		benburb(at)comcast.net Guest
				 Posted: Sun Nov 26, 2006 8:24 am    Post subject: Evans Coolant |
				In my 912 UL installed in a Kitfox III, after about 60 hours TT, I
 switched to straight Evans coolant, doing the system flush as
 required- all as advised by ROTAX.  I have been running very hot
 water temperatures ever since- borderline too hot.  Has anybody else
 run into this problem?  Lockwood tech help asked me why I made the
 switch, saying they don't do it themselves.  Thanks
 Ben
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dhkey(at)msn.com Guest
				 Posted: Sun Nov 26, 2006 8:44 am    Post subject: Evans Coolant |
				I use the Evans in my 912, works great for me. I have to shield off some of
 my oil cooler in the winter months because my coolant temps were at 170 now
 they are back to 190.
  	  | Quote: | 	 		  From: Ben Burbridge <benburb(at)comcast.net>
 Reply-To: rotaxengines-list(at)matronics.com
 Subject: Evans Coolant
 Date: Sun, 26 Nov 2006 11:23:37 -0500
 In my 912 UL installed in a Kitfox III, after about 60 hours TT, I switched
 to straight Evans coolant, doing the system flush as required- all as
 advised by ROTAX.  I have been running very hot water temperatures ever
 since- borderline too hot.  Has anybody else run into this problem?
 Lockwood tech help asked me why I made the switch, saying they don't do it
 themselves.  Thanks
 Ben
				 Posted: Sun Nov 26, 2006 11:13 am    Post subject: Evans Coolant |
				Hello Ben
 "I have been running very hot water temperatures ever since- borderline
 too hot.  Has anybody else run into this problem?"
 Evans does not conduct as well as 50/50. I am not flying, but believe this
 is normal on Europas.
 I talked to Evans, and in automobiles they want you either to increase
 flow with a more powerful pump, or more cooling area on a larger radiator,
 or both to compensate for poorer conductivity.
 Once you reach higher temperatures, instead of boiling and not cooling
 hardly at all like 50/50, Evans will conduct a lot more, this is the real
 advantage. Did you calibrate your gauges to see if they are remote close
 to accurate?
 Downsides besides thermal conductivity less than 505/50, price, not
 readily available local, need to flush, is that it is flammable.
 I am going to try Evans on my 914 Europa first.
 Ron Parigoris
