janderson412(at)hotmail.c Guest
Posted: Sat Nov 04, 2006 12:34 am Post subject: Warp Drive |
Well, from the thread back a bit about checking pitch in board from the tip
I
decided to check mine.
72" 3 blade.
Blade one tip 17.5 deg, 580mm from centre 26.2deg
Blade two 17.7 26.2
Blade three 17.5 24.7
So I set blade 3 at 18.6 tip and 25.9 (at) 580mm. After this, to the eye
viewing from the side when running one blade was out and in flight I'm sure
not as smooth in flight!
So my thinking is perhaps the WarpDrive folk know something we don't.
Anyway, tomorrow it
goes back to as was.
~j~
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
propellerdesign(at)tele2. Guest
Posted: Sat Nov 04, 2006 1:08 am Post subject: Warp Drive |
Set the blade by the 75% radii = 686mm from center.
It seems that one blade is off 1,5 deg, that is a LOT
Makes me wonder if they use different moulds or if they pop them out before they have cured. it should not be more difference then a 1/8 deg or max 1/4
Most all that have measured there Warp blade have unequal blades.
Jan Carlsson
dave
Posted: Sat Nov 04, 2006 3:55 am Post subject: Warp Drive |
John,
Glad you found similar reading to what a few of us others have found. I
re-adjusted mine so that all were the same at the 75% radii
point and tips were out a bit. I never noticed it by eye but I did run it
up and it seemed ok. So I flew it a few hours like that and I never saw
much of a difference but if anything it might have has a tiny bit less
vibration and there was not much to begin with.
I have a GSC on now and if works about equal to the WARP in performance.
And now with colder air ( 25F this am ) takeoffs in 150 feet or less are
the normal solo.
It would be interesting to see what difference you find with your prop at
the new settings. Heck maybe you might find it better than ever ?
Or maybe not. I had to try mine to see for myself and personally I don't
think it makes allot of difference in my case at least. As far as you
thinking that visually is looks different, maybe so but hey IVO props flex
makes me wonder about them too when on take off they bend 3 to 6 inches
ahead. But they seem popular and a good safety record.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
occom
Posted: Sat Nov 04, 2006 4:50 am Post subject: Warp Drive |
Since the warp prop is being discussed. I'm curious about the mounting
method which is not described in the documentation I have. I gather that the
spinner mounting plate goes directly on the mounting flange followed by the
prop hub. After that I don't know whther to use this blank flange I have or
just washers and bolts.
I can back up the flange with self locking nuts but have not been able to
locate 8mm cross drilled bolts. Length appears to be 70 to 80 mm although I
have seen 80 quoted. I have the torque spec in the documents. I see warp
actually sells mounting hardware for a very low price, is this a set of
drilled bolts?
dave
Posted: Sat Nov 04, 2006 6:43 am Post subject: Warp Drive |
Dave.
The mounting plate goes on outside of hub.
I don;'t know if Warp recommends drilled bolts.
I use to use drilled bolts but I don't now. I use AN locknuts only.
I am sure some will argue about safely wire but I think it totally
unnecessary.
As far as Bolts -- Try Leavens in Toronto as they usually have a good
stock of most bolts.
And if you a RAA member you get a further discount.
I have drilled many times my own heads and if you have the right length bolt
now and are adamant that you want drilled head -- just drill them.
Dave
occom
Posted: Sat Nov 04, 2006 9:47 am Post subject: Warp Drive |
Posted: Sat Nov 04, 2006 1:59 pm Post subject: Warp Drive |
Yes Dave, I'll reset at the 75 percentile and see how it goes, but sure it
was rougher after this last adjustment. Not sure if the visual tip track is
a good indicator or not, we helicopter types are always looking at blade tip
path…tip path plane is very important.
Wonder if the tip track is not very important for smooth operation on warp
props and being composite, no sayng what is happening at 2500 RPM?
Considering the lever arm at the tip, a degree variation might have a
greater effect than pitch variation at a lower percentile.
Subject: Re: Warp Drive
Date: Sat, 4 Nov 2006 06:54:39 -0500
John,
I have a GSC on now and if works about equal to the WARP in performance. And
now with colder air ( 25F this am ) takeoffs in 150 feet or less are the
normal solo.
Dave
Posted: Sat Nov 04, 2006 4:17 pm Post subject: Warp Drive |
No Dave, the plate goes on after the prop hub. I machined up a re-enforcing
ring and drilled hub pattern rather than just use washers. ~j~
Date: Sat, 4 Nov 2006 08:50:15 -0400
drilled bolts?
Become a fitness fanatic (at) http://xtramsn.co.nz/health
Float Flyr
Posted: Sat Nov 04, 2006 7:40 pm Post subject: Warp Drive |
Lock nuts work ...especially if they are checked n the schedule recommended
by the prop manufacturer. But.... You can't beat the look of a nice well
done lock wire job. According to Ivo people don't like to cut lock wire to
check and retorque the prop bolts so they require that you not use lock wire
on their prop bolts.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sat Nov 04, 2006 10:31 pm Post subject: Warp Drive |
AN metal stiff nuts are the go and if it's a bolt and nut situ, then lock
wire has no place. It would be lock nuts or castle. ~j~
Subject: RE: Warp Drive
Date: Sun, 5 Nov 2006 00:10:18 -0330
Noel
