JimmieBlackwell(at)austin Guest
Posted: Tue Nov 21, 2006 7:35 pm Post subject: Need Muffler Source for Model IV 912 UL |
Would appreciate anyone on the list letting me know if you have a source for a Model IV 912UL muffler.
rjdaugh
Posted: Tue Nov 21, 2006 9:16 pm Post subject: Need Muffler Source for Model IV 912 UL |
You might want to look at what Just Aircraft supplies for the Highlander. Its one muffler for each side. You end up with dual pipes and a nice compact package.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jimmie Blackwell
Sent: Tuesday, November 21, 2006 8:33 PM
Subject: Need Muffler Source for Model IV 912 UL
| Quote: | | www.aeroelectric.com | 0123456789012345
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
runwayrex(at)juno.com Guest
Posted: Wed Nov 22, 2006 1:12 am Post subject: Need Muffler Source for Model IV 912 UL |
Hi Jimmie,
As far as I know, the model 4 muffler was made by the Kitfox people specifically for the Kitfox plane. It is not a Rotax part. Are you sure you need a new one? Several people I know, including myself had the baffle inside come loose. We cut the muffler open and rewelded the baffle and welded the muffler closed again. A year later, the baffle came loose again. That time, I cut the muffler open and removed the baffle before closing things up. It's been running fine ever since with little or no difference in sound or temps.
That's my experience, for what it's worth. I have approximately 200 hours of no baffle running time with no problems. Good luck.
Rex in Michigan
roelectric.com
com/">www.buildersbooks.com
kitlog.com
homebuilthelp.com
www.matronics.com/contribution
">http://www.matronics.com/Navigator?Kitfox-List
Posted: Wed Nov 22, 2006 8:46 am Post subject: Need Muffler Source for Model IV 912 UL |
Actually I was checking for a friend of mine. Not having seen the muffler I am not sure about the repairability of it.
One thing that comes to mind though, our Kitfox's will certainly outlast the mufflers and all of us will eventually need a muffler and exhaust pipes. Perhaps John McBean has plans to provide them in the future.
Appreciate the response.
Have a great Thanksgiving.
Jimmie
Will do that. Thank you Randy.
Happy Thanksgiving.
Jimmie
dafox(at)ckt.net Guest
Posted: Wed Nov 22, 2006 7:53 pm Post subject: Need Muffler Source for Model IV 912 UL |
Hello Jimmy,
I just had a new muffler installed on my header pipes by John McBean.
( Kitfox Aircraft now ) I sent in my header pipes and he put them in the
appropriate Jigs to fit the 912 UL to the kitfox IV 1200, I got them back last
thursday an installed it the next day, and they fit like a glove.
Call John McBean, he can fix you up. amoung a lot of other things
David, 4 1200 912 UL
( No one else is capible in doing this )
Posted: Thu Nov 23, 2006 6:11 am Post subject: Need Muffler Source for Model IV 912 UL |
Thanks. Did talk to John and he can do it, but is backed up with moving for now.
Jimmie
