ronlee(at)pcisys.net Guest
Posted: Thu Oct 26, 2006 6:39 am Post subject: FADEC controlled engine problem |
Background: New RV-7A, XP-360 engine, Aerosance FADEC system.
On the second flight the engine was surging at times. The pilot
reported a significant CHT drop on the #4 cylinder. On the first
flight that same cylinder had very high CHT but that data point
may be misleading.
Aerosance suggested moving the fuel injector to the number 2
cylinder to see if the problem moves. Certainly a valid way to
isolate a problem but since the problem was not duplicated on
a ground run it may not be best to try in again in flight.
Ignoring for now that the FADEC controller may be a problem
I am assuming three possible problems.
1) Inadequate fuel flow
2) Intermittent clog in the injector
3) Solenoid problem ( Apparently the solenoid on each injector
somehow controls the fuel injected in to the cylinder).
Fuel flow could be verified by disconnecting the fuel lines at the
injector and running the boost pump to verify fuel flow and eliminating
a clog in the line as a possible problem.
As far as the injector, I am assuming that there is a way to check
for blockage.
The owner should be checking documentation for additional info as well
as calling the manufacturer but if anyone has helpful advice it would
be appreciated.
Ron Lee
skylor4(at)yahoo.com Guest
Posted: Thu Oct 26, 2006 10:50 am Post subject: FADEC controlled engine problem |
What did the EGT's do during the surging?
--- Ron Lee <ronlee(at)pcisys.net> wrote:
FADEC system.
times. The pilot
On the first
data point
may be misleading.
number 2
valid way to
duplicated on
flight.
problem
each injector
cylinder).
fuel lines at the
a way to check
for blockage.
be appreciated.
Ron Lee
browse
Subscriptions page,
FAQ,
Web Forums!
Admin.
Posted: Thu Oct 26, 2006 1:44 pm Post subject: FADEC controlled engine problem |
At 12:49 PM 10/26/2006, you wrote:
I don't have that info. With the blizzard today I may not have
it until Friday...if it is known.
Ron Lee
sjhdcl(at)kingston.net Guest
Posted: Fri Oct 27, 2006 4:23 am Post subject: FADEC controlled engine problem |
What type of prop and gov (assuming CS) is he running? I had a surging
problem with my governor.
Steve
RV7A
| Quote: | Time: 07:39:34 AM PST US
Subject: FADEC controlled engine problem
may be misleading.
for blockage.
be appreciated.
Ron Lee
Posted: Fri Oct 27, 2006 11:18 am Post subject: FADEC controlled engine problem |
At 06:20 AM 10/27/2006, you wrote:
Steve
RV7A
Aerocomposites CS prop and MT P-860-4 prop governor.
Ron Lee
