		rv7a.builder(at)yahoo.com Guest
				 Posted: Mon Oct 23, 2006 11:26 am    Post subject: Transponder antenna location |
				Hello List,
    I was thinking of installing the transponder
 antenna just forward of the F-704 on the passenger
 side. Will a spinning prop or the tricycle landing
 gear cause any problem with this location? Thanks JR
 RV-7A...finishing touches on the electrical system.
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		charlieray(at)optonline.n Guest
				 Posted: Mon Oct 23, 2006 2:32 pm    Post subject: Transponder antenna location |
				On most Pipers, the factory location is about 1 foot behind the firewall in
 the center.  Your prop will not do alot of shadowing damage.
 Just ensure to follow the guidelines for your transponder manufacturer...
 Garmin says use low loss coax rg400 or rg142 and keep it under about 8 feet
 or cable run...  at the same time no closer than 3 feet straight line from
 transponder to the antenna (linear distance traveling thru seats and floor
 etc)..
 Charlie
				 Posted: Mon Oct 23, 2006 3:51 pm    Post subject: Transponder antenna location |
				Thanks Charlie....JR
  damage.
  etc)..
  Charlie
		sa300(at)uniserve.com Guest
				 Posted: Mon Oct 23, 2006 5:21 pm    Post subject: Transponder antenna location |
				A good place to mount it is just aft of the firewall between the exhaust
 pipes, which puts it just to the left of the electric fuel pump. It will
 work very well in that location.
 rv7a.builder wrote:
  Hello List,
