rexjan(at)bigpond.com Guest
Posted: Sun Oct 22, 2006 6:58 pm Post subject: Rebuilding 582's |
I am kinda hard headed at times as I have been racing sleds and we run those WAY
harder and longer than anyone in their right mind would run an engine you are
flying behind. With that being said, I feel that if I can rebuild / straighten
cranks in race engines (that are straighter than the NEW factory crank) that
go for 100 miles at a time on the bar (WOT 8,200 RPM+) time after time and
stay together year after year, I am not shy about rebuilding this engine. I am
also not a stupid pilot who takes alot of unnessisary chances with his life
(well ok there have been a few times lol). I dont buy into the arguments that
you have to buy NEW cranks everytime. If you take it down, inspect, mike, etc.
and find it within tolerances and put it back together to specs then I dont
have one second thought about flying behind it.
Just my thoughts
Hi Leni,
sorry to see you cop so much flak over wanting to rebuild your 582. There is a place for this discussion to let us all that are prepared to listen acsertain a few pertinent facts. Actually I'm in a similar boat to you. I raced a 250cc Kart for years. It was single cylinder and ran all race long on 14,000 RPM. Yes despite comments that an aircraft motor is running much longer etc there is a lot of lessons learn't doing this sort of thing and I'm willing to bet a 582 out of the box wouln't handle that for long. We also rebuilt cranks to way better than factory specs. We also polished and shot peened rods and changed them every six months. We learnt not to use metal caged mains etc etc. You can't tell me a lot of this isn't relevant to making a better 582. I have a Blue Head that might have reached 150 hrs by now so I don't expect to have to worry about it anytime soon. However when I do I'm very tempted to want to do it myself. Sure Rotax have learn't a lot over the years and the 582 is now a remarkable motor. Anyone would be foolish to ignore what Rotax have learn't. I think the trick is to be aware of all that and to be able to get parts to rebuild the crank etc. My understanding is that you can only buy the crank as a whole from Rotax no patrs as in rods, crank pins etc. I believe there is some after market pistons though that should be better. Also a big problem is Rotax have prices that are way over the fence.
If we could all discuss this subject here calmly we could gather a lot of info to our mutual benifit and yes we can no doubt make a better engine. I am not saying that making a lot of horsepower and running a long time aren't two entirely different things although a motor that will hang in for racing at 14,000 obviously is bullet proof at 6,800 so some aspects do apply. I also would not like to see just anyone rebuild their own plane motor just because it's cheaper. Obviously there is a lot of knowledge, experience and expertise needed not to mention tools and jigs. I heard that Rotax actually raised the price of parts so high so people would would opt for a new motor rather than rebuild. Apparently there were a lot of rebuild failures which is not good for safety plus of course Rotax was getting a bad reputation. Also if one upgraded from Grey head to Blue in the course of sorting motor problems then there was less motor failures. I understand too that not being able to buy individual crank parts stops poor crank rebuilds. I think one issue was broken crank webs where their was a machine mark. If one has to buy a new crank that problem gets solved instead of a crank with that mark going back into service only to fail at some point.
I say let's discuss what's involved and we can get a better product. If we save some money that's fine but personally I'd pay more rather than less to get that better product. At a very casual glance at all this I feel better pistons are available. Bearings should not be a problem nor seals. However what about crank parts especially the rods. Actually just new rods would probably be fine and I'd polish and peen them but as I understand it we can't get these. However their might well be an alternative !
Leni please don't be put off. Your knowledge and experience do count. As for those that don't have that then yes by all means don't fiddle. Just go for a new engine or at least a rebuilt one by some one like Bob Robertson but don't tell the rest of us what to do with our knowledge and experience.
Rex from Australia.
eskflyer(at)lvcisp.com Guest
Posted: Sun Oct 22, 2006 8:00 pm Post subject: Rebuilding 582's |
Well said REX . I know there are bearings available to rebuild but i cannot find out where yet . trying to get these secrets is like trying to get a straight answer from my wife . it aint gonna happen lol . Im my experience running the 582 it is the rod needle bearings on the crank and piston pin that tend to disintegrate . I Hope we can find a source for them .
Fly safe fly low fly slow Flyfun fly KITFOX
John Perry
Kitfox 2 N718PD
akflyer Guest
Posted: Mon Oct 23, 2006 9:27 am Post subject: Re: Rebuilding 582's |
Just to let you know, I just got off the phone putting in the order for all the seals, o-rings, bearings etc,... YES THEY ARE ROTAX PARTS... I found them at CPS. I downloaded the PDF manual and price list, then called and ordered them. Not quite as bad as one would expect, but I bet there is a cheaper place to get them somewhere, I was just ready to order now and went for it.. All said, the crank parts are $512.66. The only problem is they dont have the lower conrod needle bearings. I am still on the hunt for them so if you know a place that has them please let me know..
I am still looking for a source to machine the case for the water pump seal upgrade.
OK now I have to get on the soap box just a little...
I have been involved in several "certified" aircraft rebuilds and this spring the TOH of a lycoming 0320. I was spose to be the parts grunt and two A&P's (one with AI) were the brains.... I was appalled at the lack of attention to detail by the two monkeys. Con-rod nuts installed upside down (yes they have a right and wrong side), wrong nuts or studs used, using a TQ wrench that had NEVER been calibrated or in most cases not using a TQ wrench at all. The wrong assembly lube used, wrong rod bearings installed.... the list goes on to include just about everything they did....I guess with my QC mentality, my attention to detail is VERY great. If I think I know something by heart I still look it up just so I can pat myself on the back for knowing the right answer all along... but more often than not, it saves my butt...My point in all this is, I trust no one more than myself to work on my aircraft. This goes for for all aspects of the construction. I can tell horor stories all day long but I will quit at this.
I will keep you posted on the progress and how the parts look when I get them.
Guy Buchanan
Posted: Mon Oct 23, 2006 9:39 am Post subject: Rebuilding 582's |
At 12:27 PM 10/23/2006, you wrote:
| Quote: | Leni please don't be put off. Your knowledge and experience do count.
experience.
Rex,
I agree with your sentiments but want to add that the reason I
often do work myself is because I then KNOW the quality of the work. When
you send your engine to a shop you hope the work gets done consistent with
that shop's reputation, by the people who made that reputation, and that
they're just as good, just as sharp, and just as conscientious as they ever
were. Unfortunately "S&%t Happens" and yours may be the one or the first
engine that doesn't get done right, and you have no way of knowing until it
fails. That's not to say I will do my own rebuild, because I just don't
have the expertise and the tools; but I would fully endorse someone else
doing so who does.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Mon Oct 23, 2006 2:58 pm Post subject: Rebuilding 582's |
That's why they pound it into us to use the maintenance manual. Copy the
pages for the job check everything off, get it inspected by another set of
eyes if you want keep the copied sheets stapled into the technical manuals.
In Canada it is actually illegal to use any measuring equipment on an
aircraft that is not calibrated. That includes Torque Wrenches, Voltmeters,
Barfield testers, micrometers... He** even pressure gauges to inflate tires
with nitrogen have to be calibrated. Each tool carries a sticker with the
calibration data on it. Yes I have seen guys use "standard torque" by
their definition it is snugged with a wrench. I figure if the AMO has to go
through the expense of obtaining all the equipment, manuals and the
calibration$ the least I can do is use them.
I spent a few sleepless nights when a flash light was missing from my boss's
tool box. Six weeks later we found it, still turned on, where the pilot who
did the final independent inspection left it, under the right floor board of
his C185.
I set up a shadow board for the AMO and also had an inventory on my tool
box. Every tool was locked up before quitting time. I had no problems
lending a tool out to other engineers as long as I made a note and left that
note in the place the tool was supposed to be. Never lost a tool.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Mon Oct 23, 2006 4:01 pm Post subject: Re: Rebuilding 582's |
| Quote: | | Con-rod nuts installed upside down (yes they have a right and wrong side) |
Leni,
This statement struck a nerve !
I'd say...if you can't do the work.. (I count myself on this list) .. then DO everything possible within limits - try to get the chance to observe! at the least. Who cares most about an engine? The guy sitting behind it in the air.
My only catastrophic engine failure, to date, was an IO-520 and a C-206. In my case, I'd just come from Nassau (90 minutes over water), was just clear of the shore passing over Ft Lauderdale (FLL) - boom .... grrrrrrr - I was on tower freq. - made an urgent request to land (declined declaring emergency, though may have had to if there hadn't been a gap in 9L traffic) ... powered back - not nice engine noise and vibration - short base, then landing... rolled with no power on to the north ramp. - yes, the trucks did roll in for a look...
On tear-down (~50-60 hours since rebuild) a connecting rod bolt was found to have been installed ' backwards' - excess length had been 'gently' hammering away on the crank case until it finally banged through.
I found a rebuilder in the area, and was able to monitor every step of the new work. (the original shop denied responsibility, the rebuild was done for the previous owner)
Grrrrrrrrr!
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
Malcolmbru(at)aol.com Guest
Posted: Mon Oct 23, 2006 5:23 pm Post subject: Rebuilding 582's |
call air screw performances in Arizona Steve batty has rebuilt moor 582s with aftermarket partes and rebuilt moor cranks than anybody I know and he fly's one of them Canadian Kit fox clones malcolm
akflyer Guest
Posted: Mon Oct 23, 2006 5:26 pm Post subject: Re: Rebuilding 582's |
Thanks I will be calling him tomorrow.
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 23, 2006 9:30 pm Post subject: Rebuilding 582's |
Float Flyr
Posted: Tue Oct 24, 2006 7:39 am Post subject: Rebuilding 582's |
Oops I should have stated for certified aircraft and their appliances. Home
built or to be correct for TC it's "Amateur Built" is the same as the
states. When I got so used to working one way I sometimes forget not
everyone has to operate by the rules I have to use at work.
Noel
[quote] --
Kitfox III-A
akflyer Guest
Posted: Wed Oct 25, 2006 2:26 pm Post subject: Re: Rebuilding 582's |
You were right. Rotax does offer the rods, bearings, pin and shims. One call solved it all.. But this is only for the grey head. I am told they do not offer the set for the blue head. I do not know what the differences may be.
Now for the kicker... after you add up all the parts you need to zero time your crank, you are only looking at maybe a 175-200.00 savings over just buying a new crank. This is based on retail prices, unless one can find a cheaper source for parts....In most cases, you are better off to just bite the bullet and buy a new one, unless you have the knowledge and equipment to safely complete the job yourself.
I am still on the hunt for a cheaper supplier, but at least I know now that the parts can be obtained and the work completed.
Thanks again for the tip on who to call.
