		hgmckay
				 Posted: Mon Nov 27, 2006 10:18 am    Post subject: SB-912-043-R2 |
				Gentlemen: This Rotax SB requires the 50/50 water/glycol coolant temperature to be measured between the engine expansion tank and the radiator. This means that the sending unit must be a type that can be mounted in the coolant line itself in some manner. All the temperature-sending units I have seen are the type that screws into the engine block. Does any one know of a sending unit that can be connected to the coolant line??
 <![if !supportEmptyParas]> <![endif]>
 Hugh McKay III
 912UL
 Allegro 2000
 N661WW
 hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		piercetonypeggy(at)mail.u Guest
				 Posted: Mon Nov 27, 2006 11:08 am    Post subject: SB-912-043-R2 |
				Grand Rapids sells an inline sensor that fits in the hose to or from the  radiator.
  [quote]   ---
		jodel(at)nildram.co.uk Guest
				 Posted: Mon Nov 27, 2006 11:41 am    Post subject: SB-912-043-R2 |
				It’s probably on the wrong side of the pond for you, but the UK Rotax distributor sells a complete kit for this.
 See http://www.skydrive.co.uk/sd_sa_91.asp
 Simon
 From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay III
  Sent: 27 November 2006 18:18
  To: rotaxengines-list(at)matronics.com
  Subject: RotaxEngines-List: SB-912-043-R2
 Hugh McKay III
 912UL
 Allegro 2000
 N661WW
 hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)    	  | Quote: | 	 		  |   www.aeroelectric.com  | 	  0123456789012345
		Ollie Washburn
  Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
				 Posted: Mon Nov 27, 2006 12:41 pm    Post subject: SB-912-043-R2 |
				Grand Rapids Tech. has a piece of tubing that has a fitting welded to it to take a temp probe. The piece of tubing fits in the hose. They also have one with  room for a pressure fitting also.
  Ollie
  _________________ Ollie RV6-A & Rans S7S
  Central FL |
		Ollie Washburn
				 Posted: Mon Nov 27, 2006 12:42 pm    Post subject: SB-912-043-R2 |
				Check Grand Rapids Tech. They have  one.
  Ollie
  [quote]   ---
  Central FL |
