dosmythe(at)cox.net Guest
Posted: Mon Nov 06, 2006 2:58 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
| Quote: | >The only â?opaperworkâ?ť you need to be concerned with is the W&B sheet,
>and that is where you take your aircraft empty weight number from,, and
>inset it into, the >>
Am I the only one seeing the strange postings? It's full of ????? and other
squares and such. Very hard to read
Don Smythe
temco(at)telusplanet.net Guest
Posted: Mon Nov 06, 2006 3:35 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
Don
I get the same thing --- I think Steve has his HTML turned on rather than
plain text. At any rate I just delete all those anyway,
Regards ---- Ted
DO NOT ARCHIVE
Lynn Matteson
Posted: Mon Nov 06, 2006 4:03 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
Nope, I'm seeing them too, Don. I thought it was my eMac interpreting
something wrongly. I agree, it's VERY annoying...like pot scrubbers,
eh? But, following my own advice, I've pretty much switched channels.
Lynn
On Monday, November 6, 2006, at 05:57 PM, Don Smythe wrote:
>> The only â?opaperworkâ?· you need to be concerned with is the W&B
>> sheet, and that is where you take your aircraft empty weight number
>> from,, and inset it into, the >>
other squares and such. Very hard to read
Don Smythe
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Mon Nov 06, 2006 4:38 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
Lynn you old pot scrubber -- at leat your toes are warm now LOL
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Nov 06, 2006 4:51 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
Don, me too. I wonder if it is intentional. Something like a John Gault
thing.
Lowell
kirkhull(at)kc.rr.com Guest
Posted: Mon Nov 06, 2006 4:59 pm Post subject: Basic question : If Steve is right about LSA rules. . . |
Your not alone. I'm getting the same thing
tpcolman(at)yahoo.com Guest
Posted: Wed Nov 08, 2006 7:09 am Post subject: Basic question : If Steve is right about LSA rules. . . |
My sense is that this argument has become an intellectual one for you Steve. For me it is not intellectual. The rules, and FAA's interpretation of them, will dictate exactly what I fly. I have seen fairly authoritative sources say that you are wrong, and someone posted a page from an EAA publication that definitely says you are wrong. I speak as someone who would love for you to be right.
The difference between you and me is that I am not willing to spend tons of money on the chance that you are right. Can you get an FAA source to publicly agree with you? If not let's all agree to move on.
Tim Colman
Float Flyr
Posted: Wed Nov 08, 2006 8:01 am Post subject: Basic question : If Steve is right about LSA rules. . . |
Just reading the mail here.
It appears that if Steve is true to his convictions he should take the FAA
to court ( after all it's a free country ) and let the chips fall where they
may. If he can't afford to do that .... Too bad you will have to live with
what ever FAA says their interpretation of their regulations are.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
84KF Guest
Posted: Wed Nov 08, 2006 8:08 am Post subject: Re: Basic question : If Steve is right about LSA rules. . . |
When you read , and understand, the rules and regulations you will learn, beyond a shadow of doubt, and in proper English, that :
1) You may fly a 1550 design weight amateur-built aircraft under sport pilot privileges.,
2) You may remove the in-flight adjustable propeller from you “amateur-built” aircraft and install a fixed pitch propeller, and still be eligible for use under sport pilot privileges.
3) The since words “original certification has continued to meet the following” is only applicable to aircraft manufactured under TC or TCDS.
4) That the actual “mass” of the aircraft , at the time of takeoff, is, at that time, the determining factor., not a design weight, or any other interpretation of “maximum takeoff weight”
These are your privileges, that the FAA has stated are not affected , so as “amateur- homebuilt” status we just move along. We are not involved that much in their certification and regulation process , which is the issue to them. Not our silly design weight.
This is not an opinion. These are the facts and they are correct.
Fox5flyer Guest
Posted: Wed Nov 08, 2006 8:35 am Post subject: Basic question : If Steve is right about LSA rules. . . |
Steve, I admire your tenacity. However, you've made your point many times
over and it's time to put this topic to bed.
Deke Morisse
List Administrator
84KF Guest
Posted: Wed Nov 08, 2006 9:49 am Post subject: Re: Basic question : If Steve is right about LSA rules. . . |
To all,
In case you haven’t noticed, I have a lot time on my hands. Life is good.
If I have a question about LSA issues , I need the correct answer, from someone who is irreproachable
I go straight to the source. In this case:
Federal Register: July 27, 2004 (Volume 69, Number 143) Page 44771-44882
Certification of Aircraft and Airmen for the Operation of Light-Sport Aircraft
As we all know, when you ask the FAA anything, it’s not a cut and dry situation. The same here. It requires over 100 (110) pages….. over 103,000 words, to address all the issues and clarify each as to leave no loopholes or room for interpretation. I do not interpret , I verify, confirm or disallow, according to the determining regulatory publication.
Just my opinion when a reply is to be made to a “subject”, Use the “REPLY TO” button on the bottom of the last post . This maintains continuity of the subject, and does not clutter the master page with repeated postings. Yes, I find this a distraction (too) and has the perception of an argument, as compared to an ongoing discussion of a specific topic that is very selectable.
Does perhaps posting from an off site access page break the continuity? It seems that off site readers do not have the features available to “go with the flow”?
I don’t know….
Anyway, I’m done. This is my last reply to any of the issues I presented for comment and discussion. If it will reduce the tension provoked by the argumentative and misinformed, so be it.
I will continue to “lurk”, and gleen the wonderful technical info as it progresses.
Deke, Thanks for your patience
steve
MichaelGibbs(at)cox.net Guest
Posted: Thu Nov 09, 2006 8:13 am Post subject: Basic question : If Steve is right about LSA rules. . . |
You know guys, the sooner we stop responding on this subject, the
sooner it will go away. Since Steve is the only guy on the planet
who interprets the rules this way he must be right, so let's leave
him to revel in his victory over bureaucracy.
Mike G.
N728KF
