chris_sinfield(at)yahoo.c Guest
Posted: Fri Nov 10, 2006 2:34 am Post subject: Wing locker |
Hi all
Well the wing locker on my XL is now complete.. looks real nice but since I will not be able to hanger the bird when it rains, it got me to thinking how can I stop rain from going in the hinge (fwd edge)? The sides and back have a strip and I will put foam door seal for weather proofing, but how to stop the rain getting in from the front?? and as you know rain getting in will cause corrosion and green scotchbrite to grow.
Chris
Down Under
flybumtoo
Posted: Fri Nov 10, 2006 8:50 am Post subject: Wing locker |
Hinge? Why did you use a hinge? Zodiacs don't use no stink'n hinges! :~)
Dan Ribb
Fresno, CA
601XL tail kit 20% done
- do not post -
Posted: Fri Nov 10, 2006 10:56 am Post subject: Wing locker |
Chris,
Don't forget to put drain holes in your baggage area same as all the
other places you can collect water. What matter if it takes
water that leaves thru a drain. Water will condense in your plane in
all the other blind spots. A 1/8" drain hole will alleviate this.
Larry McFarland - 601HDS at www.macsmachine.com
Dan Ribb wrote:
[quote] Hinge? Why did you use a hinge? Zodiacs don't use no stink'n
hinges! *:~)*
Dan Ribb
Fresno, CA
- do not post -
grs-pms(at)comcast.net Guest
Posted: Fri Nov 10, 2006 12:25 pm Post subject: Wing locker |
Good point, Larry, and thanks for the reminder.
George
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Sun Nov 12, 2006 8:28 am Post subject: Re: Wing locker |
I use clear prop tape on the baggage locker hinge to keep the water out. I also installed a thin strip of foam weather seal on the bottom edges of the door (the stuff you use on your doors and windows to stop air leaks in your house). It's not absolutely water tight, but it helped considerably.
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
ggower_99(at)yahoo.com Guest
Posted: Sun Nov 12, 2006 9:22 pm Post subject: Wing locker |
Also lets remember to keep the drain holes clean, dirt and pieces of insects can pevent the water to come out.
Saludos
Gary Gower.
George Swinford <grs-pms(at)comcast.net> wrote:
[quote]--> Zenith-List message posted by: "George Swinford"
George
