jimlc(at)att.net Guest
Posted: Wed Nov 01, 2006 7:04 pm Post subject: Need a floating ball for fuel quantity sight tube |
Joe,
Some have used one of the balls from an antifreeze tester that uses a bunch of colored balls to indicate freezing level.
Jim Crowder
At 07:30 PM 11/1/2006, you wrote:
[quote]Hi Guys,
I use a piece of clear fuel tubing looped between the top
and bottom fittings of my wing tanks. Inside the tube at
the top and bottom is a spring to prevent the tube from
kinking. I would like to add a floating ball to help me better
locate the fuel level. (I'm in the tri-focal generation.) What
would you recommend that would not dissolve? I can bend
the end of each spring to keep the ball out of the tank...
Joe Connell
Stewartville, MN
Kitfox-II N62JK
Guy Buchanan
Posted: Wed Nov 01, 2006 8:15 pm Post subject: Need a floating ball for fuel quantity sight tube |
At 06:30 PM 11/1/2006, you wrote:
| Quote: | What
Joe,
I put two spray tubes from B-12 Chemtool spray cans into my sight
tubes. The show where the fuel level is by diffraction. (They show a visual
kink where the fuel level is.)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Nov 01, 2006 8:46 pm Post subject: Need a floating ball for fuel quantity sight tube |
Another old trick is to put a piece of white paper in back of the site tube
with diagonal lines marked on it. They will show a positive demarkation at
the fuel level
Lowell
neflyer48(at)cableone.net Guest
Posted: Thu Nov 02, 2006 6:56 pm Post subject: Need a floating ball for fuel quantity sight tube |
I tried using balls from an antifreeze tester. They won't float. Gas is much lighter then water and it takes a heavier then water liquid to make the tester ball float, (which antifreeze is heavier then water). I would be interested if anyone else has been successful in finding something that would float in the sight tubes.
Jerry Kohles M3 912UL
runwayrex(at)juno.com Guest
Posted: Thu Nov 02, 2006 8:59 pm Post subject: Need a floating ball for fuel quantity sight tube |
First I tried the antifreeze balls and learned they don't float. Next I used balsa wood balls, painted in fuel proof dope from the hobby store. They worked for a few months, but eventually the fuel must have gotten through the paint and the balsa wood lost its bouyancy. Since then, I have gone without, but have a new idea I'd like to try. Why not grab and old carburetor float out of a floatbowl and carve a little ball out of that material? Whatever that material is, it floats inside of our carburetors.
Rex in Michigan
gjfpilot(at)yahoo.com Guest
Posted: Mon Nov 06, 2006 11:25 am Post subject: Need a floating ball for fuel quantity sight tube |
Rex,
For plastic balls, try www.usplastic.com. They have
a variety of sizes and materials.
Grant Fluent
--- Rexster <runwayrex(at)juno.com> wrote:
[quote] First I tried the antifreeze balls and learned they
Rex in Michigan
float in the sight tubes. Jerry Kohles M3 912UL
