CJohnston(at)popsound.com Guest
Posted: Thu Jan 26, 2006 10:14 am Post subject: Nylon Snap Bushings |
Hey all -
Didn't get a reply from anyone last time I asked, so I'll try again.
Are the nylon bushings (ie: SB437-4) safe to be used in an application
that has them submersed in fuel constantly? Will they react at all?
Break down?
cj
#40410
wings
www.perfectlygoodairplane.net
noel(at)blueskyaviation.n Guest
Posted: Thu Jan 26, 2006 10:28 am Post subject: Nylon Snap Bushings |
CJ
If I remember correctly the Van's capacitance plates that I put in the RV-8A
used the snap bushings to run the wire though the bulkheads and the wire was
wrapped around the vent line. Quick call to Van's will solve this. For a
belt and suspenders approach you can completely coat the bushing in proseal.
Noel
RV-10 flying
RV-9A flying and one under construction
RV-8A flying
RV-7
RV-6A (X2)flying
Among the good ones anyway
www.blueskyaviation.net
ricksked(at)earthlink.net Guest
Posted: Thu Jan 26, 2006 10:34 am Post subject: Nylon Snap Bushings |
Chris,
The bushings are made from black nylon and are safe for immersion in fuel.
Risk S.
40185
Fuselage
rvbuilder(at)sausen.net Guest
It's probably a safe bet that they will be fine. However you can always drop a couple in a mason jar of 100LL and put it on the shelf for a while to be sure. If they don't melt within a day I probably wouldn't worry about it.
Michael Sausen
-10 #352 Fuselage
n223rv(at)wolflakeairport Guest
Posted: Fri Jan 27, 2006 8:17 pm Post subject: Nylon Snap Bushings |
Well, I know Van's uses the snap bushings in the fuel tanks to hold the
vent lines as they go through the tank ribs.... I have not heard of
anyone finding pieces of them in the sump or bottom of the tank.
-Mike
