Tony Partain
Posted: Wed Oct 25, 2006 7:28 pm Post subject: Kitfox vs. Cub |
Hello everyone after building my RV7 and starting a RV10, midway through the RV10 tail kit I decided that I had already done enough metal work. So I sold the 10 tail kit. My other choice was a Cub, but after researching the Cub kits they were either very expensive or expensive and incomplete. And the plans for a Cub are non existent. The Kitfox kept coming back to the front of the list. I looked at the Just Aircraft Highlander but support of the Kitfox group seem to be more prevalent. The side by side seating is a plus and having 150 lbs of baggage capacity is a plus also.
So I have a few question about performance of the Super Sport with a 100 hp Rotax.
Is the advertised rate of climb accurate for the Super Sport? The advertised rate is 1200 fpm.
Is the stall speed accurate at 41 mph?
How many people are actually using this aircraft for back country airstrips? I plan on using the plane on strips that a mainly grass and gravel strips. Nothing extreme.
Does this design have the durability to handle this type of use?
Quick Build wings, is it worth the extra $1295 for the QB option?
I would like to hear your thoughts on these items.
_________________ Tony Partain
Partain Transport Company
Bend Oregon
http://www.partaintransport.com
RV7 IO360 CS 116WT |
propellerdesign(at)tele2. Guest
Posted: Wed Oct 25, 2006 10:17 pm Post subject: Kitfox vs. Cub |
Tony,
Except for VAN's don't thrust the factory Nr's.
I guess that's why you ask this group.
Dave have a top speed of 100+ MPH with 65 HP, on his KF IV, so if everything ells is the same, you will have a cruise of 100-102 at 65% power.
top speed 115 -118 MPH if you have fairings.
climb at 1200 LBS TOW 1050fpm to 1390 fpm depending on how you prop the plane.(standard day SL)
Jan
rdmac(at)swbell.net Guest
Posted: Thu Oct 26, 2006 9:53 am Post subject: Kitfox vs. Cub |
Tony,
I can speak for the 1200 fpm rate of climb. I built a model 7 with
100 horse Rotax and with the area of the country where I fly from being
anywhere from to 800 to 1200 msl. That rate of climb is certainly attainable
and I have the basic GSC wood prop. It may vary to on how you have it
pitched. I lost a little climb performance when I repitched the prop for
cruise but it will still leave the runway after a 300 to 400 ft role and
climb like a homesick angle, I just love it. As for the quick build wings,
if you're a person that enjoys the building experience you can save some
money but for me the extra money was worth it. They can build the wings with
there jigs at the factory and when you get them they look like a work of
art, very will done. As for durability I have made some not so graceful
landings in mine and I'm still amazed at how durable that spring aluminum
gear is. It is stout. Good luck on your decision.
Roger Mac
S7/912uls
Malcolmbru(at)aol.com Guest
Posted: Thu Oct 26, 2006 4:14 pm Post subject: Kitfox vs. Cub |
you can get a built Highlander with minamum IFR ( not legal IFR) for $65,000 malcolm
dan(at)azshowersolutions. Guest
Posted: Thu Oct 26, 2006 5:03 pm Post subject: Kitfox vs. Cub |
Hey Tony,
Welcome to the Kitfox gang. You may remember the Kitfox you delivered in Mesa AZ last January...that was mine. It is going well, but slower than I like. If I remember right I think you said you finished your RV-7 in 6 months? With that speed, it may take you 3-4 months to do a Kitfox...especially if you get the QB wings.
I can't give you Super Sport specs as I'm building a IV, however, the guys I have flown with in IV's, and VII's have the Rotax 912s and they do climb out at 1200 ft/min and then some. Here in the desert, climbout was what I was concerned with. After my first flight (which was in July of 05) I was sold. With two of us at close to 400 lbs. That 100 HP pulled us up like we weren't there.
If you choose to go Kitfox, talk to John McBean about the in-flight adjustable IVO Prop. You will find nothing better.
As for durability, these planes are great for back country strips. Get the Grove Spring gear and you will be sitting pretty. I can't say exactly what the stall speed average is for the Sport, however, this is the area of stall that the IV's enjoy.
Good Luck with your decision,
Dan Billingsley
www.azshowersolutions.com/Kitfox1.html
Tony Partain <tpartain(at)bendcable.com> wrote:
[quote]--> Kitfox-List message posted by: "Tony Partain"
Tony Partain
Bend Oregon
RV7 IO360 CS 116WT
Read this topic online [quote][b]
Tony Partain
Posted: Thu Oct 26, 2006 5:54 pm Post subject: Re: Kitfox vs. Cub |
Gentleman thanks for the replies. I am really looking forward to building another plane, a tube and fabric plane this time! My initial thoughs were to us a traditional engine, but the Rotax seems to be the engine of choice. It also sounds like the factory numbers are close.
One other question about the builders manual, the Vans manual is pretty good for the RV 7 8 9, but it's fantastic for the 10. How does the Kitfox manual stack up?
It sounds like I will be making a trip to Idaho as soon as John returns from Copperstate.
Bend Oregon
RV7 IO360 CS 116WT
Lynn Matteson
Posted: Thu Oct 26, 2006 6:14 pm Post subject: Kitfox vs. Cub |
I hope you haven't overlooked the Jabiru line of engines....2200 4-cyl
or 3300 6-cyl...all air-cooled. Rotax may LOOK like the engine of
choice, but for a long time it was the ONLY choice. Do yourself a favor
and have a look. I'm VERY satisfied with mine after 180 hours...
Lynn
Kitfox IV Speedster...Jabiru 2200
On Thursday, October 26, 2006, at 09:54 PM, Tony Partain wrote:
I sound like I will be making a trip to Idaho as soon as John returns
from Copperstate.
Tony Partain
Bend Oregon
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
gjfpilot(at)yahoo.com Guest
Posted: Thu Oct 26, 2006 7:45 pm Post subject: Kitfox vs. Cub |
Tony,
I am building a Classic IV and did not choose the
quick build wing option. It took me about 100 hours to
assemble both wings to the where they were identical
to the quick build wings that came in a Series 5
Kitfox kit. I had more time than money and enjoyed
putting them together. Plus, I figured I saved about
$12/buiding hour!
Grant Fluent
--- Tony Partain <tpartain(at)bendcable.com> wrote:
a plus also.
Nothing extreme.
type of use?
the QB option?
Tony Partain
Bend Oregon
RV7 IO360 CS 116WT
http://forums.matronics.com/viewtopic.php?p=70257#70257
Michel
Posted: Thu Oct 26, 2006 10:52 pm Post subject: Kitfox vs. Cub |
On Oct 27, 2006, at 4:17 AM, Lynn Matteson wrote:
| Quote: | I hope you haven't overlooked the Jabiru line of engines....2200 4-cyl
favor and have a look. I'm VERY satisfied with mine after 180 hours...
So am I, after 160 hours. Like all air-cooled engines, the Jabiru
requires a cowling modification that creates the proper ventilation
but, once that is done, the engine is very reliable and smooth running.
Those who have had problems with the Jabiru are those who think they
know better than the manufacturers and modify the original
installation. That's cool, after all we are talking about experimental
aviation. But then, don't blame the manufacturer. If you install a
Jabiru as recommended, with the original airbox and oil cooler, using a
recommended propeller, you are certain to have many hours of
trouble-free flying pleasure. The TBO is 2,000 hours with a cylinder
top overhauling at 1,000.
Cheers,
Michel
kmamjones(at)comcast.net Guest
Posted: Fri Oct 27, 2006 6:51 am Post subject: Kitfox vs. Cub |
I'm in the early process of building a Series VII with the builder's manual
I received with the kit from Skystar. I previously built an RV-4 in the
late 80's. In my opinion the Skystar builder's manual is not quite as good
as a Van's manual, but it's not bad. I'm finding it to be quite adequate,
particularly with all the construction pictures and advice from other Kitfox
builders available on the internet and this forum. But perhaps most
important, the new owner, John McBean is every bit as good as Van's (maybe
even a little better) in answering questions and providing advice.
Good luck in your project.
Ken Jones
Tony Partain
Posted: Fri Oct 27, 2006 10:54 am Post subject: Re: Kitfox vs. Cub |
Are there any builder web sites? I would like to see them.
Ken could you call me at the office? 800-774-0828.
Bend Oregon
Posted: Fri Oct 27, 2006 11:55 am Post subject: Kitfox vs. Cub |
Tony,
Having only built one airplane so far in my life I really have
nothing to compare with the Kitfox build manual. However it isn't bad I
guess. I did find a couple of typos and other minor errors, nothing really
comes to mind.
And those have probable been corrected too. So short answer, the manual is
OK I guess. It could certainly be worse.
Roger Mac
davestapa(at)juno.com Guest
Posted: Fri Oct 27, 2006 1:53 pm Post subject: Kitfox vs. Cub |
Tony, I have finished a Kitfox 5 and I am about 60% on a Van's RV-9A. In
my opinion the Kitfox manual is far superior to the Van's manual and blue
prints. In fact Van's has changed to a manual almost identically set up
as Kitfox on the RV-10 and recently on the RV-8. I spend a lot of time
searching for notes and details on the Van's prints (can be on several
pages) where as on most operations you have everything spread out on
double pages in the Kitfox manual
C. David Estapa
Woodstock, GA
S5TD N97DE (taxi testing).
On Fri, 27 Oct 2006 14:54:51 -0500 "Roger McConnell" <rdmac(at)swbell.net>
writes:
Tony,
have
bad I
really
comes to mind.
manual is
Roger Mac
shilocom(at)mcmsys.com Guest
Posted: Fri Oct 27, 2006 3:26 pm Post subject: Kitfox vs. Cub |
It could be like the QCU Challenger manual,,,,smile....worse
Posted: Fri Oct 27, 2006 3:49 pm Post subject: Kitfox vs. Cub |
Very little done with builder web sites in the Kitfox arena...mine is the only one I know of. www.azshowersolutions.com/Kitfox1.html Go to Sportflight page to get other bits of info. http://www.sportflight.com/
Dan
Tony Partain
Bend Oregon
http://www.vansairforce.net/Graphics/PartainTruckingCo.htm
RV7 IO360 CS 116WT
