kitfox(at)bresnan.net Guest
Posted: Sat Nov 11, 2006 4:56 pm Post subject: PTT |
The task has been completed, thanks Lowell,Dave,Neol,Marco,Lynn.
I also have the Sigtronic's SPO 22N. I mounted the switches in 2
snap in plugs that fit 3/4 tube , ran the cables out the side of each
stick , secured the cable with zip ties ran them under the seat and up
behind to an alum. plate mounted to the cross tube where the SPO 22N
is stuck with velcro to the plate . Both cables are secured under the
seat and behind so as not to interfear with anything .
