things any more, or keep this subject going, but what
about the holes in the skin for the fuel tank caps? Would I be correct in
assuming that there might be less stress because they are somewhat smaller
and are fairly close to both the spar and a rib? Just curious. It's time to
get this done and move on.
Posted: Wed Oct 18, 2006 7:22 am Post subject: Inspection covers. |
Radio Shack sells those little vibrating engraver tools (cheap and easy to use). I consider it a must for my project. When I have fitted and drilled a piece, it has to be removed, deburred, and primed (and sometimes painted) before it is ready for rivetting later. When I take the piece off to do all that stuff, the first step is to ID it with the little engraver. It does not lead to cracks or fraternization with green scotchbrite (I use a security camera to monitor the parts while I'm at work). I put the ID where it will not be seen once the part is installed. That allows me to positively ID the parts location and its orientation with arrows as needed. Even once the part is primed or painted the marks can still be seen. The same goes for my inspection hatch covers.... they all bear location and orientation marks on the inside.
Ed Moody II
Rayne, LA
---- Gary Boothe <gboothe(at)calply.com> wrote:
Quote: | sure to make the screw pattern an obvious indication of which direction the
Gary Boothe
Cool, CA
Posted: Wed Oct 18, 2006 7:28 am Post subject: Inspection covers. |
Yep.... just as well convert them to Velcro now.
Ed
Quote: | Dave,
Now you've done it!! You just condemned yourself to multiple removals.
Gary - Do not archive
...Another thing, hopefully these things never have to be taken off...
Dave
doug kandle
Posted: Wed Oct 18, 2006 8:02 am Post subject: Re: Inspection covers. |
pacificpainting(at)comcas wrote: | what
The fuel tank cap holes were designed in, not a builder add on. I assume that the designer knows what he was doing. But I don't have any easy way to determine how much stress must be supported in any particular location on the skin and therefore I assume the worst (that it must be full strength). I have heard rules of thumb - like the farther out on the wing you go, the less stress the skin must withstand. The FAA takes design changes very seriously and I think we all should too.
Posted: Wed Oct 18, 2006 10:30 am Post subject: Inspection covers. |
What is the rating for Velcro. Would it need to be higher in shear or
tension? Do I have to use industrial strength or just the regular household
variety. Does it have to be "Velcro" brand or can I use after market
products as long as they are approved. What about Color? I'm really confused
now.
Posted: Wed Oct 18, 2006 12:03 pm Post subject: Inspection covers. |
"I'm really confused now."
You didn't to tell us that Dave, we already knew. KABONG 8*) Do Not
Archive
Subject: Re: Inspection covers.
household variety. Does it have to be "Velcro" brand or can I use after
market products as long as they are approved. What about Color? I'm really
confused now.
Posted: Wed Oct 18, 2006 1:43 pm Post subject: Inspection covers. |
Dave,
You raise relevant points. I think the shear rating is most important on
under-wing applications, while the tension rating would apply to
top-of-wing. It would not matter if it was "industrial" or "household" as
long as it was at the certified rating. Certainly, anything other than
"Velcro" would require an STC. As to color, my guess is that any color
except green would be certified (wouldn't want anyone to mistake the green
Velcro for scotchbrite).
What really concerns me, though, is the adhesive with which the Velcro is
applied. It'll take someone smarter than I to determine the required testing
for that (after all, I'm just a guy who travels too much for work with way
too much time on my hands in a motel!)
Gary Boothe
Cool, CA
DO NOT ARCHIVE
