pete.howell(at)gecko-grou Guest
Posted: Fri Oct 27, 2006 7:58 pm Post subject: Dynon - hall effect sensor issue |
Hello,
I have a Dynon EMS-D10 unit in my RV-9A. I am using a hall effect sensor
from a GRT EIS to measure current in the main wire from the battery to the
main bus. This sensor is supported by Dynon and it works well with one
glitch. Every 10 seconds (like clockwork), the amps reading shoots up to
+99 amps for 1 second and then drifts back down to the correct value. In
the 10 seconds that the correct value is displayed, I can vary the load and
see accurate results on the meter. Any thoughts? There should be nothing
that is sending a high current spike thru the cable.
I have a message into Dynon, but thought I would try here, too. - Thanks
enewton57(at)cableone.net Guest
Posted: Sat Oct 28, 2006 4:52 am Post subject: Dynon - hall effect sensor issue |
I don't have an answer but have a question for you- I getting ready to start
my wiring and was wondering exactly how you mount the Hall effect sensor.
Thanks for any advise.
Eric Newton
nuckollsr(at)cox.net Guest
Posted: Mon Oct 30, 2006 7:48 am Post subject: Dynon - hall effect sensor issue |
At 10:57 PM 10/27/2006 -0500, you wrote:
<pete.howell(at)gecko-group.com>
Hello,
I can think of no way to deliberately generate this behavior
with some variance of wiring. It's almost a sure bet that the little
critter is suffering from byte-farts.
< with experiment. >
< --Lawrence M. Krauss >
brianpublic2(at)starband. Guest
Posted: Mon Oct 30, 2006 11:22 am Post subject: Dynon - hall effect sensor issue |
I just went through installing my GRT HE sensor for my GRT EIS, so I have
the latest info on this from GRT.
First, a couple questions I had for them about it; you can mount it on or
near metal without it affecting the reading. For example, you could mount
it to where the wire passes through a panel or bulkhead. Epoxy and/or
tie-wraps would do this. Picture a large hole same as ID of sensor,
surrounded by about three 1/4" holes for tie-wraps going through the holes
and around the sensor.
I also had wondered if accuracy of the sensor would be affected by other
large wires near the OUTside of the sensor. GRT said no.
This is how I did mine:
http://brian76.mystarband.net/avionicsOct06.htm#oct28
I also used heatshrink on the sensor wires and the sensed wire, to help hold
them together and protect them. I also have 2 crossed tie-wraps holding the
HE sensor ring to the sensed wire. Mounting options are limited only by
your imagination.
brian
jgswartout(at)earthlink.n Guest
Posted: Mon Oct 30, 2006 7:41 pm Post subject: Dynon - hall effect sensor issue |
WOW! Brian! If you ever give up airplane building I think you have a
future in professional photography! Those are stunning photos. Color,
composition, lighting, the works!
John
Posted: Tue Oct 31, 2006 4:47 am Post subject: Dynon - hall effect sensor issue |
I noticed in John's pictures that he has the solenoids with the rubber
insulators on the mounting tabs. There was some discussion recently on this
group about them. Was a conclusion ever reached? I have the same insulated
mounts on the ones that I purchased from B&C. Should the solenoids be
grounded?
Eric Newton
cjensen(at)dts9000.com Guest
Posted: Tue Oct 31, 2006 5:00 am Post subject: Dynon - hall effect sensor issue |
Hey, Brian, how about sharing a little. John's right about the photos.
Given how much everyone is coming to rely on photos to document their
work and to illustration problems/solutions, good quality pictures are
fun to look at. There are a bunch of crappy photographers out there
(and we know who we are) that would appreciate a short rundown on the
equipment you use and how you set up to take the photos. Who knows,
some of the quality might rub off on us.
Chuck Jensen
Do Not Archive.
Posted: Tue Oct 31, 2006 5:38 am Post subject: Dynon - hall effect sensor issue |
At 06:46 AM 10/31/2006 -0600, you wrote:
<enewton57(at)cableone.net>
this group about them. Was a conclusion ever reached? I have the same
insulated mounts on the ones that I purchased from B&C. Should the
solenoids be grounded?
Eric Newton
It doesn't hurt for the contactors to have insulated
mounting feed. I'm mystified as to why the booties
have been added after all these years but the case
is not part of the electrical circuitry and may be
insulated either on purpose (booties) or accidently
(composite airplane).
Posted: Tue Oct 31, 2006 3:33 pm Post subject: Dynon - hall effect sensor issue |
Ok thanks Bob
