dsavarese(at)elmore.rr.co Guest
Posted: Tue Nov 28, 2006 4:35 am Post subject: Shinden33 Rough Running[LashBack] |
Scott,
If you would like to resolve the Russian ignition wiring harness forever, please contact me off-list at dsavarese(at)elmore.rr.com (dsavarese(at)elmore.rr.com).
Dennis
Posted: Tue Nov 28, 2006 4:47 am Post subject: Shinden33 Rough Running[LashBack] |
You did not say you tried isolating the problem to one mag or the other? Have you looked inside the magnetos under the mag caps and checked for adequate lubrication on the cam? Also look for obvious binding at the points. Verify the point gap is between .25 mm and .35 mm or .010 to .14. Ideally, .3 mm or .012. Look inside the mag cap for carbon tracks. Gary's suggestion is also very sound and highly recommended. Check the timing on both mags. Let me know what you did or found.
Dennis
shinden33(at)earthlink.ne Guest
Posted: Tue Nov 28, 2006 6:17 am Post subject: Shinden33 Rough Running[LashBack] |
Dennis,
We've done all tests/run-ups on both mags and each mag separately with identical results. I did pull the cap on the left mag and checked everything that you mentioned below and checked out good. It would have to be spectacular luck (good or bad your choice of words) to have identical ignition failures on both mags at the same time or to have the time go out the same amount. Unless of course, there is some form of crossover I am not aware of. Thanks for the advice though.
Scott
[quote] --
[quote] Can you "paint that Yak for $99.95." as well???
Sorry Dennis - just a joke. I do appreciate all the advice.
Oh but wait a minute - does Savarese have a new call sign??
Dennis "Earl" Savarese
Dennis "Schieb" Savarese
I leave that open to discussion.
S
[quote] --
Posted: Tue Nov 28, 2006 6:53 am Post subject: Shinden33 Rough Running[LashBack] |
That was uncalled for.
Dennis
ScottA
Joined: 05 Jan 2006 Posts: 100 Location: Park City, UT
Posted: Tue Nov 28, 2006 10:08 am Post subject: Re: Shinden33 Rough Running[LashBack] |
The joke wasn't very funny. What will be funny is when it turns out to be the ignition wires..
SA
[quote="shinden33(at)earthlink.ne"][quote] Can you "paint that Yak for $99.95." as well???
S
talew(at)bellsouth.net Guest
Posted: Tue Nov 28, 2006 3:34 pm Post subject: Shinden33 Rough Running[LashBack] |
Did you run a compression test on these three cylinders?
Terry Lewis
