gbright(at)bellsouth.net Guest
Posted: Wed Nov 01, 2006 4:25 pm Post subject: Special Airworthiness Information Bulletin |
While this bulletin applies to STCs, the facts about the
negative effects of alcohol in Mogas are listed.
Here is the link:
http://www.faa.gov/aircraft/safety/alerts/saib/media/CE-07-06.pdf
Even though I am in the South, I will start checking all
gasoline before I put it into the Kitfox.
Cheers,
Grant
Series 5
N21VX
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Thu Nov 02, 2006 6:23 am Post subject: Re: Special Airworthiness Information Bulletin |
It's more than the South, as can be seen in the following link:
http://www.cleanfuelsdc.org/info/images/Map.gif
In nearly all of Maryland, we're stuck with roughly $4/gallon avgas because the ethanol additives are all that's now used in $2.20 mogas. All of our auto-gas STC's are effectively useless. A number of other states are in the same boat. This was a poorly applied political decree, as the alchohol isn't produced near here, so the benefits are negative.
Bob
_________________ Remember that internet advice may only be worth what you pay. |
