PS
Posted: Tue Nov 28, 2006 12:55 pm Post subject: CJ6 Vent |
I would like to clean my fuel vent system on my CJ. What is the best procedure?
Also, does anyone have M14P intake tubes they would part with. I am hoping there is a derelict M14 sitting around with tubes( hopefully the bottom tubes with drains) I can experiment with.
Phil Salter
_________________ Phil |
dsavarese(at)elmore.rr.co Guest
Posted: Tue Nov 28, 2006 1:11 pm Post subject: CJ6 Vent |
Phil, if I remember correctly, your lower 3 intake tubes have a small plug in them. I've installed the Kimball intake drain kit on these type of intake tubes many times. You just order the kit from Kimball without the large SS intake plugs that go on the larger intake tube drains on an M14. Use the #4 blue anodized fittings that come in the kit; remove the plugs and drill and tap the tube with a 1/8 NPT thread tap. Then screw the #4 fittings into them. If you press the drill bit and tap into a toilet ring wax seal (about $2 at the hardware store) before you start drilling and tapping, the wax will grab the metal shavings.
Dennis
